Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
I have an admiral sal2027gbb and the alarm keeps sounding. there is ice building up on the back of the freezer. we have dad the sensor replaced and heating element but has not solved the problem. can you help
  • 52 Answers
Could be the temp is set too low that would cause the ice build-up, thus causing the alarm to set off. Try defrosting the freezer, and run the fridge again.
Posted on Feb 04, 2010
My admiral model hmg-64184 is leaking water from the bottom of freezer
It sounds like you have a broken place in the door gasket that is allowing warm air to enter the freezer.
May 29, 2015 | Admiral 26 cu. ft. Side-By-Side...
Why does freezer's alarm sound every 12 hrs?
There could be an ice build up sensor on the coil. try turning it off and using a hair dryer to melt any ice on the coil. This would be inside the rear of the freezer, you would direct the hot air into the vent that the cold air normally comes out of.
Apr 04, 2015 | Freezers
Frigidaire elite, red alarm light on,freezer defrosted, fridge icing up
Sounds like your heater is either out or the connectors are loose causing it not to be able to cool properly from ice build up
May 08, 2014 | Frigidaire Refrigerators
I have an Admiral model NS22H8. The fridge is not cooling properly and the freezer is not keeping ice cream frozen. In fact, a bottle of soda did not freeze overnight when left in freezer. I had the...
Yes is surly does sound as if the defrost heater is the problem....by (exceedingly)far it is the most common thing wrong when a Admiral side by side doesnt cool properly.
GENE
Sep 17, 2011 | Admiral Refrigerators
Hi our fridge is building up ice in freezer section & water is leaking out bottom of fridge. I cleaned ice out once but came back nxt day Cheers Wayne
The problem is caused by the failure of either the defrost thermostat or defrost heater. In any case, replacing both the defrost heater and the defrost thermostat is recommended, and that would solve your "ice in freezer" problem.
Jan 16, 2011 | Admiral Refrigerators
Ice/Water dispenser not working correctly
hi,,
it is a thermostat problem,,because of it heating is not done properly ..u should replace or fix it,,it is not a big amount....
thank u,,,
Jul 01, 2009 | Admiral 26 cu. ft. Side-By-Side...
Admiral side by side refrigerator ,model sal2027gbb
icemaker water valve is bad check to see if you can tell if the unit is turning
Apr 16, 2009 | Admiral 26 cu. ft. Side-By-Side...
What causes ice build up on the bottom of a freezer?
your drain is probably plugged so when the fridge goes on defrost the water has nowhere to go.After the defrost cycle when the frige starts to freeze again the water freezes up causing ice build up
Dec 18, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
154 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
