Question about LG Washing Machines
What does the cide "LE" mean and how do I clear it?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Le is a locked motor error. The issue could be because the connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of stator assembly. Also it could be because the electric contact between the connectors (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main pwb assembly is bad or unstable. Also check if the motor harness between the stator assembly and main pwb assembly is cut (open circuited). If still the issue is not resolved then it is because the hall sensor is out of order/defective. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 03, 2010
What corrective action for an le code?
The le error code means the leakage sensor located in the middle of the base has detected water. Check asap to see if there is water leakage underneath the unit. The sensor must be dry in order for the error to be cleared. Usually, when these sensors are active, they will tell the main board which will not allow anything to run until the code is clear--for obvious reasons.
Aug 11, 2015 | Samsung Dishwashers
Nokia c1-02 sim lock restriction code
this restriction code dos'nt workt to my phone Nokiac1-02 IMEI357887046246384 SIM LOCK RESTRICTION CIDE TYPE RM-643 CODE 059G5L7 can anyone help me ?
Jul 13, 2012 | Nokia Cell Phones
How do you clear the le error code on a front loader so it will run?
Hi Wendy just read your posting.Unfortunately LE means the Hall sensor on your motor or motor is faulty. To clear the error code you need to either change the Hall sensor or motor.Most of the time the fault is the Hall sensor.Please reply for further help.Looking forward to your reply.
May 24, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Water still in machine says LE on display
LE error code means Locked Motor Error.
Sometimes this can be cleared by unplugging then plugging back in the machine. If this does not clear it you have a faulty component.
This usually failure of a component called the Hall Effect Sensor which may need to be replaced.
Dec 16, 2010 | LG WM-2277HW Front Load Washer
What does error code LE mean?
Here is a tip that explains what the LE error code means.....
LG Washing Machine LE Error Code or Fault Code
heatman101
Sep 20, 2010 | LG Washing Machines
I have a black screen mon my TI=83 that I cant make go away
Salut,
Chassez le naturel il revient au galop.
Si ton écran est noir, tu peux réduire le contrast.
Appuie sur la touche [2nd] puis libère-la.
Appuie sur la touche [Flèche vers le bas] et maintiens la pression jusqu'à ce que l'écran s'éclaircisse à ton goût.
Appuie sur la touche [CLEAR] pour effacer l'affichage.
Press [2nd] and release it.
Press and HOLD [DownArrow] till screen lightens enough.
Press [CLEAR] to clear the screen.
Hope it helps.
Oct 29, 2009 | Texas Instruments TI-83 Plus Silver...
Error code LE and OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged.
LE Code refers to a motor overload.Since the pump is blocked,the motor becomes inefficient in working.Once you get the pump cleared from blockages,I assure that you can get rid of these errors.Good luck with the machine.Please do post the results and comments.
Apr 12, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Lg wd-3243rhd front load washer and dryer combo "le" error message
LE error code means the motor sensor has failed.  The motor sensor is located in the back of unit inside the motor.  You will need to order a replacement motor sensor from LG.  You will need a 17 mm and 10 mm socket tools to do this job.
Mar 17, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Washing Machines Logo
18 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
