Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas
The hot water is not getting hot enough - Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas
  • 1,420 Answers
Time to run some vinigar thru the unit to descale it. Contact Rinnai for details. 800-621-9419.
Posted on Feb 05, 2010
Water is not getting hot enough
thermostat set too low.
leak in hot water line or hot water being used too fast.
defective thermostat
Dec 09, 2014 | Reliance Water Heaters
NOT GETTING HOT ENOUGH
Copy following link to identify type of water heater:
http://waterheatertimer.org/How-to-fix-water-heater.html
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 20, 2014 | Premier Water Heaters
The water never gets hot when on normal settings
This time of year the water comming in the house is much colder and heater has to work a lot harder to heat 40deg. water than ot does to heat 70deg water in the summer time. its normal.
Jan 09, 2013 | Water Heaters
I installed a 30 gallon gas hot water tank and sometimes i get strong water pressure but my hot water doesn't last long enough for 2 showers, but if i have low water pressure we can get in 4 showers. Any...
At a high pressure you are consuming more hot water. It sounds to me like the water heater isn't big enough for what you need. You can try turning up the heat thermostat on the water tank. If the water gets hotter you won't need as much for each shower and it will also recover faster at a higger temperature.
Mar 26, 2011 | Whirlpool Water Heaters
Do you connect to cold water or hot
You need to hook that to the hot water line...often the dishwasher will work better if you even run water to the sink and get the water hot before starting the dishwasher....they will keep the water hot but do not have a strong enough element to heat cold water hot enough to do a good job for you...
heatman101
Feb 02, 2011 | Dishwashers
The water is not hot enough when it comes out even if you have it turned all the way to hot. I think it is a 1300 or 1400 Delta Monitor faucet. I can't get the handle off. In order to set the water temp a...
taps just pass water --hot or could or both
water not hot enough is from a hot water system that is not heating the water
normally there is an inlet supply tap for the hot water system
if your system has a hot water control valve ( a valve that allows cold water into the hot water line (By law) to prevent scalding and hot water burns , that unit has a have a habit of failing and making the water colder that it is supposed to be
otherwise ,
check the elements for operation
Nov 14, 2017 | Home
I have been putting my washing on a 40 wash and have been putting enough washing liquid in but my clothes just will not wash, i have felt the glass in the door but it doesnt get very hot, is my washing...
The hot water goes into the machine at a slower rate than the cold water does. Open the hot spigot (water valve) behind the washing machine all the way open, then open the cold spigot just enough to get the desired 'warm' temperature of the water going into the machine while the machine is filling. You may have to shut the door to allow water to flow. Remember that it takes a minute or so for hot water to reach the machine from hot water tank.
Dec 08, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
My Rinnai 24 will only start when I use the the hot water in the kitchen (which is closer to the heater). If I open any of the hot water taps in the bathroom it doesn't work.. I have to start the hot water...
Looks like your recirculation pump might be bad. If your opening a valve close enough to the heater and it comes on, It sounds like it's giving your pressure switch a false reading and allowing it to come one while the farther away you get, it is not enough line pressure to overcome the safety's of the heater.
Sep 28, 2010 | Heating & Cooling
Water is not hot enough and the temp is on 120 I have a notiz tankless hot water heater
check your gas pipe size. make sure you have enough gas running to the unit. also turn all your faucets on hot and turn off the cold water to the heater and see if you get any water out of the hots anywhere, that could mean that you have a cross connection.
Aug 24, 2009 | Noritz Water Heaters
Bosch TF250 hot water service
Replace the flame sensor.
May 11, 2009 | Bosch Water Heaters
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas Logo
158 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
