Question about GE WNRD2050DWC 3.5 Cu. Ft. Commercial Washer with Stainless Steel Basket
AGGITATOR NOT WORKING AND THE SPIN CYCLE NOT WORKING ALSO LOOKING FOR TEARDOWN INSTRUCTIONS.
    Problem Solver:
  • 16 Answers
How old is ure machine if it is about 5 years old and the drum is strugglin to spin u will need your motor brushes changing
Posted on Feb 03, 2010
My whirlpool Estate washer is not draining or spinning but aggitates, what can be the problem?
Sounds like a cycle switch problem. The switch is not turning and making contact with the next cycle. It needs to be changed!
Jan 09, 2013 | Whirlpool Washing Machines
My Amana washer doesn't aggitate during wash cycle
What is the model number of your unit?
Nov 30, 2012 | Washing Machines
Will not spin or aggitate. giving a code of some sort
look under the door. there is a switch that will not allow the spin cycle to work if the door is open - like when you open the washer door on the spin cycle and the spin cycle shuts off until you close the door again, its a safety thing.
see if the switch works.
cost around $3.00 put in with a screw driver - good luck - aloha
Feb 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing machine will not aggitate.
if it fills with water then stops check you lid or door switch. will the unit drain or spin if so the the timer may be bad
Sep 16, 2009 | Washing Machines
Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
Jan 23, 2009 | Kenmore 22422 Top Load Washer
Aggitator won't work and won't spin/ drains ok
Coupling is bad.
There is a coupling between the motor and the transmission. When this part breaks then it will pump the water out but won't spin or aggitate.
Jan 18, 2009 | Kenmore 15944 Top Load Washer
Washing machine will spin on the spin cycle
aggitator? Does it sound like it is? I would put a flat head in the door switch in activiate the cycle "as if it is running" put some weight on the aggitator, see if you can feel it moving while your weight is on it.
Nov 23, 2008 | Maytag Ensignia MAV2757AWW Top Load Washer
Washine mashine aggitator
Rob, sounds like you need an agitator repair kit. Not a hard job, under the dispenser cap you have a set of ears, spring and plastic bearing. The kit is cheap, you can find it here http://www.repairclinic.com/0080.asp Catriver...post back
Dec 03, 2006 | Kenmore 15864/15862 Top Load Washer
GE WNRD2050DWC 3.5 Cu. Ft. Commercial Washer with Stainless Steel Basket Logo
60 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
