Question about Drills
When looking at a motor diagram, the shaft has ø12 ±0.03 --- Does that mean the diameter of the shaft is 12mm plus or minus 0.03 mm
    President:
  • 1,378 Answers
Exactly.
Posted on Feb 03, 2010
What is the wrench size i need to tighten handle bars on a jeep FT 4,0 boys bike
There are nuts or allen bolts for both the stem and the bars. They are almost certainly a metric size, but hard to say what unless one has the same bike. My guess would be a 12mm hex, plus or minus, or a 6mm allen, again plus or minus. Get a metric hex/allen set and see what fits.
Dec 30, 2016 | Jeep Cycling
How can I replace the motor in an Aerolatte?
The whisk shaft is glued to the motor shaft. I used needle nose pliers to pry whisk shaft away from motor shaft and it separated easily. Ordered D.C. Motor from china on ebay. 21 mm diameter case. 2mm shaft width. Motor was .99 cents freight prepaid from china to USA.
Feb 15, 2016 | Aerolatte Original Steam Free Milk Frother...
I have earrings that are 12mm
13mm is approx equivalent to 1/2 inch. 12 mm could pass as 1/2 depending on if it's inside or outside measurements.
Feb 06, 2015 | Clothing Accessories
I need a new SHENG BANG HD-1688 AA VOLT BATTERY MOVEMENT
Check on Amazon or Madeinchina .com, Tradetang may be a good place too
Nov 11, 2014 | Watches
Isuzu rodeo 1996 3.2L V6. Torque specs for alternator pivot bolt 14 mm and lock bolt 12mm. torque for AC idler pulley lok nut 23 mm
Isuzu does not list specific torque values for these fasteners. When this is the case, you are expected to use standard torque values. These can be found on the chart I have linked below. Be advised that bolt sizes go by the diameter of the shaft [round shaft portion] of the bolt or stud, NOT the hex head [socket size] of the bolt or nut. Partially remove the bolts so that you can measure the shaft and obtain the correct torque from the chart. See
https://www.swtc.edu/ag_power/diesel_engines/lecture/metric%20torque%20values.pdf
Sep 26, 2014 | 1996 Isuzu Rodeo
What size are the starter bolts on a 2002 dodge stratus. i broke one and it seems longer than the other
You mean metric diameter & thread pitch?
You will have to mic the diameter & convert
to metric or just match up at a store
As a guess only--dia may be 1/2 "or 12mm & length say
2" or 50mm
.0395 is (1) mm
Whatever you measure dia or length wise, you
divide by .0395 to go to metric
They heat treated bolts,not a Home Depot
chinese item
Aug 13, 2014 | 2002 Dodge Stratus
Diameter is 1,88mm and thickness is 20mm. what is the mean diameter?.
It the diameter of a circular object is 1,88 mm then the mean diameter is also 1,88 mm. The thickness is irrelevant.
Sep 18, 2013 | Cameras
What is the clearance for rod bearings on the crank of a 98 ford f 150 4.6
General Specifications Item Specification
Displacement L (CID) 4.6 (281)
Number of Cylinders 8
Bore and Stroke mm 90.2 x 90.0
Firing Order 1-3-7-2-6-5-4-8
Oil Pressure (HOT @ 1500 rpm) kPa 138-310
Drive Belt Tension a
Cylinder Head and Valve Train
Combustion Chamber Volume cm 52?±.5
Valve Seats Width?€"Intake mm 1.9-2.1
Valve Seats Width?€"Exhaust mm 1.9-2.1
Valve Seats Angle 44.51-45.01 degrees
Valve Seats Runout (T.I.R.) Max mm 0.025
Valve Arrangement (Front-to-Rear) (Left Hand) E-I-E-I-E-I-E-I
(Right Hand)
I-E-I-E-I-E-I-E
Valve Stem to Guide Clearance?€"Intake mm (Inch) 0.020-0.069
(0.00078-0.00272)
Valve Stem to Guide Clearance?€"Exhaust mm (Inch) 0.045-0.095 (0.0018-0.0037)
