Question about GE Spacemaker JVM1640SJ Microwave Oven
Ge jvm3670sk02 microwave won't heat, have replaced the magnatron
  • 1 more comment
  • matt_burn212 Feb 03, 2010
    I was thinking it might be the thermostat, but I will check all. I'
    start that. I'm at work so I'll have to check it out later and let you
    know. Thanks, Matt.
  • matt_burn212 Feb 04, 2010
    Hi: I checked the thermostat and it is good. I checked the control
    panel and smart board and saw nothing wrong. The display is working
    fine and when you push start it lights up and the turntable gos around.
    When I replaced the magnatron the unit was on its side and I took out
    the HV. I wrote the colors of the wires. If I have these backwards
    could this be the problem? Thanks, Matt
    Hi: Is it possible I have the red, blue, black wires to the HV in the wrong order?
  • 10,515 Answers
It could be either Power Diode or High Voltage Capacitor.
Read :-
http://www.partselect.com/repair.aspx?appliance=microwave&part=no-heat
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 05, 2010
  • 8,197 Answers
Chances are you didnt need the mag.
You need to check the various components
such as HV diode and capacitor before purchasing
any other parts. One of them may be shorted.
Posted on Feb 04, 2010
  • Jyackle5
    Jyackle5 Feb 04, 2010
    There all kinds of possibilities, I’ll just list a few.
    Burnt wire connection
    Bad high voltage components, such
    as high voltage capacitor or diode.
    Any of which could be brought on
    by a bad magnetron.
    A bad winding in the transformer.
    These are just a few possibilities.
    Some troubleshooting needs to be done
    in order to isolate exactly what’s at the root
    of the problem and determine how severe it is.
  • 476 Answers
On this microwave oven, I don't believe the new magnetron came with a thermostat(black and silver piece that mounts on the side of the magnetron and two wires plug into it) you might want to check that out with an ohmmeter just for continuity, another area to look for is in the control panel area, some space-savers have two electronic panels, the first one (closest to the front) is the control panel and the second part which is the part facing inside is called a smart board, both panels develop loose solder connection due to heat build up(specially the smart board) look around the connectors and relays. and finally you have the door switches some times called interlock switches, sometimes they get erratic because of constant wear, other times they just freeze in a certain position, causing the oven inoperable. All these suggestions only apply if you have a working display in the microwave(alive in other words).
Posted on Feb 03, 2010
My GE OTR Microwave Model # JVM3670SK02 overheated when I tried to cook rice for 30 minutes...two times in a row. What could be the problem?
why are you cooking rice for 30 minutes in a microwave????? the problem is that a microwave IS NOT A RICE COOKER!!!use a rice cooker or use instant rice and heat the water for 2 1/2 minutes only!! OR BURN DOWN YOUR HOUSE!!
May 08, 2015 | GE Microwave Ovens
My GE Profile JVM3670SK02 microwave stopped heating. Can it be fixed?
Anything can be fixed, it all depends on how much it will cost to repair. Sometimes it just pays to buy another microwave oven they have come down in price quite a bit
Good luck
Feb 27, 2014 | GE Microwave Ovens
Ge spacemaker microwave JVM1650 won't heat
sounds like possible magnatron or diode thats the case its not worth repairing. but if your handy then google model nuber and get the part be extreamly careful because of the power capacitor holds extream volts. turn off and allow to sit 15min before working on
Oct 23, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
HVM1750 won't heat
The magnatron is likely to be the problem... though I have seen the fuses go , they usually follow the magnatron.
If your unit is under 5 years old , the Mag is covered under warranty and all you need to do is contact GE at
gechsconsumerrelations@ge.com
with the serial number of your unit and they will send you the replacement magnetron imediately and free of charge.
You are responsable to have the part installed , but there are videos on Utube that will walk you thru it no problem.
Sep 30, 2011 | GE HVM1750DMBB / HVM1750DMWW 1000 Watts...
Problem with the GE Spacemaker (JVM1640SJ) Microwave Oven GE Spacemaker XL1800 won't heat food anymore....It worked this morning, now won't heat. What should I do?
GE Will replace the magnetron for 9 years! Mine is a 2004 model with a one year warrently according to manual. HOWEVER they did say the magnatron was covered for nine years: call 888-239-6832. When I called they said thats all they get calls for and would send out in 3-5 days. NO CHARGE. I had to ask if there was coverage longer than a year on major parts and that's when they offered the info and I eventually was transferred to the right office. Saved $120 bucks on parts alone.
Jun 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Mircowave runs but doesn't heat and it has a load hum.
You may need a new microwave..however, the diode may be defective or the magnatron tube may need replacing,,The magnatron tube is only warranted for 5 years so it may be used up as the model is (10years)fairly old.
Jun 18, 2010 | General Electric Microwave Oven
Quit heating
This is a sure sign that the Magnatron has burnt out and needs replaced ( This is what cooks the food!) Replace magnatron in oven unit and all should work well!
Please rate my response!
THANK YOU!
Jan 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker xl1800
more than likely the fuse has blown onthe magnatron it is the button looking thing on the magnatron with two wires. there are 2 of these one is on the magnatron the other is above the heat box test these for open. if open replace. if good then replace the magnatron.
May 02, 2008 | Microwave Ovens
Not heating
Either the magnatron or the high-voltage capacitor and diode. Replace the capacitor and diode then if still not working, replace the magnatron. Its only affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Feb 06, 2008 | GE JVM1440 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
177 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
