Question about Hitachi 61SDX01B 61" Rear Projection Television
Green 5 in lower right hand corner
This is what i did so far i changed the stk392-110 ic chips cause of magic focus wouldnt focus. also got a green number 5 in lower right hand corner even before the chip replacement need some help
thank you
joe
  • 2 more comments
  • spdracerxx1 Feb 20, 2008
    how do you do that
    when i go into the service mode for the converg. only the green and blue move but cant get it to straighten out just slopes off the screen to the left and its up on the right on a diagonal and it will not line up with the red one need some more help
    thanks
  • spdracerxx1 Feb 21, 2008
    no but when i looked around the ic's nothing looked burt or leaking so i figured all was fine
  • spdracerxx1 Feb 24, 2008
    how many resististors are around the ic should i just change them all
    President:
  • 4,402 Answers
Dont worry about the magic focus check the convergance that all guns align.
Posted on Feb 20, 2008
  • 1 more comment
  • Cary Farah
    Cary Farah Feb 20, 2008
    did you check the resisters? when you replaced the ic's?
  • Cary Farah
    Cary Farah Feb 21, 2008
    you will need to check the resisters. IC's typically don't show when they are bad, if you have a bad resister it can blow the ic out again..
  • Cary Farah
    Cary Farah Feb 25, 2008
    1 each of the following 1Watt axial lead fusible resistors:
    1.5, 1.8, 2.2, 2.7, 3.3, 3.9 Ohms.
    just lift one side of each resister and check them, on my set three of them were located by the yoke plug.
I have a problem with the magic focus button I get a green light on the left hand top corner of the TV with a number 3 in the bottom right hand corner of the screen. The solution is a convergence circuit...
hello, it's not just about changing the convergance ic also you will have to test the resistor in front of the chip and the capacitor at either end you will have to desolder 1 end of the resistor so you get a proper reading on the multimeter also you will need a esr meter to test capacitors and good desoldering and soldering skills, i'm not trying to put you off just explaining what is needed, make sure the power off good and luck be safe
regards
shaun
Nov 22, 2010 | Hitachi 53UDX10B 53" Rear Projection...
My hitachi keeps showing red and blue bands. when
Replace your convergence ICs they are big black ICs will have part number on them STK392-110s use 150s better ICs Mats has them 1-800-628-1118 also CK Low ohm reisitors 1.5ohms and up 3.9 ohms
May 09, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Picture is not focused, color is off. When we
this sounds like the convergence ic's need to be replaced that should fix the problem
Jan 25, 2010 | Hitachi 57F500 57" Rear Projection...
Color and Image are Bad!
Convergence IC's are bad or poor solder connection, IC's are large chips with heatsink mounted to them, re solder them to board, if not fixed replace IC's, should be 392-110s, but check them number is on the IC itself.
Aug 09, 2009 | Hitachi 46F500 46" Rear Projection...
Hitachi tv magic focus does not work
Your problem is the convergence circuit. This is very common in CRT projection sets like yours. There are a couple of IC's that need to be changed and possibly some resistors. A good repair shop will run you $400-$500 to do the repair.
Oct 28, 2008 | Hitachi 53UDX10B 53" Rear Projection...
MAGIC FOCUS
I had the same problem. Had to have the amplifier replaced. Cost about $100.
May 19, 2008 | Hitachi 43FDX20B 43" Rear Projection...
IMAGES ARE OVERLAID AND NOT IN FOCUS
Here is the schematic diagram. Download all the 13 parts and unzip them using winrar.
The parts you need are listed on page # 50 of the schematic diagram.
You will find the ICs HERE.
Make sure you check the fuses and micro/pico fuse nearby the ICs, as well some crystallized solder joints.
Good Luck.
Mar 16, 2008 | Televison & Video
Magic focus trouble
Convergance amp ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 19, 2007 | Hitachi 46F500 46" Rear Projection...
Out of focus
Rach, if it doesn`t move from green to red to blue in Magic Focus then there is a problem with the convergence IC`s and probably one or more support resisters. These components will have to be replaced, questions? ask away, BMW Rider
Dec 14, 2007 | Hitachi 57F500 57" Rear Projection...
Convergence problem
I had the same problem sounds identical. My warranty was up in a couple weeks when this happened so they came out and fixed it. They replaced the red converter IC. However just recently the blue and green is acting up??? My warranty is up now so thats a bummer.
May 31, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 61SDX01B 61" Rear Projection Television Logo
192 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
