I want to install Belkin N Wirelss Router as a bridge to my current Mac Airport so I can get internet in another room as well. I am not a technical person and just need step by step instructions
  • 6,993 Answers
At the back of the wireless router, you will find four or more ports. One of these ports is labeled "Internet", while the others are 1, 2, 3....
Now, connect the main internet cable to the "internet" as it will be the one to feed others.
Any other computer you want to connect with cable can be connected to any of the remaining ports as the main internet cable will feed the others.
Then for the system with wireless, you do not need any wire. Just put on the wireless on the system, go to network search and allow the system search for your wireless router, once it finds it, click on it and allow the system pair with the router.
This is all that need to be done.
Take care
Posted on Feb 03, 2010
Where is wds bridging in belkin f7d2301
There is no Wireless Distribution System (WDS) on this Belkin product as it is a SWITCH, not a router.
See the reply from Belkin here.
Belkin F7D2301 Airport Xtreme BS 4th gen client configuration
You would have to buy a router, connect it to a broadband service and put this switch on the LAN side to get Internet access or connect up to a Wireless device.
Dec 23, 2014 | Belkin Computers & Internet
Problems setting up new macs and a new wireless system with a PC
The MAC address of the network card on the PC is probably registered with Tiscali. The easiest thing to do is to Connect the Belkin router to the internet, then go into the config and clone the MAC address of the windows PC. Once this is done, then you can either plug in the airport express, or configure wifi for the Macs from the belkin.
Jul 23, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Trying to create a bridge with two routers
You do not need a bridge if you are using a wireless adaptor on your pc in the other room. Just set up the Belkin Plus router to the WEP security settings you want and make sure the pc wireless usb adaptor has the same settings as the router. You should be good to go. Good Luck.
Jul 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can't get network connection using XE 102 and WGX 102. Have Mac computer and a linksys router. In room with the router, I pick up the linksys network on my MacBookPro laptop. Installed (hardwire) XE 102...
If you are able to pick signals on the laptop, i am sure that your router & mac book are good.
there are only two possibilities to work on ;
1.) look for any interference between the router & computer in the other room like ( refrigerators, television, Music systems, AC, Thermostats)... by pass 'em if required.
2.) The installation of the reciver on the Mac book might require a range setting.
Fame !
Jul 04, 2009 | NetGear XE102 (XE102US) Bridge
Problem with Mac and Belkin router
I have a Mac Pro and a Belkin F5D 7230-4 Router. The Mac links to the WiFi but will not go on to the internet. The Router works fine with a wired PC and other wireless PCs. I have updated the Belkin with the latest Firmware but it does not help. I have tried powering down the Router and Modem
Gmac
Feb 18, 2009 | Belkin (F5D5231-4) Router
Belkin n wirelss router setup
I made a video on how to do it on my F9K1003V1. It should be close to the same setup. The IP address you use to log into it should be the same as I use in the video but the menu will probably be a little different.
Feb 14, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Cannot connect my Mac Pro to the internet via my Belkin wireless
With the router powered on, use a small thin object to press and hold the reset button for exactly seven seconds. The router lights will flash and this will restore the router to factory default. Connect your computer to one of the routers lan ports with an etherent cable. Open your web browser and navigate to 192.168.2.1. This should show the router status page with the default settings.
This will make the router unsecured again, so be sure to go back into setup and reset your Wireless security. I suggest using WEP authentication, and using a 10 digit ph # for your key (that way its easy to remember).
Dec 31, 2008 | Gateway 802.11g Wireless DSL/Cable Router...
How do I access my Belkin N Router's settings?
open internet explorer and type 192.168.2.1 and the will get u to the belkin router page and then click on mac address control and then type ur password to get in to the router and it will take u to all the mac address u have allowed or denyed
Dec 28, 2008 | Belkin (F5D72304F5D7000) Router
Wireless connection
Access the routers admin page with the hardwired pc.  http://*gateway*  right click network status on pc and get gateway.  Google the model you have for the default passwords.  Setup your wifi security then do the same to your laptop and attempt to connect again.  Bad settings somewhere.
James Mac
Sep 09, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
