Question about E-Machines eMachines Desktop PC
My windows dont start sometimes,and i wonder if i restore my computer will this fix the problem? My computer will just be on the black screen sometimes forever
    Problem Solver:
  • 18 Answers
Sounds to me like its some software based issue causing the problems. Restoring your computer is likely to resolve the problem, but however your docs, data and installed software may be removed as you would be restoring to factory setting basically, unless you are restoring to a recent backup which would be fine. You could try a system restore from windows, if you can't get into windows when you power up your system, keep on tapping the F8 key after the initial BIOS boot up, and you will be presented with a list of options select safe mode, windows should boot up.. once into windows usually it's goto Start Menu -> Accessories -> System Tools -> System Restore, select this and read through you can restore the system to a previous state, select a date that you had no problems with the PC, then follow the instructions... this way you won't lose personal data like documents and pictures etc... but maybe software that has been installed. If you can't get into safe mode then, let me know.
Posted on Feb 03, 2010
    Problem Solver:
  • 8 Answers
You might have bugs, or your hard drive might be messed up.
Kdcom.dll status 0xc0000221
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a serviceyou can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly.This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
if this hails to fix the problem
http://support.microsoft.com/kb/307545/
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
Select safe mode with networking to download
you could select the option start with command prompt you should be in DOS mode black screen
typechkdsk/r/f which will scan for and attempt recovery any bad sectors and automatically fix any corrupt files on your hard drive
you should have no input while chkdsk utility is in progress any input might further damage your hard drive
or you could use another operating system
http://www.ubuntu.com/download/ubuntu/download
which can repair what windows has ruined and is unable to fix fix the problem
Feb 20, 2014 | Acer Aspire One Netbook
Computer Problem
What sort of a problem ??
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
type chkdsk/r/f which will scan for and attempt recovery any bad sectors and automatically fix any corrupt files on your hard drive
Sep 06, 2013 | Computers & Internet
Acer
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. if this hails to fix the problem http://support.microsoft.com/kb/307545/ restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice Select safe mode with networking to download you could select the option start with command prompt you should be in DOS mode black screen type chkdsk/r/f which will scan for and attempt recovery any bad sectors and automatically fix any corrupt files on your hard drive you should have no input while chkdsk utility is in progress any input might further damage your hard drive
Apr 06, 2013 | Acer Aspire One Zg5
My HP laptop tries to start up but freezes on the "microsoft Corporation" screen with the green loading bar. I tried to do a System restore, but it wont acknowledge any recent restore points at...
Freezing at the "Microsoft Corporation" screen is normally caused by Windows updates. Since System Restore did not work for you, you can also try to disable unimportant services and start-up items. Usually this kind of problem ends up to reinstalling the operating system.
But you are lucky if reinstalling the operating system would fix the issue. Sometimes you'll end up wondering what to do because you'll end up with the same screen after the computer reboots itself from the long process.
With this kind of issue, I suggest you to try to run a hard drive diagnostic tool or try to use a good known harddrive.
Hope this helps.
Jun 03, 2011 | HP Pavilion dv6000t Notebook
My laptop came on but my screen is black. I can hear my coputer on but my screen is staying black.
Here are some discrete steps you shall also take besides fixing your Windows 7 registry which is inevitable for safer and stable computing:
* Conduct an antivirus and antimalware scan. Fixing for malwares after a registry scan gives an extra protection to the PC and saves PCs from lots of dangerous infections.
* Start Windows 7 in safe mode and restore your PC/system to the previous date after which you received the Windows 7 updates. It is believed that some updates may be behind these screen issues in Windows 7.
* Adjust your display settings since the wrong settings may also cause the Windows 7 black screen also called the blank screen. You can do this by starting Windows in safe mode.
Follow all the guidelines and start from registry repairing scan for Windows 7 to fix Windows 7 black screen.use registry cleaner reg in out to solve the issue
Sep 13, 2010 | HP Pavilion dv6000z Notebook
Laptop is working fine until the screen goes black
The problem of black screen can also happen in other versions of the Windows. However, the symptoms and effects of the problems in all operating systems are almost same. For instance, when a user starts his Windows, everything goes fine. But when he logs into it there awaits a black screen instead of the normal desktop layout. An average computer user finds it very disturbing and has no clue how to fix Windows 7.
However, the best way to find a solution to this problem is to fix the registry errors in your computer which become the cause of all major Windows errors and crashes. The registry in Windows 7 is a very important component of the entire operating system and it stores information about the Windows settings. If these settings are not adjusted properly then there start to appear strange computer problems such as Windows 7 black screen.
Follow all the guidelines and start from registry repairing scan for Windows 7 to fix Windows 7 black screen. The best available tool to repair registry and fix PC errors such as this is Reg In Out.
Sep 12, 2010 | Acer Aspire One PC Notebook
During system restore my monitor went black, is this normal? restoring back to 5 days..........dont know if i should shut computer down and start over or leave it alone, it has been an hour now.
u hvae to undo last restoration then just atke it back a few days not a whole week sometimes this does happen because drivers are updated and when u do a restore they dont un update they just are set for that point in time when the update was done for monitor software...to say it better restorations only restore the programs not the drivers...
Dec 06, 2009 | Microsoft Windows XP Home Edition
E-Machines eMachines Desktop PC Logo
60 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
