My printer is not printing. It is blank. I replaced the cartridges and that is not the problem. Please Help.
  • mmetrick Feb 03, 2010
    what is the cleansing process. I just bought the cartridge
    from staples. It never said to replace it. I just did it because
    it was running out of ink.
    Mary-Ann
    I'm waiting for a response. How do you do a cleansing of the cartridge?
    President:
  • 1,335 Answers
The nozzle cleaning utility is usually found in the Maintenance area of the printer Properties. I assume you are using Windows so go to Start>Control Panel>Printers>(select your printer icon)>Properties>Maintenance>select (deep nozzle cleaning) at least 3x, If the nozzles are clogged, this should clear the problem.
The other problem may be that the cartridges that you bought at Staples may not be up to specifications for your printer. If the printer was printing fine before you replaced the cartridges, I would suspect the replacement cartridges. If they are aftermarket or reloaded cartridges I would try using new OEM cartridges.
Let me know if your problem goes away after trying either of the above solutions. Thanks.
Posted on Feb 04, 2010
  • 341 Answers
I suggest running the cartridge cleaning process. Sometimes you have to do it 3 or 4 times depending on what brand printer you own. If after you run the cleaning process a few time and nothing improves, I would say that you have a bad cartridge. Especially if you purchased an off brand ( like office depot or staples) If you are using factory cartridges, chances are, but not 100%,that it is not the cartridge. Also depending on how empty you got your old cartridge. If you ran it completely dry until it was no longer printing, then definitely, run the cartridge cleaning process a few time and don't give up, it should work and if it doesn't, don't hesitate to return the new cartridge you recently purchased. Good Luck
Posted on Feb 03, 2010
My hp 1010 prints only the first page. but from the second page it gives blank print. please help
shake the cartridge well and put it back & check, replace with another cartridge, check half test page if no print on paper check on image on cartridge drum( while printings approx half page open the door remove cartridge & paper check print on paper,on cartridge drum) check transfer roller & replace
If no image any ware replace "Power supply PCA"..
Sep 10, 2011 | HP LaserJet 1010 Printer
When i try to print a document, only the top line or two is printed, rest of page is blank, please can you help
According to your problem you can't print properly with your printer.
First check your printer cartridge is not blank. If any cartridge is blank then it may happens.
clear the cartridge head.
Cartridge may need alignment. Go to the printer preferences and select the Ink cartridge alignment.
You can reinstall the driver also.
Use dry and proper size of paper which is supported by the printer.
Feb 02, 2011 | HP Photosmart 3310 Printer
My hpf44880 printer prints out blank sheets of paper what do I need to do to get it to print with ink on the paper?
please follow these steps:
1.please print a test page from printer(hold down power and cancel(red X)buttons for 3 seconds together and release both of them..it will print a test page
2.if it is blank :please take out the cartridges.
clean the metallic contacts with lint free cloth
clean the ink cartridge slots with a cutip
disconnect usb cable
unplug the power cable from the back keeping cartridges out
hold down power key for 30 seconds
reconnect power cable
reinstall the cartridges
3.print a test page again from printer if printer is quiet
4.if the test page is still blank..u need another set of cartridges
5.if test page isn't blank and u print blank pages from computer,do the following:
6.if printer s/w is already installed..please go to devices and printers(printers and faxes in win xp)
7.please click on add a printer
8.select driver manufacturer as HP,and driver as deskjet 990c(this is the generic driver for all HP printers)
9.follow the onscreen instructions,and finish installation
10.try printing with this driver
Jan 24, 2011 | HP F4480 All-In-One Printer
HP 2840 Prints Blank Pages
Black is used on all prints. Did you pull the tape on the new cartridge?
Jan 13, 2009 | HP LaserJet 2840 All-In-One Printer
Please help me, my epson inkjet all in one printing just blank blank blank
Epson printers will not accept continuous ink cartridges. That is why you are getting blank pages. I recommend just buying the ink cartridge as you need them.
Good Luck
Jan 05, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Dell A960 printing blank pages
I just sprayed windex on bottom of cartridge several times and wiped with paper towel until dark streak of black appeared. Then I dried off cartridge and replaced. It works now. Must have been clogged.
Nov 18, 2008 | Dell A960 All-In-One InkJet Printer
Printer says printing but no print out.
all my cartridges are full/newly changed. my epson stylus cx5200 keeps on feeding papers, displaying printing message but with no actual print out i.e. blank paper comes out. please help. thanks!!
Darren.
darren.lee54@yahoo.co.uk
Oct 06, 2008 | Epson Stylus CX5200 All-In-One InkJet...
Printing inkless printing
Gecko17 How old is your cartridge? is there is enought ink to print your document? If so then... Take out the cartridge carefully from your printer without touching any contact points, heads etc. Clean the head's of your printer cartridge carefully by using head cleaner fluid. After that, reinstall your cartrige and please try to print again. If this deosn't solve your problems, you may need to replace your cartridge with new one. thanks
Aug 30, 2007 | Lexmark Z600 InkJet Printer
Printing blank pages
My printer has funn ink cartridges and it is printing blank pages and it is saying that the ink is empty. Please help
Feb 27, 2007 | Brother MFC 4420C All-In-One InkJet...
16 people viewed this question
k24674
