Question about Cooktops
I have a frigidaire gallery series, electrolux oven, we used self cleaning mode, worked great. Problem is the oven doesn't work know, broiler works, just the oven wont turn on.
  • 126 Answers
Often the bake ignitor will burn out during or right after a self clean cycle.You can confirm this by either measuring voltage at ignitor while oven is on.Alternate method remove ignitor ,check continuity, If the ignitor is coming on but no gas,replace ignitor it is weak.Hope this helps ,please take the time to rate my response :)
Posted on Feb 03, 2010
My stove top works but oven and broiler will not heat
Good Afternoon friend, thanks for your post!
I see that your oven and broiler will not work on your Frigidaire range. It could be possible that your elements are bad or the thermostat may have shorted. I would suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for roughly ten minutes. If that does not help resolve your issue you may need to have a professional technician come out to pinpoint the issue within your range. Best of luck! -Matt
Feb 16, 2015 | Frigidaire Stove / Oven / Range Glass...
Where are the inline fuses on the Electrolux Frigidaire double ovens?
I appreciate your post, Richard Balzer!
I see that you would like to know the location of your inline fuses on your Electrolux wall oven. I have located the wiring diagram and the parts manual for your wall oven. I do not see the location of an inline fuse. I hope this is helpful information. -Matt
Frigidaire Manual Search Results
Jan 18, 2015 | Electrolux Frigidaire Gallery 30" Double...
I have a drop-in oven from frigidaire.I started the self cleaning process the door did not lock and the light keeps flashing,I dont know how to stop it and i cant use the oven at all.
Good Morning friend, thank you for your post!
I understand that your Frigidaire range is not allowing you to cancel and you are unable to use the oven. I would suggest holding down the "Cancel/Clear" button for ten seconds and that should cancel the self-cleaning. If that does not work I would recommend a reset on your range, you can do that by flipping off the household circuit breaker for ten minutes. I hope this has been helpful. -Matt
Oct 13, 2014 | Frigidaire 30 in. Electric Self-Clean Coil...
Why would there be no heat from frigidair oven elements?
Make sure the oven timer is set properly, if its turned off, the oven will not go on. Also check if the oven has separate fuse, it may have blown.
Aug 24, 2014 | Frigidaire Stove/Oven/Range Black Glass...
Broiler doesn't work
Do you have it on the right setting, I did that before.
Dec 11, 2012 | Maytag Stove / Oven / Range Cooktop -...
I have a Frigidaire Gallery Professional Series Stove and Oven unit. The oven temperature indicator light has been fading for years and is now barely visible. Everything else on the control panel (timer,...
Hello arab125 - I understand that the timer and clock works fine, however from what you have described it sounds like the range could possibly have a wiring failure, faulty sensor, or an issue with the EOC. I would suggest contacting a professional to move forward accurately.
Oct 08, 2012 | Frigidaire FGEF3031KB Gallery 30"...
How to clean self cleaning oven
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Mar 21, 2011 | Whirlpool 30 in. RC8700 Electric Cooktop
DOes anyone know how to set the self clean on the Madillion 850
Before you go working too hard to get your oven to go into the self clean mode (self destruct mode)....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Mar 06, 2010 | GE Cooktops
Cooktops Logo
195 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
