Question about Proform 575 Crosstrainer Treadmill
Need to know size of ac power cord to get ie. volts and mA for a proform gl 125 recombent bike
  • 10,865 Answers
Hello. Your proform can be operated on electric or with 4 D cell batteries. If you do not have the power supply cord that comes with this unit you must order one from the company. The information on how to order one from the company is at the end of the manual. Here is the manual:
http://fitness.manualsonline.com/mdownloads/ae475852-929e-4cad-8d5a-1ac56f09731a.pdf
Kindly rate my answer. thankyou.
Posted on Feb 03, 2010
I need an adaptor for my Dr. SCHOLL'S back massager. It says class 2 Power Supply. AC 120 60 Hz output AC 20 1000 mA ??? I don't know what all this means. Please help!
go to your local thrift store , they usually have them, especially Value Village. Find one that has 20VAC output at 1000ma printed on it. it will not do any harm if you find one that is 20 VAC and more than 1000ma ,ie anywhere from 1000ma to 3000ma so long as the price is right. the higher current ones will not overheat as easily. And then the next thing you need to be sure is that the output plug fits into your massager. If you use a 18Vac unit with 1000ma , it is a bit dicey, it might not have quite enough volts for work properly, but it might work, hard to say. of course 1000ma is the exact same thing as 1A as the "ma" simply refers to milliamps, so 20Vac 1A would also work.
Jul 11, 2017 | Power Computers & Internet
6 AA Batteries generate how many amps
If this is a battery powered CD player,
we are talking mA not amps.....6 x 1.5volt batteries give you 9 volts
I would recommend something like this:-
http://www.ebay.co.uk/itm/New-AC-DC-Universal-Travel-Adapter-Input-110-220-Volt-7-Output-500mA-/251316939793?_trksid=p2054897.l4275 This will have more than enough power for the CD Player.
Feb 06, 2013 | Sharper Image Audio Players & Recorders
What type of ac adaptor do i need to a proform gl 125 interactive trainer
Hi
Mine says on back - Plug in class 2 Transfromer -
Input:AC 120v - 60 Hz 150mA Output:DC 9V -1A
Hope this helps
Dixie
Feb 21, 2010 | Proform GT 85 x Upright Bike at GNC
Lost power cord
Specifications:
  • Manufacturer: HP
  • Input: 100-240V, 50/60Hz
  • Output: 32V, 16V
  • You can get more information here:
    http://www.unitedsale.com/product_info.php?products_id=18583
    Please vote me if you like my post.
    May 25, 2009 | HP Photosmart 2610 All-In-One InkJet...
    Sanyo CLT2054 - power cord has light but when I plug it into the
    OK you need a volt meter to check the voltage output of your power pack as two things cause this now enough power out the pack to run your unit or the unit has a short both problems will unlight the light so you need to know if the power supply is working right first as it should say like 120 volts AC in and 12 volts DC 1000 ma out so you will need to mesure this with a volt meter. this is a common problem loading the load of the curcuit as in your TV is mor the the power pack is giving out thus shorting out the power pack of any voltage present, as the little LED light your seeing only takes 5 volts at very ittle current to light and dose not repersent the total voltage output of the power pack itself
    May 16, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
    Missing power cord 12v
    go to radio shack get a 12 volt 1500ma power supply with I belive it is a N% plug end but any how 800 ma to 1500 ma should run this and the plug end is standard plug with plus 12 volts on the inner side and negitive on the outer case side look at the back of the TV or the old power supply it sould have info on voltags and amprage, and the plug as to inner voltage and outer voltage on the plug any old time radio shack or electronics shop should be able to help you bring in the flat screen if need be as if you know its 12 volts then It wont mater weather you use a 1000ma 1500ma 12 volt ubnaversale power pack as the tv will only use the current needed so more MA is good the only concrn you have is the right mini barrle plug and the right side of +/- voltage on that mini plug being most use + voltage in the inner most circle and - 12 volts on thje outer
    Apr 05, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
    Output voltage of 120volt AC brick & approx dimensions
    Any PC speakers that have a AC plug pak attached can probably use 12V simply cut off the AC plug packs lead that goes to the speakers, and connect up 12V ya should be good to go.. some connect with a Phono Plug, and usually the Outer is Minus Voltage and the Centre is Plus Voltage .. they are also generally Diode protected so a reversal shouldn't cause too many probs... GL
    Jul 29, 2008 | AOpen MA-691 Computer Speakers
    Proform 575 Crosstrainer Treadmill Logo
    464 people viewed this question
    Top Proform Exercise & Fitness Experts
    Matt Olenzek
    Matt Olenzek
    Electro Med Services...
    Owen Barnes
    Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
