Question about Equator EZ 2512 CEE Front Load Washer / Dryer
Equator EZ 2512 CEE Front Load dryer not starting
The all in one doesnt dry.
I can run a washer load and have it set up to dry and it just sits there with the dryer light ON and the door/lock light blinking slowly.
If I do a Dry Only cycle i set the washer to reset set the dryer to 110 min and then turn on the power. the dryer light turns on. The door/lock light blinks slowly a few times then fast while it accepts the directions then blinks slowly again and nothing happens after that.
Any advice would be useful.
Thank you
  • dkleimann Feb 22, 2008
    Maybe I am missing something in the manual you sent me. The light blinks constantly. It doesn't blink a certain number. I know the dryer assembly works b/c it kicks on during the end of the Cotton wash cycle. So i know there is nothing physically wrong with the dryer assembly. It goes through the wash cycle and then the dorr lock light blinks as if the cycle is done. The dryer lights is on, but nothing turns on.
The mode light isn't blinking a fault code. It is blinking as if it is in the end of a cycle. But it is at the start of the drying cycle. The drying cycle never starts. The quick blinking is the program being accepted by the unit according to the user manual.
I did try counting the mode light and it blinks same interval uninterrupted for 20 min
Posted on Feb 20, 2008
  • 770 Answers
The blinks are the fault code on the unit you will have to watch them an count match them to the chart in the service manual
Here is a link to the service manual
http://www.appliancedesk.com/appliancedesk/service/CWD/EZ3612CEE_EZ2512CEE_EZ1612V/Service_Manual.pdf
  • Gary Davd
    Gary Davd Feb 22, 2008
    Use the link to see what i am talking about
Nordmende washer dryer not drying
Check that the heating element is functioning. Check thermostatic cut-out
May 11, 2014 | Equator EZ 3612 CEE Front Load...
My equator EZ 2512 CEE washer/dryer suddenly wont finish washing a load of laundry. I think some sort of drain pump may be broken. The door will not unlock. I took the drain hose out and put it on the...
If you are still looking for a solution to this here it is:
In these machines if you try to change the setting of the washer knob without letting a cycle finish which is already set it may happen that the unit won't function properly and hence the unit needs to be reseted. There is a reset procedure for the same and let me know if you would like have the same.
If the door is not opening it is advisable to reset the unit first and then try opening the door which should work and also the door handle won't break then.
If you have already replaced the door handle on your machine it is fine or else you may want to order the same from appliancedesk.com
Nov 22, 2009 | Equator EZ 2512 CEE Front Load Washer /...
Broken Handel for a Equator ez 2512 CE
If you are still waiting for this part you can get it from appliance desk through their website www.appliancedesk.com click on shop parts.
Jun 12, 2009 | Equator EZ 2512 CEE Front Load Washer /...
When drying rubber burning smell from inside Equator EZ 3612 CEE
If you are still wanting to know the reason, it may be that the door gasket has warned off and may need to be replaced.
Apr 04, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Equator ez2512 washer dryer keeps throwing the main belt off.
somthing is going to be obvious there.you have to inspect it whatch it while it runs
Dec 31, 2008 | Equator EZ 2512 CEE Front Load Washer /...
Leaks near filter
It may be the drain pump that is leaking, you can open the back panel of the unit and figure out if it is so by checking the drain pump for leakage just when the pump starts to work.
Oct 17, 2008 | Equator EZ 3600 CEE Front Load Washer /...
Equator door handle
Here is the phone number for equator, 1800-935-1955 or parts and service 800-776-3538. They sould be able to help you.
Their address is 10067 Timber Oak Dr. Houston, TX 77080-7045
Jun 27, 2008 | Equator EZ 2512 CEE Front Load Washer /...
Pre-set buttons
they are activated when pressed in
Dec 19, 2007 | Equator EZ 2512 CEE Front Load Washer /...
Equator EZ 2512 CEE Front Load Washer / Dryer Logo
294 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Dan Webster
Dan Webster
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
