Question about Fetco International CBS-2052
We have a the twin 1.5 tanks and can run a full tank of coffee but cannot get the 1/2 or 1/4 pot buttons to work
RTFM...for real. Turn power off, under unit, when machine powers on, press and hold the stop button on the left brewer. When it then reaches prgram cycle, you need the manual to refer to. good luck.
Posted on Sep 29, 2013
Why won't my bunn coffee maker turn on
You should check to insure that the tank inside the machine is full of water. Pour in 1 pot of water at a time until you get water to come out of the brew basket. If you haven't done any internal damage it should be ready to brew a pot of coffee inabout 20 minutes.
Sep 21, 2014 | Bunn 10 Cup Home Coffee Brewer
WE HAVE A BUNN VLPF SERIES COFFEE MAKER. WHEN YOU PUSH THE BUTTON TO MAKE A POT OF COFFEE, THE WATER DOESNT STOP AT ONE POT IT MAKES 6-7 BEFORE IT STOPS. IF YOU TURN OFF THE MACHINE WHEN THE DECANTER IS...
Sounds like your timer part #32400.0002.This is the new type timer which replaces the dial timer.Another thing is does this happen when you turn on the on/off switch? I would also check your liquid level probe in top of tank.Always a possibility bad liquid level board.If it only does this when you push the brew button the timer is bad.
Feb 07, 2011 | Bunn VLPF Coffee Maker
We poured the amount of water needed to make the amount of coffee desired but 30 minutes later no coffee was made. Does the bottom "warmer" button need to be on or does the maker just need to be...
The tank inside holds about 2 and a hlalf pots of water. Once the tank is full, whatever you pour in will come out. The unit has to be plugged in to make coffee. Leave a pot under the brew funnel and pour a pot of water in. If nothing comes out within a minute, pour another pot of water in. Still if nothing comes out do it again. This time for sure water will come out. It will take avout 10 minutes to get hot enough the first time it is full to make coffee. If you have a thermometer, the water should be about 190 degrees F to make coffee correctly.
Oct 28, 2010 | Bunn VPR Coffee Maker
Model Cwtf 15 It keeps running. when pot is full
Hi. Let it run until the water tank is empty. Then just fill the pot to the amount of coffee you want to serve.and dump it in, now the maker can only make the coffee for the amount you put into it. Good luck. bobbyone
Aug 13, 2010 | Bunn NHB Coffee Maker
How do you clean the Mr Coffee machine? billie_tate@msn.com
You can purchase packages of cleaner in your supermarket that mix with water and are poured into the water tank. Follow the directions on the package.
You could also do it with simple white vinegar, too. Some people like a 50/50 vinegar and water mixture and other like to use vinegar "straight" You can fill the tank 10 - 12 cups with the mixture or pour the straight vinegar into the tank 1/2 way (or all the way - your choice) and press the brew start button. No filter is required.
The vinegar will breakdown the mineral deposits that form in the tank and on the heating element. Usually once is enough, but you might want a second round with a fresh mixture. Do not reuse the old mixture in the tank. In any case, continue cleaning with mixture until the water is clear (again, once is usually enough).
When done cleaning, make at least 3 full pots of water only to completely flush all vinegar from the tank and heater. Failure to adequately flush will result in a terrible tasting pot of coffee.
Good luck - I hope you found this very helpful.
Nov 20, 2009 | Coffee Makers & Espresso Machines
Bunn coffee maker
It sounds like you have a pour over model and the problem is the tank isn't full. Turn the machine off (or unplug it). Put a pot on the warmer like you are going to brew coffee. Pour clean cold water into the top until it starts coming out the sprayhead (above where the coffee grounds go). Now plug it in and turn on. Let it heat up then you can brew.
The way your machine works is that there is always about 2-1/2 pots of water in the tank. The water you pour in to make coffee is actually pushing the hot water in the tank out. So, if you don't fill the tank before using it, you may be hurting the heating element since it isn't totally submerged in water.
Oct 12, 2008 | Bunn NHB Coffee Maker
NEWCO manufactured 1989 model RC-28F
Aug 28, 2008 | Coffee Makers & Espresso Machines
Braun Coffee Maker Type 4093
it sounds like the hole at the bottom of the waqter tank is clogged. the fact that it is hot means the electrical parts are all working.
it should be an easy fix
May 18, 2008 | Braun Aromaster KF 400 Coffee Maker
3-Pot coffee Maker instructions
The first time you use the machine you need to make sure it is full of water - before you plug it in and turn it on. Put an empty coffee pot under the brew basket and fill another empty pot with clean cold water.
Pour the water into the coffee maker. If water comes out then you can plug it in and turn it on. The water heating tank holds about 2-1/2 pots of water so if your machine is empty you will need to keep adding water before you turn it on otherwise you may burn up the heating element.
After the green light comes on - indicating that the tank is hot you can brew a pot of coffee. This machine is meant to be left on all of the time so it is always ready to brew. If you choose to turn it off when not in use, you will need to give it about 10 minutes to fully heat up the water before you brew.
Jan 25, 2008 | Bloomfield 8571 Coffee Maker
Coffee doesn't brew full pot
It's possible that the hose or valve running from the tank to the heater is partly clogged. See superkev2000 and W5VSI fixes posted here.
Dec 10, 2007 | Cuisinart DCC-1200 Coffee Maker
Coffee Makers & Espresso Machines Logo
53 people viewed this question
Top Fetco International Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Fetco International Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
