Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Gunky slim in rubber gasket on front door. terrible odor also
Use once a month the clean tub cycle and add 1/2 cup of clorox, you will never have that problem.
Posted on Feb 14, 2010
  • 129 Answers
That is mold bleach water hand wash rinse with water . afresh cleaner several times then monthly
Posted on Feb 04, 2010
We have a terrible odor from fridge side. Cleaned it 3 times..found nothing and odor persists Any suggestion? No odors when doors are closed
What does it smell like? Burnt plastic , mold , rotten food? Check gaskets and temp in fridge, food could be spoiling. It is tough to get serious odors out of fridges. Bleach, vinegar are good for killing odors. Check manufactures recommendations.
Apr 14, 2011 | Viking 42 in Built In Professional...
Smelly gasket even tho i wipe dry and leave door open
try using Baking Powder to neutralise the odor. Maytag had a similar problem once. their gasket(door boot) was gray in color and reacted with some kind of bacteria then they change it to a black rubber compound and the problem went away.
Feb 08, 2011 | Samsung WF203ANW Front Load Washer
Mold remain in rubber rim of washer
Hi Qqiustin.There are couple of solution for this,you can try that before attempt to change door gasket.1- Run machine empty on Cotton 95C cycle,while it's intaking water add 300ml of bleach.(It could produce some foam but let it go & finish it's cycle)That progress will clean your machine & mould on the door gasket should get disappeared.Alternatively you can try EXIT MOULD or likely products on the super market sells.Follow the instruction.Goodluck.Thanks.
Aug 02, 2010 | Miele W1926A Front Load Washer
Bad smell when starting a new load the next day
These are some good tips. However, leaving the door open between loads decreases odor by drying out the residue which can make the residue difficult to remove. Also, the residue will affect the next wash load.
The only way to have a truly clean washer is to remove the odor-causing residue. The "splash area" just 3-5 inches above the normal waterline is where the worst buildup is. To clean the whole tub use a washer cleaner that is able to be used with clothing in the washer. The added laundry will raise the water level to include the splash area.
There are many washer cleaners on the market. Some are all natural and can be used with laundry to safely clean inside the washing machine. After you get rid of odor you'll need to change your washing habits so it doesn't come back.
Apr 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Very unpleasant odor in LG front-loading washing machine.
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@@!!
Jan 27, 2010 | LG WM-2277HW Front Load Washer
The odor is terrible. Running the recommended
The filter is actually the drain pump trap. The following link explains how to access and clean the drain pump:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
You also may have to remove the drain hose that runs from the bottom of the wash tub to the inlet side of the drain pump to ensure it is free of debris as well. Small articles of clothing can commonly get lodged in this area and sour.
Make sure you also check the door bellow (gray rubber door seal) to ensure there is nothing caught in the rubber folds of the seal. Pull the rubber back and check the entire perimeter of the door. It is common for small items such as socks to get stuck in this area. If left for any significant period of time, they begin to sour and mildew. It is recommended that you check this area after each wash. I once found 17 socks stuck in the door seal that the owner did not know was there. They had been there for months. You can imagine what the odor was like at that point.
Last of all, leave the door open between washes to allow the wash tub to air out. Due to the water tight and air tight nature of these door seals, when closed no air can escape the tub and any residual water that remains in the drain lines will sour.
If you have any questions, please let me know. I hope this help you.
Nov 26, 2009 | Kenmore Elite 45986 Front Load Washer
Terrible odor from rubber seal around door. Don't know how to remove seal
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Oct 14, 2009 | GE WSXH208A Front Load Washer
Problems with mildew around the rubber and terrible odor to the laundry after washing. Also, hear water sloshing when turn the drum by hand.
Oct 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Mold in rubber ring front loader Fridgidare washer
Common problem. Clean the moulding as best you can, even scour with steel wool. Leave the door open so the machine will be dry when not in use or/and wipe the rubber after each use. You can try to cover up the odour by wiping with a rag moistened with vanilla essence. Otherwise fit a new rubber and keep it dry in future.
Jul 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Mildew on rubber gasket around door.
This happens when you keep the door shut. Run an empty load with extra chlorine bleach to kill the mold spores. Keep the door open to prevent mold or mildew from growing again.
Mar 18, 2009 | LG WM-2277HW Front Load Washer
Washing Machines Logo
149 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
