Whenever i type on my Dell Inspiron 14 and then i go to use the touchpad mouse, the pointer wont move for about three seconds. I cannot move the mouse immediately after i type. is there any way to fix this?
  • 76 Answers
Yes there is update the mouse drivers and also tweak the mouse settings it also might be because your computer is slow which usually indicates you need more ram or a faster cpu either way it dependes on what applications your using what version of those apps and how old your computer is and how much ram is installed
Posted on Feb 03, 2010
I have some focus problem in my Dell Inspiron laptop. While typing the caret moves to some other location. What is the solution for th?
What is happening here is, while typing, your wrists are coming into contact with the touchpad. The touchpad is interpreting this as a click and moving the caret to where the mouse pointer is located on the screen. My solution, when I had the same issue, was to buy a cordless mouse and disable the touchpad altogether. If this is not an option for you, then you must relearn your typing habits and practice typing without resting your wrists on the touchpad.
Dec 20, 2010 | Dell Computers & Internet
I cant move my cursor to my dell inspiron 1545. the touchpad wont work
Connect a USB mouse.
Then, in Control Panel, access the 'Mouse' panel, and "enable" the touchpad.
Nov 26, 2010 | Dell Inspiron 1545 Notebook
Mouse wont move
Are you referring to the mouse pointer when using the touch pad? To isolate the problem, try to use a USB mouse and see if the pointer will move. If the USB mouse works, then the touch pad could be disabled.
Refer to the user manual of the laptop and see on how you can enable the touch pad.
If same problem occur even though you're using a USB mouse, contact the manufacturer of the computer for second opinion or repair.
Good luck and have a great day!
Feb 08, 2010 | Dell Inspiron 6400 Notebook
My touchpad jumps around or the arrow won't move
Keep the palms of your hands away from your touchpad.
Just being "close" to the touchpad is enough to move the mouse-pointer.
Dec 11, 2009 | Dell F3534 Touchpad
Cursor on my keypad jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
2. Adjust the sensitivity of the touch pad:.
a. Click the Start button and click Control Panel.
b. Click Printers and Other Hardware.
c. Click Mouse.
d. When the Mouse Properties window appears, click the Pointer Options tab.
e. Under Select a pointer speed:, click to move the slider bar closer to Slow.
f. Click OK.
g. Check to see if the touch pad still behaves erratically.
3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
4. After connecting an external mouse, uninstall the touchpad driver from the Device manager listed under the "mice and other pointing devices" category and restart the Computer.
5. Download the Touchpad driver compatible to the Operating System installed on the Computer from the manufacturer's site and install it after restarting the Computer.
Good luck!!!!!!!!!!
Sep 18, 2009 | Dell Inspiron 6000 Notebook
Touchpad Sensitivity
Click on the start menu and select "Control Panel". Once in the control panel, select "Hardware and Sound". Once in the hardware and sound menu, click on "Mouse". Once the mouse menu comes up, there should be a tab labeled "Dell Touchpad". Click on that tab and then click on the large touchpad icon to take you to the touchpad options. Once in the touchpad options menu, click on "Device Select". Once you click on deivce select you should see the option to "enable" or "disable" the touchpad.
Mar 28, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 PC Notebook-touchpad working erratically,help!
i cant figure out how to turn on the croll for my inspiron 6400 touch pad
Mar 05, 2009 | Dell Inspiron 6400 Notebook
Cursor(pointer) cannot be moved by using touchpad but possibe wit
This happens to me also. Check whether the touchpad is enabled (laptops do have an option of enabling / disabling the touchpad). Secondly, you can try reinstalling the touchpad driver. Uninstall and then re-install the driver. Re-boot the system. Try using the touchpad.
Hope this helps., if so, rate me.. thanks - billa
Dec 20, 2008 | Lenovo Thinkpad R61i Notebook PC
Dell Inspiron 1526
your touchpad is just one case to sensitive. deactivate it by hitting "fn+ the tuchpad deaktivation key on your keyboard" and get yourself a mouse
Jun 22, 2008 | Dell Inspiron 1501 Notebook
Sensitive touch pad
Hi, click on start and control panel. go to mouse properties. Try to look for a tab that says either touch or touchpad. you can change the sensitivity settings there. however if this doesnt work, this could only mean that this is a physical problem with the toucpad. try to apply pressure on the outer side of the touchpad. if it moves, you're gonna need a replacement palmrest.
Oct 02, 2007 | Dell F3534 Touchpad
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
