Question about Kenmore Washing Machines
Ok, my problem is this: I need a new water inlet valve which is part #8271960 for my kenmore elite washing machine model #SM 9710803-a. I took a photo of what wires were hooked up where on the inlet valve but I failed to include which hoses coming from the guts of the washer are for hot and which one is for cold. I also failed to include a photo as to which corresponding spigot on the inlet valve would hook up to each the hot and cold water hoses. Need to know which hose coming from inside washer is for hot water and which is for cold (there is a green hose clamp on one) and I need to then know which spigot I would hook each up to on inlet valve (one has black tip on it and other is just the blue plastic from inlet valve).
  • 4,070 Answers
The left hose on the supply spigot is usually the hot. You can turn it on to a drip and see if it get hot.
Because it can be different try this on the washer.
Connect the water inlet valve wires and watch the valve when you put the wash temp selector on hot and cut the washer on. You should be able to see which valve moves. That is the hot. You don't have to turn the water on for this. It doesn't matter which hose from the washer you connect. Just make sure each one will easily reach the valve.
Posted on Feb 03, 2010
Model #110.49962600 water fills agates will not spin
And the code is!? Gee I hate when that happens! OK look at these:
F1--Water supply/low water fill.
o 1. Check water supply to machine.
o 2. Replace water inlet valve.
• F2--Water level too high.
o 1. Plugged/Bad water pump.
o 2. Faulty water valve.
• F3--Pump problem.
o 1. Check pump trap and clean.
I go with the last one..Common, then the pump is bad then the valve. But You didn't tell Us!
Jan 16, 2014 | Kenmore Elite 45986 Front Load Washer
Kenmore elite h5
Hello there and welcome to fixya
I am very sorry that you are having a troubles with your machine
I know that it can be very frustrating when dealing with error codes so i will do my best to try to help you thru this ok?
ok well first the f20 error code is a no water code meaning that the machine may not be getting any water into the machine or very little and after 6 minutes the error code will be shown on the display .
So what do u need to do is this
f you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Feb 10, 2012 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 front loading washer, model 110.45872400 - completely drains and runs correctly but sometimes an hour later there will be water in the tub
Your water inlet valve is leaking it needs to be replaced.You need to remove the top to access it.There are screws along the back edge holding it on.
Jul 24, 2010 | Kenmore Elite 45986 Front Load Washer
What is usually wrong when water will not fill in a new Kenmore elite 800 washer? The spin cycle works but will not fill with water. Washer is only 3 months old.
There's no water at all If there's no water at all, make these checks: Is there water getting to the machine? Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way? If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown? Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Feb 01, 2010 | Kenmore 24032\24036 Top Load Washer
Replacing inlet mix vlv on HE3 washer
you will need to take the top off, look at back of the machine toward the top and you should have 2 to 3 screws to remove. slide the top toward you .. Please Do All Steps With Power Disconected from the machine. :)
Make sure you have turned the hot and cold water off befor you take the hoses off.
Make sure you watch what wires you take off of the valve and put them back where you found them.
Remove valve and install new one.
Re install wires and lid
Jan 09, 2010 | Kenmore Elite 45986 Front Load Washer
Water flowing during the spin cycle
Hi
You are right the problem will be inlet valve or the inlet valve keeps always open to deliver the water to the inner tub of washing machine
else the problem with the main board of machine please change the mother board
Dec 22, 2009 | Washing Machines
My Kenmore Elite He4t front loading washer fills up with water when I'm not even washing clothes. I left some bed linens in the tub to be washed later in the week and when I opened the door to add some...
This condition is typically caused by faulty solenoid or solenoids at the water inlet valve. Unplug the machine, turn off the water, and remove the supply hoses. Check the solenoids at the water inlet valve. They can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity will indicate a faulty solenoid and the inlet valve assy will need to be replaced. Sorry for your trouble and I hope this helped. Best wishes.
Oct 02, 2009 | Kenmore Elite 45986 Front Load Washer
No water is going in
Check the water water supply at the water inlet valve. Remove the supply hoses and check that the small screens in the inlet valve are not clogged with rust or debris. The water inlet valve solenoids can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve will need to be replaced. I am attaching a photo for reference. Hope this helped and best wishes.
Aug 11, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite quietpak9 HE4T washer FH error code
take the lid off attached to the inlet valve to the dispenserr you will see a little white mechanisim in line with them. this is called your flowmeter take it off and blow through it is should sound like a cazoo. put it back on and try to do a wash cycle. if this doesn't help you need a new flowmeter. also if you take the kick panel off you will find the tech sheet to help you diagnose this problem.
Jun 23, 2009 | Kenmore Elite 45986 Front Load Washer
Water is collects in drum after a few hours after cycle is complete
no your inlet water valve is defective, youll need to repalce it, part number 8181694. in the mean time just turn off water in beween usages.
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
66 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
