Question about HP PSC 1315 All-In-One InkJet Printer
Printer i can scan but cant print. comes up that cant find hard drive?
  • ariesaries Mar 05, 2008
    it comes up new hardware found..... then psc1310 with computor ond magnifieing glass.
    Genius:
  • 3,587 Answers
Keeps coming up and running it prints out alingning ink cartridge I cant get it to stop doing this..So printer will not print.
Hello, try this:
Place a blank sheet of paper in the printer.
Turn on the printer, and you can see the alingning page.
Put that page in the scanner and press the key SCAN.
Although it has already done, some printers will lose the registration and request a new alignment.
Aug 10, 2014 | Dell Photo 926 All-in-One Printer
Problem with the hard disk
Check to see if sd card for print and scan are installed on side of copier. Could be bad or missing. Go into user tools and see if they show up in display. If copier comes up in copy mode the hard drive is probably ok, try going to address book User tool/counter button then system tools then administrator then scroll to address book click on it. If you can do that then hard drive is ok.
Jan 24, 2014 | Ricoh Aficio 2045e 2035e Copier...
How come my pc cant link to scan doc???? this is an office pc. my pc at 1st can link to this canon IRC3220N , it can photostat can scan from the canon to pc into scan doc file. but for right now my pc...
try to reinstall the driver s for the printer/scanner ...and see if the issue is solved.....Another thing ....if the scanner is used by multiple computers you have to give the scanning command from the computer ...and not from the scanner itself...This way you will be able to import the scan result into the library of the program that drives it ..
another thing that may happen is the link to be broke ...so ..get to the fax and printers in the start menu ...and open it ..and redo the link ..by scanning for printers and choose it again from the list ..(by name ) ..and make it the default printer/scanner..
Jul 05, 2011 | Office Equipment & Supplies
My Deskjet F2480 printer won't print. It scans fine but when I try to print something it appears in the print que for a second and then disappears? I've used the printer many times before but have recently...
try unplugging the printer deleting and then deleting it from the control panel. Plug the Printer back in and go through the install utility, even if this does not fix the problem it normally explains the fault.
Mar 07, 2011 | HP DeskJet F380 All-In-One Printer
Deleting scanned information from all-in-one printers' hard drive
The Canon doesn't have a hard drive, it only stores images until they are printed and only in flash memory. There will be no personal information left on it if you discard, unless you have phone numbers stored in fax memory.
Sep 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I cant scan from my kodak all in one printerto my
Try system restore to a day before your problems started and then you should be right.
Jun 03, 2009 | Kodak 5500 ALL-IN-ONE PRINTER
Ricoh aficio 2027 print/scan module addition
you need to go into the sp mode and turn the NIC unit on and make sure the USB is off. Won't work until you do.
Apr 21, 2009 | Ricoh Aficio 2027 All-In-One Laser Printer
How to print photos from hard drive canon pixma MP610
dl kodak .com software new 7.0 verison works with all printers bring pic u want up auto fix it then print button on top should do it k free software and the best
Oct 06, 2008 | Canon PIXMA MP610 InkJet Printer
Dell No. 962 (All-In-One Printer)
you need to go to your printer settings and make sure it is set as the default printer for everything. Make sure it is also set as your default scanner. you may also try lightening the image with the lighter/darker setting on the machine. if this continues, you may want to see if a section of the light is burnt out. this wiill cause darkness on scan & copies but not printing from the c drive. Make sure the machine is lighting up completely when is scans or copies. If part of the lighting is burnt out it will be a fix or replace situation.
Mar 05, 2008 | Dell 962 Photo All-In-One InkJet Printer
Slow printing
Not enough memory, add a harddrive or more memory.
Oct 25, 2006 | Canon imageCLASS D320 Digital Copier
HP PSC 1315 All-In-One InkJet Printer Logo
83 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
