Question about Lexmark X8350 All-In-One InkJet Printer
When i scan a document the file size is too large. a 1 page document scans as over 27,000 KB using 300 dpi. if i use smaller dpi the print is too light.
    President:
  • 1,768 Answers
1. Increase the contrast on the print. That is increase the ink that is dispensed.
2. Check the user manual as to how to do this function.
3. It seems at this resolution the printer reserves the ink dispensed when this size print is selected.
Posted on Feb 03, 2010
I have used last 4 year canon 2900B printer. How to set 300 dpi printing resoluation
Canon PIXMA Manuals MG2900 series Resolution
Resolution The data in the image you have scanned is a collection of dots carrying information about brightness and color. The density of these dots is called "resolution", and resolution will determine the amount of detail your image contains. The unit of resolution is dots per inch (dpi). Dpi is the number of dots per inch (2.5 cm). The higher the resolution (value), the more detail in your image; the lower the resolution (value), the less detail.
How to Set the Resolution You can set the resolution in Resolution on the (Scanning from a Computer) tab of the Settings dialog.
Appropriate Resolution Settings Set the resolution according to the use of the scanned image.
Item Type Use Color Mode Appropriate Resolution Color photo Copying
(Printing) Color 300 dpi Creating a postcard Color 300 dpi Saving to a computer Color 300 dpi Using on a website or attaching to e-mail Color 150 dpi Black and white photo Saving to a computer Grayscale 300 dpi Using on a website or attaching to e-mail Grayscale 150 dpi Text document (document or magazine) Copying Color, Grayscale, or Black and White 300 dpi Attaching to e-mail Color, Grayscale, or Black and White 150 dpi Scanning text using OCR Color or Grayscale 300 dpi Important
  • If you double the resolution, the data size of the scanned image quadruples. If the file is too large, the processing speed will slow down significantly, and you will experience inconvenience such as lack of memory. Set the minimum required resolution according to the use of the image.
Note
  • When you will be printing the scanned image by enlarging it, scan by setting a higher resolution than the recommended one above.
Oct 07, 2014 | Canon LASER SHOT LBP-2900 Printer
Slow save on pdf file with capture perfect3
Change the scan resolution to 200 dots per inch (200 dpi). If 300 it tajes a few seconds. If 1200 dpi, it may take really long.
Jul 29, 2014 | Canon DR-9080C Path-Through Scanner
My laser mfp 1815dn is reducing the size of the image of the document i am scanning. how do i get it back to scan and save a full page?
Welcome to Fixya!
Adjust the Scan setting to the defalult/appropriate resolution. See guidelines below.
Documents:
300 dpi black-and-white or 200 dpi grayscale or color
Documents of poor quality or that contain small text:
400 dpi black-and-white or 300 dpi grayscale
Photographs and pictures:
100-200 dpi color or 200 dpi grayscale
Thank you for using Fixya. Have a great day.
Jas247
Jul 12, 2011 | Dell Printers:Dell MFP Laser Printer...
How can I scan a document then print it with larger print?
You can scan a document or photo or negative film etc.. using a scanner, there a many types of scanners which you can choose as per your requirement. There are dedicated scanners, all in one integrated scanners, or two in one like that.. but if you need it for your professional use or daily use, it's better to get a dedicated scanner not "all in one" since with all in one if the copier fails or fax fails, the scanner will also fail because they are related and built-in integrated.
The process of scanning a document is as follows;
  • > Place the document on the scanner's flatbed.
  • > Press scan button or scan using the integrated software from the computer.
  • > Customize the scan settings/quality.
  • > Save the scanned documents.
Printing a document to a larger size is different, you can use photo editors like photoshop, paint.net etc..where you can changed the resolution as well as the size of the image. It's best to change the size or resolution before you give the print command. Or you can also change the print size with the paper size or print size.
If you still need more help, please let me know with more details. I am ready to assist you.
Good luck.
Thanks for using FixYa.
Jul 04, 2010 | Computers & Internet
Scanning files to large
It's the resolution you are using to scan. Try a lower setting. for documents, 150-200 dpi is fine. That will produce smaller files.
Aug 25, 2009 | Dell 922 All-In-One InkJet Printer
Scans from the Dell is quite large.
you can reduce picture size using any photo software best is photoshop, you may have microsoft picture viewer, and a lot of soft. Scaner may not let you less then 72dpi to get normal picture for print.
Aug 05, 2009 | Dell 968 All-In-One Printer
Need to get scanned photos to between 300 and 600 dpi
What I saw first off is that although the resolution indicates 96 DPI, the file size itself between the 2 examples are drastically different. You are putting raster images into MS Word for publication work, and that is a NO NO. Word was not created for any kind of high resolution printing. It's a glorified text editor that people seem to think is an option for printing. YOU WILL NEVER GET 300 or 600 DPI images out of Word. Ever.
To create your project for printing, you need to use software more suited for the task. InDesign and Quark are examples, but they are very expensive. In my opinion, Publisher would be better for this kind of project and I hate myself for saying that.
Talk to your Printer, find out his specifications for Applications and Linescreen for Printing. The minimum requirement is 280 DPI, but if the image is placed at 100%, 600 DPI is overkill.
Oh, and try to never scan a scan... you are looking for trouble... a little thing called a Moiré pattern comes into play, and it will make you images print NASTY!
I could go on about your post all day long, but if there is anything else I didn't explain, please post again.
Jan 21, 2009 | MGI Software PhotoSuite SE V4.0
Scan file from Lexmark 6100 is very large
If the documents you are scanning are black and white, make sure you are selecting that in the scanner dialogue box. If you need to keep gradiants, but don't need color, try selecting grayscale. If you are adjusting your DPI (dots per inch) to the maximum (300), try using something lower (recommend 150). Lastly, check the settings in the software you use to create PDFs to ensure they are the same as what you use at the office.
Dec 24, 2008 | Lexmark X6170 All-In-One InkJet Printer
Scanner Creates a Very LARGE PDF file 1.8 meg for one page
I have an old X7170 and have the same problem when using the doc feeder. I scan using the flatbed the size is much much smaller.
May 05, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark X8350 All-In-One InkJet Printer Logo
469 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
