Question about Craftsman 10" Table Saw
1975 vintage Craftsman 10" table saw motor will kick circuit breaker out after about 5 to 10 mins just free running with no load, cutting nothing. Is motor worn out? Can't find manual so to know if need order replacement motor?
    Brigadier General:
  • 4,090 Answers
Feel the outer case of the motor to detect how hot it has become. I would suggest the windings are shorting out and causing it to overheat. The safety detection part is preventing it from catching fire. I would be replacing the motor if it was mine
Thanks for using FIXYA
Posted on Feb 03, 2010
Ryobi 10 inch table saw trips breaker when he turns onRyobi 10 inch table saw trips breaker when you can it on
First of all the saw needs to be plugged in directly to a outlet . NO Extension CORD !!! If it is Right , then Check on the motor label and see how many AMPS the motor is ? You need to then check the Breaker box and make sure the breaker is big enough to handle the load of the motor on the saw . You may have to make sure that the saw is the only thing on that breaker . NO Refrigerator , A/C , ECT.
Also make sure that the motor is clean and not packed full of saw dust . This can over heat the motor and kick off circuit breaker fast .
Good Luck , Hope This Helps !!!!!!!!!!!!!!
Aug 22, 2014 | Saws
10yr old table saw smells hot and trips breaker
Maybe, but first rule out several other things. Has the saw been recently overloaded - heavy cuts with a dull blade? You may have a partially burnt-out motor (which means the insulation on the wire in the windings has partially melted.) Has it been used recently or used now with an extension cord or to an outlet wired with 15 ga wire? Is the saw arbor hard to turn by hand (with the belt removed)? Does the motor overheat with no load (remove the belt and let it run for 10 minutes)? Try running the saw with the belt on, but not cutting for 10 minutes.
Dec 10, 2012 | Craftsman 10" Table Saw
My 10 in. Craftsman table saw is blowing the house circuit breaker
If it was the bearings you would probably hear a change in the sound of the saw before a significant amount of drag would cause this problem. If you are using the same outlet and the same cords as when you did not have this problem, then something has deteriorated. Is the blade sharp? Has the cord become compromised - either the wire itself or the plug? (The stranded wire in the cord could be hanging on by a few remaining strands.) Does the plug fit nice and tight in the outlet? Perhaps the motor has overheated and has partially shorted out some of the windings. On the other hand, if you have changed extension cords, perhaps the cord is too light or long.
Jul 09, 2012 | Craftsman 10" Table Saw
Saw reset button keeps kicking after only a few minutes of use. Could the dust collection bag be creating a heat problem?
I would not think so, the reset is for thermal protection and I think that you have a problem with the motor stalling or under a heavy load. I would check to see how free the motor spins with being on. UNPLUG TOOL FIRST and turn blade by hand. Then to eliminate the dust bag remove it and just run the saw without cutting. Look into the throat plate area for a build up of debris that might be limiting movement.
Jul 23, 2011 | Craftsman 10" Table Saw
Trying to cut any size piece of wood the saw blows the circuit breaker at the panel 1x4 piece
Are you operating the saw on a 10 amp circuit or with a long extension cord? Table saws need at least a 15 amp circuit and should not be used with an extension cord. If absolutely necessary the extension cord should be no less than 12 guage. Tabel saws will run OK on a 10 amp circuit but as soon as you apply a load (try to cut wood) the power requirements go up to keep the saw turning. If you can, plug it into another outlet on a higher capacity circuit breaker or at least closer to the breaker box. If it still pops the breaker you may have bearing problems in the motor that are creating too much friction. This would make the motor work harder to turn so it would draw excessive power and trip the breaker.
Apr 13, 2011 | Craftsman 10" Table Saw
My very old Craftsman 10" Table Saw does not power on. While rip cutting some plywood, I errored and caused the blade to bind. Before I was able to power off the saw, the motor stopped. I thought I had...
Go to searspartsdirect.com and put in your model number. Look at the motor and wiring section. Look at item 16. The motor overload protector. (probably your reset button) WIth saw unplugged, unwire one sid of this switch and test with an ohm meter. You should read through the switch. If it is open then that's why the saw doesn't work. Many of this type of oveload requires quite a push to reset as you're flexing a klixon disc back to make contact. If is open and you can't reset, it's available there although a bit high priced.
Aug 13, 2010 | Craftsman 10" Table Saw
20 amp Circuit breaker trips everytime I flip the motor switch on. Its a craftsman table saw motor 1HP Model 113-12070., 14/7 amps
I assume that you are using the motor on 115 volt service. Remove the drive belt and check for excess friction in either the saw arbor bearings or the motor bearings. If both seem free to turn, then suspect that the start capacitor on the motor has failed. They usually become open circuited which prevents the start rotation. It will just sit there and hum loudly until the breaker pops. You may also have a defective 20 amp breaker--you will need a clamp-on AC ammeter to verify. Suggest that you run the saw on 230 volt service when you get it running. You will be amazed at the acceleration and apparent power available. My table and radial arm saws are both set for 230 volt operation and love it. Go to: Searspartsdirect.com and enter the complete model number minus the decimal point. This will take you to a series of drawings that list all replaceable parts. Hope this helps!
Jun 27, 2010 | Craftsman 10" Table Saw
I HAVE A CRAFTSMAN MODEL # 137.218041,, 10" TABLE SAW. WAS RUNNING FINE, BUT WHILE CUTTING 2X4'S FOR FURRING THE SAW MOTOR STARTED SMOKING AND THEN QUIT. IT ALSO TRIPPED THE CIRCUIT BREAKER. I RESET THE...
Sounds like you may have overheated the motor. I'm surprised the overload on the motor didn't trip first. With this overheating, the windings in the motor have basically shorted out to ground. This is why your breaker is tripping. Rewinding the motor is no longer the option these days. You can try going online to www.searspartsdirect.com
May 15, 2010 | Craftsman 10" Table Saw
Craftsman 10" Table Saw Logo
51 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