Valve Head Diameter?€"Intake mm (Inch) 44.5- (1.75)
Valve Head Diameter?€"Exhaust mm (Inch) 34.0 (1.34)
Valve Head Diameter?€"Gauge Diameters mm (Inch) 42.5- and 32.0
(1.67 and 1.26)
Valve Face Runout Limit mm (Inch) 0.05 (0.002)
Valve Face Angle 45.25-45.75 degrees
Valve Stem Diameter (STD)
?€"Intake mm (Inch) 6.995-6.975 (0.275-0.2746)
Valve Stem Diameter (Std)
?€"Exhaust mm (Inch) 6.970-6.949 (0.274-0.2736)
Valve Springs?€"
Compression Pressure N @
Spec. Length?€"Intake 587.14 N @ 28.02 mm
Valve Springs?€"
Spec. Length?€"Exhaust 587.14 N @
28.02 mm
Valve Springs?€"Free
Length ( Approximate)?€"
Intake mm (Inch) 49.55 (1.951)
Length (Approximate)?€"
Exhaust mm (Inch) 49.55 (1.951)
Valve Springs?€"Installed
Pressure N @ Spec. Length
?€"Intake 244.64 N @ 40.0 mm
Valve Spring?€"Installed
?€"Exhaust 244.64 N @ 40.0 mm
?€"Service Limit 10 % Pressure Less @ 28.02 mm
?€"Out of Square Limit 2 degrees
Valve Guide Inner
Diameter mm (Inch) 7.015-7.044 (0.2761-0.2773)
Rocker Arm?€"Ratio 1.75:1
Valve Tappet?€"Diameter
(STD) mm (Inch) 16.000-15.988 (0.66-0.629)
Valve Tappet?€"Clearance
to Bore mm (Inch) 0.018-0.069
(0.00071-0.00272)
Valve Tappet?€"Service
Limit mm (Inch) 0.016 (0.00063)
Valve Tappet?€"Hydraulic
Leakdown Rate b 5-25 seconds
Valve Tappet?€"Collapsed
Valve Tappet Gap?€"
Desired mm (Inch) 0.085-0.45 (0.0033-0.0177)
Camshaft
Lobe Lift?€"Intake
mm (Inch) 6.58939 (0.2594)
Lobe Lift?€"Exhaust
Lobe Lift?€"Allowable
Lobe Lift Loss mm (Inch) 0 (0)
Theoretical Valve Lift @
Zero Lash?€"Intake
mm (Inch) 12.0 (0.472)
Zero Lash?€"Exhaust
End Play mm (Inch) 0.025-0.165
(0.00098-0.0065)
Journal to Bearing
Clearance mm (Inch) 0.025-0.076
(0.00098-0.003
Journal to Bearing
Clearance?€"Service Limit
mm (Inch) 0.021 (0.0048)
Journal Diameter (All)
mm (Inch) 26.962-26.936
(1.061-1.060)
Journal Diameter (All)?€"
Bearing Inside Diameter
(All) mm (Inch) 27.012-26.987
(1.063-1.0625)
Camshaft Runout
Cylinder Bore
Diameter?€"Surface Finish
(RMS) 0.2-0.6 Microns
Diameter?€"Out-of-Round
Limit mm (Inch) 0.015 (0.0006)
Service Limit mm (Inch) 0.020 (0.00079)
Diameter?€"Taper Service
Limit mm (Inch) 0.006 (0.00023)
Piston
Piston?€"Diameter?€"
Coded Red 1 mm (Inch) 90.177-90.197
(3.550-3.551)
Coded Blue 2 mm (Inch) 90.190-90.210
(3.5507-3.5515)
Coded Yellow 3 mm (Inch) 90.203-90.223
(3.513-3.5521)
Piston-to-Bore-Clearance
mm (Inch) -0.015 + 0.031 (0.0005-0.0012)
Pin Bore Diameter
mm (Inch) 22.0015-22.004
(0.866-0.8663)
Ring Groove Width?€"
Compression (Top)
mm (Inch) 1.520-1.550 (0.06-0.610)
Compression (Bottom)
mm (Inch) 1.520-1.530 (0.060-0.0602)
Ring Groove Width?€"Oil
Ring mm (Inch) 6.996-7.224 (0.275-0.2844)
Piston Pin?€"Length
mm (Inch) 61.93-62.05 (2.44-2.443)
Diameter mm (Inch) 21.994-21.999
(0.866-0.8661)
Pin to Piston Clearance
mm (Inch) 0.005-0.010
(0.0002-0.0004)
Pin to Rod Clearance
mm (Inch) 0.015-0.040
(0.0006-0.00157)
Piston Rings?€"Ring Gap
?€"Compression (Top)
mm (Inch) 1.0 MAX (0.0394)
Oil Ring?€"Side Clearance
mm (Inch) 1.25 MAX (0.05)
Oil Ring?€"Compression
(Top) mm (Inch) 0.040-0.090
(0.0016-0.0031)
(Top) mm (Inch) 0.030-0.080
(0.0012-0.00031)
Oil Ring Snug Fit
Oil Ring?€"Service Limit
mm (Inch) 0.015 MAX (0.0006)
Ring Gap?€"Compression
(Top) mm (Inch) 0.23-0.49
(0.01-0.02)
(Bottom) mm (Inch) 0.23-0.49
(0.01-0.02)
Ring Gap?€"Oil Ring (Steel
Rail) mm (Inch) 0.05-0.66 (0.006-0.026)
Lubrication System
Oil Capacity?€"Automatic
