Question about Radio Shack Pro-94 Scanner
No sound from speaker but the unit is scanning.
    Problem Solver:
  • 15 Answers
Try plugging in a headphone and see if that allows you to hear it play, or hear rushing noise (squelch open). If it does, then you know the scanner is working, and the only problem is the earphone jack, or the speaker and/or wires to it. Try removing the headphone again (try several times) to see if the only problem was dirty terminals inside the jack that disconnects the speaker when the headphone is connected. I have found several portable electronics that this was the only problem. At least it costs nothing to see if it helps!
Posted on May 06, 2010
How can I fix the sound on my Windows 7 computer
Try plugging a pair of headphones or earbuds or a different pair of known-working speakers (in places of the current speakers) - if you get sound with the "replacements", then there's a problem with the "current" speakers; otherwise, the problem is the sound on the unit.
Alternatively, plug the "current" speakers into a different (preferably, known-working) unit. If there's still no sound, then there's a problem with the speakers; otherwise, the problem is the sound on the original unit.
Jan 05, 2016 | Dell Audio Players & Recorders
No sound from speakers
Possibilities are:
Disconnected cables
Fuse
Short cut from radio to the speakers
You may have to take the radio off and look and see and if is not it, you have to test the speakers as well the lines one by one with a tester
Dec 19, 2013 | 2010 Volkswagen CC
It is scanning but no sound comes out. It is silent. Has been for 3 days.
Hi, my name is John. Welcome to FixYa. Get your frequency,s here www.RadioReference.com . Turn your Squelch until you here some static then turn it back just a little until you don't hear any static. Extend your antenna all the way out. If still no sound , try plugging a external speaker in the external speaker in the jack on the unit. If you have sound now, replace the speaker inside.. good luck and thanks for choosing FixYa....John
Nov 04, 2010 | Uniden BC72XLT Handheld Scanner
The radio is working but there is no sound coming from the speakers it was working I turned the car off and when I turned it back on no sound?
If you have high quality after market speakers with a lower impedance (2 ohm and 4 ohm) versus the factory speaker impediance (8 ohm 12 ohm and 16 ohm) your headunits sound out device is probably fried inside your head unit. that or all your speaker leads are fowling out at the same time which i would find that hard to believe. But the good new is, some of the newer head units have a low impediance fail safe, so you could have one speaker that is fowled out that is sending the head unit into protection mode which is muting the output until the fowled wires are cleared. Disconnect your speakers and turn the head unit up playing a cd or something, then connect each speaker one by one. You should have sound. hope this helps.
Aug 07, 2010 | Car Audio & Video
I bought a boat with a clarion cd/stereo head unit. I noticed a problem while trying to play the radio that the speakers continually cut out. I get music for 2-3 seconds, then a popping sound, followed by...
try taking antenna lead out of set and put a length of wire into the center hole were the antenna fits then scan,you should pick up at least one station,if you do fit a new antenna,if not try switching off any traffic anouncement services on the set ie press and hold button marked either ta/rds/tta/ast
Topspark
Aug 21, 2009 | iLO XM-MP3-CD Car Stereo
No sound from the tuner
almost Has to be antenna problem. Id get a standard arial, plug it in and stick it out the window. If that works then you know what to do.
May 03, 2009 | Car Audio & Video
NO SPEAKERS SOUND
Ok, there is a plug that looks green on the back of the unit. Match the color coding on the back of the unit and on the sound card. Make suire its plugged in the right hole because you got LINE IN- MIC and SPEAKER.. if its a 7.1 sound card then you probably got CENTER- RIGHT AND LEFT and so on.. check your cabling..
Apr 21, 2009 | Dell Inspiron 530 Desktop Computer
I have no sound
I have had the same problem with my altec lansing speakers on my desktopat home. a freind of mine who is thankfully way more tech savvy told methat is was most likely the driver, or that i had a registry error andthe sound card wasnt communicating with the speakers properly.
he told me to run a driver scan to make sure they were all in place.
this help link should fix your problem
I have had the same problem with my speakers on my desktopat home. a freind of mine who is thankfully way more tech savvy told methat is was most likely the driver, or that i had a registry error andthe sound card wasnt communicating with the speakers properly.
http://www.windowsfilehelp.com/solution.php?sc=fy&kw=speakers&key=speaker+sound+not+working
good luck!
Mar 13, 2009 | Gateway GT4022 PC Desktop
No sound
speaker points jared loose inside might need to soder back on
May 03, 2008 | Uniden BC72XLT Handheld Scanner
Head unit is on but no sound coming out
I Had That Happen To Me Its A Ground Problem. Check The Negtive Speaker Terminal And The Ground Wire Runing To The HeadUnit This Should Fix It.
Dec 17, 2006 | Kenwood KAC-9152D Car Audio Amplifier
Radio Shack Pro-94 Scanner Logo
57 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
