Question about Frigidaire FEF336BC Electric Kitchen Range
How do I remove the bake element in a CFEF365RIS1 FRIGIDAIRE ELECTRIC RANGE.
  • 126 Answers
  1. disconnect power
  2. remove screws holding bracket to rear inside wall
  3. pull element out slowly and disconnect wires,pull off
  4. if wire disconnects while pulling element out you'll need to remove rear panel to reconnect
  5. hope this helps,please rate my solution :)
Posted on Feb 03, 2010
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
The lower element burned in my oven. I replaced the element, but the oven will not work.
unplug range ..remove the back cover plate check all wires all connections ..their must be a burnt /broken /dissconnected wire ..check where the wires connect to the bake an broil element ..and the bake broil switch..if all looks good .then the bake broil switch burnt out when element blew out..plus is the breaker tripped in the box ..it prob. tripped when the element blew out..let me know..good luck
Aug 28, 2010 | Frigidaire FEF366 Electric Kitchen Range
My stove self cleaning light keep blinking and it will not bake. I have tried unpluging it from the wall.
check the bake element it most likley burnt out ..unplug range ..remove oven racks ..look at element with flash light to see if it broken burnt..if it is ..remove the 2 screws at the hing ..pull element out ..remove wires ..you will need model#an serial # to purchase call local appliance store for element ..or the local used appliance repair shop may have one cheap..let me know ..good luck/joe/
Aug 27, 2010 | Frigidaire FEF352 Electric Kitchen Range
On Frigidaire Self-Cleaning Range, bottom oven element does not work while top element does; bake relay problem?
Sounds like the bake element is out. Remove it and test it for continuity. If you need further assistance please feel free to contact me.
Jul 09, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Electric Range Model FEF355ESB
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 07, 2010 | Frigidaire FEF355 Electric Kitchen Range
Broiling works but baking does not work
CHECK FOR 240VOLTS AT THE TERMINALS OF THE BAKE ELEMENT. GAIN ACCESS BY REMOVING THE BACK PANEL OF THE RANGE. SOMETIMES THE TERMINAL WILL BURN OFF OF THE WIRE GOING TO THE ELEMENT. THE WIRE WILL JUST BE HANGING THERE. BE SURE TO UNPLUG THE OVEN BEFORE REMOVING BACK PANEL. IF THE WIRE IS BURNT, REPLACE THE TERMINAL AND REATTACH TO THE ELEMENTS TERMINAL. IF THE TERMINAL IS DAMAGED, REPLACE BAKE ELEMENT.
IF THERE IS NO VOLTAGE TO THE ELEMENT, REPLACE CONTROL.
Apr 03, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire FEF336BC Electric Kitchen Range Logo
117 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
