Question about Vizio L37 Television
How to repair Vizio VP 322 power supply - Vizio L37 Television
  • Vizio Master
  • 12,061 Answers
Power Supply repair is NOT easy, but here goes. First Without Power do as"Dry" Multimeter Ohms, check of ALL discrete components looking for "Shorts" Check, Diodes, Caps, Resistors. Coils etc.., Check all Transistors, B.C.E. with your meter set on "Diode test" look for "Bad" junctions. Then you check to see if you have power to and on the "other side" of the Bridge Rectifiers/Diodes. if not, replace that. if yes, proceed. Check for the correct Voltages around the Controller Chip. and Check the output of the Chopper Transformer, Check to see if the Waveform around the Controller IC is right. Check ALL voltages are correct & within range.. Now during this you should have found the faulty Bit(s). Replace as necessary. BE CAREFUL. I always work on ANYTHING connected to mains through an Isolation Transformer.
Posted on Feb 03, 2010
What are the symptoms of a bad psu for vizio m550nv
Vizio 0500-0612-0030 Power Supply / LED Board for M550NV
www.shopjimmy.com/vizio-0500-0612-0030-power-supply-...
ShopJimmy
$77.42 - ‎Out of stock
This Vizio 0500-0612-0030 Power Supply / LED Board for M550NV (0500-0612-0030) works for these ... The odds we'll get it soon: Bad (What does this mean?).
Vizio 55" M550NV 0500-0612-0030 LCD Power Supply ...
electropartsonline.com/vizio-55-m550nv-0500-0612-0030-lcd-power-su...
Vizio 55" M550NV 0500-0612-0030 LCD Power Supply Board Unit Motherboard. ... Any tears or bad connections between boards must be replaced FIRST. 2.
EASY HOW TO FIX LED Vizio TV- no power - YouTube
? 6:13
https://www.youtube.com/watch?v=9xZcTWr2yV0
Nov 5, 2013 - Uploaded by Tampatec
DiY How to Fix led / lcd Vizio TV service repair - no power service repair ... I can not get it to power on so I ...
Jan 17, 2016 | Vizio M550NV 55 in LCD HDTV
How do I fix my VIZIO TV?
Vizio TV Repair - Instructables
www.instructables.com/id/Vizio-TV-Repair/
InstructablesSo my Vizio TV was flashing on & off rapidly every time I switched it on. ... good way to get something to work, but it got things working until I had time to repair it.
Fix Power Problems In 5 Easy Steps: What To Do When ...
vizhdtv.com/fix-power-problems-in-5-easy-steps-what-to-do-when-your...
Aug 26, 2015 - Vizio TV power cord plugging into a power outlet. Do you know ... Powerproblems might require service or replacing parts inside the TV. Before ...
Dec 14, 2015 | Vizio E-Series E470I-A0 47" LED TV...
Vizio 60" E601i-A3 smart LED 120hz 1080p BUI is not powering on after power surge. Any suggestions on how to repair, as it's being paid off still through Aarons, and pretty sure they won't cover damage...
Most probably the fuse 'T4A H / 250 V AC' on the power supply board or capacitor/s thereon would have gone off. Either you have to change those dead parts or replace the power supply board with a new one costing around $49.41
Your Power Supply Board shown given below:
Mar 27, 2015 | Vizio Televison & Video
Vizio VP 50 hdtv 20 A it comes on but shuts down after a few min
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
Aug 26, 2014 | Televison & Video
I need a vizio vo370M schematic diagram
has anyone found a place to buy a t2d diode 94 or t2d 94 diode for a vizio vo370m power supply board, placment d106
Dec 09, 2011 | Vizio VO370M LCD TV
My VP504fhdtv10a vizio plasma TV when connect power cord the Vizio in front light up yellow/amber but will not turn on. I have replace Logic Control D Board still have same problem. I do research online...
Logic Control D Board got nothing to do with this problem. This is your main power supply gone bad(usually not the sub power supply). I just repaired my VIZIO by replacing main power supply. Just remove back cover and your board will be right in the middle of the screen. Just get board part/serial # and google it. My best price was through eBay(around $100). Everything is fine now.
Nov 07, 2010 | Vizio VP504F 50 in. Plasma HDTV
My vizio tv VP 322 will not turn on ...My question is , is there a reset button.
Unplug it for about an hour to let it reset itself. If it still doe not work, you will have to look inside and troubleshoot it.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 20, 2010 | Vizio L32 32 in. LCD HDTV
Remote code for Goldstar VC681M to match Vizio VP-50 remote
Try 747; it's supposed to work on most combomodels
Feb 18, 2008 | Televison & Video
Vizio L37 Television Logo
536 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