Transmission (Quarts U.S.) 6.675?±0.125
Oil Capacity?€"Manual
Transmission (Quarts U.S.) 6.425?±0.125
Cylinder Block
Main Bearing Bore
Diameter mm (Inch) 72.401-72.422 (2.85-2.851)
Crankshaft and Flywheel
Main Bearing Journal
Diameter mm (Inch) 67.483-67-503 (2.65-2.657)
Connecting Rod Journal?€"
Diameter mm (Inch) 52.988-53.003
(2.0861-2.0867)
Crankshaft Free End Play
mm (Inch) 0.130-0.301 (0.0051-0.012)
Crankshaft Runout to Rear
Face of Block mm (Inch) 0.050 MAX (0.002)
Connecting Rod Bearings
Clearance to Crankshaft?€"
Desired mm (Inch) 0.027-0.069 (0.001-0.0027)
Allowable mm (Inch) 0.027-0/069 (0.001-0.0027)
Bearing Wall Thickness
(STD) mm (Inch) 2.44-2.452 (0.096-0.0965)
Main Bearings
Desired mm (Inch) 0027-0.065
(0.0011-0.0026)
Allowable mm (Inch) 0.027-0.065
(0.0011-0.0026)
(STD) mm (Inch) 1.920-1.928 (0.075-0.076)
Connecting Rod, Piston and Rings
Connecting Rod?€"Piston
Pin Bore Diameter
mm (Inch) 21.959-21.979
(0.864-0.865)
Connecting Rod?€"
Crankshaft Bearing Bore
Diameter mm (Inch) 56.756-56.876 (2.234-2.24)
Connecting Rod?€"Length
(Center-to-Center)
mm (Inch) 150.7 (5.93)
Alignment (Bore-to-Bore
Max. Diff.) c ?€"Twist
mm (Inch) 0.050 per 25 (0.0015-0.984)
Max. Diff.)?€"Bend
mm (Inch) 0.038 per 25 (0.0015-0.984)
Side Clearance (Assembled
to Crank)?€"Standard
mm (Inch) 0.015-0.45 (0.0006-0.0177)
to Crank)?€"Service Limit
mm (Inch) 0.05 MAX (0.02)
Crankshaft Main Bearing
Journal Taper mm (Inch) 0.020 (0.0007)
Journal Runout mm (Inch) 0.05 (0.002)
Crankshaft Connecting Rod
Journal Taper mm (Inch) 0.015 (0.0006)
Feb 15, 2011 | 1998 Ford F150 Regular Cab
I just purchased a factory serviced model TR-520 bread maker and the paddle provided does not fit the drive shaft. The drive shaft is about 1 cm diameter, and the hole in the paddle is only about 8 mm...
Satisfaction Guaranteed on all orders:
We are happy to fully refund purchases if an error has occurred in your order or if an item you ordered is defective. If you aren't happy with the product you received or are dissatisfied for any reason simply return the item within seven days for a full refund minus a 15% restocking fee. Please call us or email us within seven days of receiving your order for information on where to ship items that need to be returned. Do not return them to our P.O. Box.
The returned product must be in new and unused condition, in the original box with all the documentation, parts and accessories to insure full credit. "New and unused" means sale-able condition, not dirty and not washed. We cannot accept returns for an item with any indications that it has been used.
Return shipping costs are your responsibility unless the item is damaged or defective. If you have any questions about the restocking fee as it pertains to your order please call us before we ship the product as once it leaves the warehouse we have incurred our cost.Fax Number: 1-866-323-8256
sales@bread-maker.net
http://www.bread-maker.net/contact-us.aspx
Dec 29, 2009 | Breadman TR520 Bread Maker
2001 Toyota 4runner Limited Alternator belt broke.
simple really 12mm wrench an socket and 14 mm wrench an socket. lossen alt bracket 14mm then tesioner 12mm slide back drop belt and reverse. unless condensioner belt in way then dro 12 mm bolts on shiled then back off 12mm bolts on condensioner pulley remove belt follow previous instructions
Nov 22, 2009 | 2001 Toyota 4Runner
Drills Logo
98 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
