How do I lock the keypad on my motorola slvr?
If you go to menue settings security then phone lock and lock now or auto lock you defalt security code is 1234 for the slvr if you bought your phone second hand id preform a master reset on the phone first and reset all settings back to factory if you want to try that to its menue settings initial set up master reset and def is 6 zeros 000000 hope that helps you
You can not lock your keypad automatically but u can do so manually by pressing the menu key(which is upon the up navigator key) and then pressing the key * fast and repeat the same procedure for unlocking keypad
SOURCE: cell phone slvr l7 motorola
codes & passwords
Your phone’s 4-digit unlock code is originally set to 1234.
The 6-digit security code is originally set to 000000.
If your service provider didn’t change these codes, you should change them:
Find it: Press - > Settings > Security > New Passwords
If you forget your unlock code: At the Enter Unlock Code prompt,
try entering 1234 or the last four digits of your phone number. If that doesn’t work, press - and enter your 6-digit security code instead.
If you forget other codes: If you forget your security code, SIM PIN code, PIN2 code, or call barring password, contact your service provider.
SOURCE: How to replace keypad on a Motorola SLVR L6 Cell Phone
I just did this for Motorola L6. This was one of the candy bar phones, not a razor. It was a pain, but I finally figured out to do the following:
1. Take off the back.
2. Take out the battery.
3. Take out the 4 Torx Screws on top around the camera area. Mine were a T5. I've noticed others talking about a T6. I suggest taking the phone to Sears or somewhere that has these type of screwdrivers to match your size unless you have a set.
4. On the bottom back of the phone, there is a plastic piece with some vent holes that I assume are for the speakers. Gently pry this piece off, and you will find 2 additional torx screws under it.
5. Once you get all 6 screws out, you will be able to gently pry off the front outer framework, and this will allow you to replace your keypad.
6. Put it all back together in the reverse order. Hope it works!!
SOURCE: Replace Keypad for Motorola SLVR L7C
Dear customer
If you are professonaly not traind for mobile repairing then its risky. At first open the screw by screw driver and open it vary carefully step by step. It is better to go at nearest MOTOROLA service center. Thank you for visit.
momery card
