Question about Schiller Medical
My machine turned on in my bag. Paper rolled around the wheel and jammed. The machine goes on, it will print the waves in manual setting, but it does not show the leads. It will not print in Auto at all.
    Problem Solver:
  • 14 Answers
Either the paper sensor is not working properly or you are using the wromg paper.  Thier should be a black mark on the top left corner of each page.   You can get the correct EKG Paper here http://www.medicaldevicedepot.com/Schiller-AT-2-EKG-paper-p/2157-017a.htm
Posted on Feb 21, 2010
Testimonial: "Thank you so much for your answer. This occurred about 3 wks ago, I already recv'd help, the problem was resolved. The paper was in wrong. "
How to change paper
This product uses 2 1/4in (57/58mm) wide standard thermal paper. Use the feed keys only when changing the paper. Do not pull the paper manually.
1. If prompted during use, or when setting up the printer for the first time, open the printer compartment by lifting up on the tabs located toward the back of the register. This will expose the printers.
2. Depending on each sides needs, use the release buttons to open the paper wells and release the print rollers.
3. Place the paper rolls into the paper well so it feeds from the bottom of the roll towards the front of the cash register (not the back). Pull the paper up and past the print heads towards the front of the cash register.
4. Once done, close the printer arms and use the feed keys to advance the paper.
5. To attach the journal roll to the back of the winding wheel, remove the wheel from the comparment. Put a small fold in the end of the journal roll and feed it under and around the tabs located on the wheel. Spin the wheel manually to take up paper slack.
6. Once the paper is attached, place the wheel into the holder in the back of the printer compartment. The part of the winding wheel with two discs should be on the right side.
Dec 23, 2015 | Royal 29445B Alpha 9500ML Cash Register
Clear paper jam pcr t2000
It\'s very unusual for the paper to jam as this machine uses a clam shell type of printer. Just raise the printer arm and remove the paper roll. Clear any paper from the print head and roller etc. Tear any wrinkled paper from the roll and then refit the roll with the shiny side of the paper towards you. Lay the paper in the printer and close the printer arm down onto the paper. If you are setting the journal side, wind some paper onto the takeup spool after it exits the printer and sit the spool into place.
If anyone needs a Casio PCR-T2000 manual, one of the users has it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-T2000_users_and_programming_manual.html
Jul 08, 2014 | Casio Parts Cash Register PC Desktop
Flashing paper and power buttons
This error means jammed paper or a foreign object is blocking print head movement. Turn off the printer, press the adjust lever down to the lowest position, and pull out the jammed paper. Open the cover and remove any jammed or torn paper, or foreign objects. Then do one of the following:
Sheet Feeder: Return the adjust lever to the position. Turn on the printer, reload paper, and press the paper button.
Manual Feed Slot: See page 15 of your manual for loading instructions.
Roll Paper: Cut off the printed portion with scissors, then remove and reload the roll paper
Mar 08, 2014 | Unknown Epson Stylus Photo R2000 Ink Jet...
Two IR2270 is converted to IR3570, problem is when duplex printing, paper is getting rolled on the exit tray. During simplex printing paper is not getting rolled but it is wavery. Very rarely paper jam...
You may have a damp paper issue, when damp paper passes through the hot element it curls or crinkles the paper resulting in paper jams and poor output , if you turn all you paper round in the paper trays to A4R it will help, or use dry paper, recycled paper is the worst as it collects moisture much quicker, especially left over night
Oct 10, 2013 | Canon Office Equipment & Supplies
Problem Description: no attempt to put paper thru printer, if it feeds it jams. Panasonic UB-5315
Hi, usually it is only a matter of removing the paper and turning it around prior to printing- but only at the start of each session. There may be a small piece of paper jammed in the paper throat area. You may be able to just see it if you open the paper draw or the plastic film area. You can access the latter area by sliding the tag downwards on the RHS of the printer. The piece of paper will be right at the bottom. Occasionally there is a full piece rolled up in the shoot that you can see above the film. You may have to remove the film rolls to access this. Make sure you look at which roll goes where before you remove them.- Ross
Apr 27, 2011 | Panasonic Panaboard UB-5315
Paper jam
NEED TO FAN THE PAPER AND ROLL THE PAPER THAN SURF IT LIKE IT IS ON WAVES OF WATER,
STRAIGHTING OUT PAPER
MAY NEED TO TRY DIFFERENT TYPE OR BRAND OF PAPER.
THERE IS A PROGRAM THAT MAY HELP YOU WITH THIS PROBLEM IT IS CALL
GREENPRINT WORLD DOWNLOAD
ENTER
ROD
Jan 30, 2009 | Canon i850 InkJet Photo Printer
Epson cx11nf paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Epson ACULASER CX11NF All-In-One Printer
HP 1320 duplex printing paper jam
Managed to solve this myself: I disassembled the printer and noticed there was a paper jammed in the duplex tray. Rolls were all ok, but the paper blocked the use of the duplex pathway. For disassembly help check the HP 1320 service manual, which you can find on the net as a PDF.
Jul 14, 2008 | HP LaserJet 1320 Printer
Paper jam at the Transfer Roll
Place a few papers in the tray.
Open up the top, pull out the main (green handle) thingy.
In the very bottom you will see a bar with a single large round rubber wheel in the middle, and white gears on both ends of the bar.
Manually turn the right side gear toward you.
As you do this, you will see the paper lift up and as the rubber wheel turns you will see that it has a notch on the bottom side.
Turn the gear, and watch the rubber wheel until the notch on the rubber wheel is facing up and away from you (and the paper is fully engaged).
Then put the green-handle thingy back in, close the printer, and it should work.
Apparently this resets something.  I have done it a number of times - usually after a paper jam.
Apr 10, 2007 | Konica Minolta magicolor 2400 Laser...
Medical Logo
165 people viewed this question
Top Schiller Medical Experts
Electro Med Services...
Are you a Schiller Medical Expert? Answer questions, earn points and help others
