Question about Kitchen Appliances - Others
How to reset unicom 51152
I bought a unicom sensor security alarm model 51152, and i need to reset it so i can put own password in again, can someone please help ASAP
    Problem Solver:
  • 14 Answers
After inserting battery, press "000" then PROG.Enter your new 1-6 digit code and press PROG again.
To programme the alarm timing, press PROG then press:-
1 for 30seconds alarm 2 cycles, 20 seconds rest in between.
2 for 60seconds alarm 2 cycles, 30 seconds rest in between.
3 for 90seconds alarm 2 cycles, 30 seconds rest in between.
any more you wanna know let me know.
Tonybeatty@hotmail.com
Posted on Jul 08, 2010
  • ghost07 Feb 23, 2011
    very helpfull thanks working ok now thanks
  • nathaniel
    nathaniel Nov 01, 2013
    wen u have done this how do u put new code in
How to reset Admin password on Samsung SDR-C5300N Digitalvideo recorder
If you have forgotten your admin password on a Samsung Security DVR, most experts would suggest that you have to contact Samsung and/or send it back to Samsung to have the administrator password reset. While this is true in some cases, it is not always necessary.
Many Samsung Security DVRs have a built-in reset that will allow you to wipe the settings of the device and reset the configuration, including the administrator password. Note that if you perform one of these resets, all settings will be erased and you will have to setup the DVR again. So you should only do this as a last resort - but to reset an admin password, the last resort is the only option.
Reset Procedures for Samsung Security DVRs
There is more than one reset procedure for Samsung Security DVRs, depending on the series and model. But in total, this only amounts to a handful. Since one reset can apply to several different models, I'll provide the resets here so you can try them on yours - I won't associate any one reset with a single model because a complete list of which reset works with what model Security DVR simply doesn't exist. Some of these won't make sense based on the buttons available on your unit or your remote. In those cases, just skip that reset procedure.
If you can perform a reset (in other words, if the instructions match what you have available on your Samsung Security DVR and/or Samsung Security DVR Remote), try it, and let us know in the comments if it works and on what model. If you tell us which model Samsung Security DVR you have, along with your results of each reset procedure, we can compile a complete list of reset procedures by model so that it will be easier for those seeking this information in the future to reset their Samsung Security DVR. Also, if you have a reset that you have used and you know works, let us know and we will add it here. I will update the list of Samsung Security DVR resets/recoveries as I encounter them.
So if one of these doesn't work for you, you may want to check back occasionally. In fact, if you leave your model number in the comments and any specifics about your problem, I'll try to get that specific reset for you. For any of these comments, just use the comment section at the bottom of this page - it is checked regularly.
Samsung Security DVR Default Password
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Steps to Reset your Samsung Security DVR
Samsung Security DVR Reset Procedure #1
Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
Then enter the 4321.
Samsung Security DVR Reset Procedure #2
Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3
This reset will work on Android based DVRs only. All steps are performed on the device itself.
Turn the device Off
Wait 2 minutes
Press and hold the following buttons
POWER,
HOME
VOLUME UP
The unit should power on. Once it does, you can release power.
Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
Activate the reset using the HOME button.
When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4
This reset will work on SDR models. It may also work on other models.
With just the cameras showing, press the following in quick succession using the remote:
Freeze
Alarm
Freeze
Alarm
Freeze
Menu
Enter
Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5
This reset will work on SDR models where procedure #4 failed. It may also work on other models.
Press the DVR Button to place the system in DVR Mode
Press:
Freeze
View
Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
Samsung Security Reset Procedure #6
Courtesy Sergio Ayala
To factory reset the SDR-B74301
Reboot the DVR
Once the DVR has rebooted, enter the following sequence on the remote:
UP, RIGHT, 5, 3, 3
You will be prompted to do a factory reset. Confirm
This has been confirmed by several people. Thank you, Sergio! If this works for you, please thank him in the comments below.
These reset procedures cover many Samsung Security DVRs, but not all.
CCTV Networking Technical Support
Oct 07, 2017 | Samsung Home Security
How to reset password for a samsung SDE-3004N DVR home security system. There is no remote for the system and have lost the password.
  1. Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
  2. Then enter the 4321.
  1. Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3 This reset will work on Android based DVRs only. All steps are performed on the device itself.
  1. Turn the device Off
    Wait 2 minutes
    • POWER,
    • HOME
    • VOLUME UP
  2. The unit should power on. Once it does, you can release power.
  3. Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
  4. Activate the reset using the HOME button.
Samsung Security DVR Reset Procedure #4 This reset will work on SDR models. It may also work on other models.
  1. With just the cameras showing, press the following in quick succession using the remote:
    • Freeze
    • Alarm
    • Freeze
    • Alarm
    • Freeze
    • Menu
    • Enter
  2. Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5 This reset will work on SDR models where procedure #4 failed. It may also work on other models.
  1. Press the DVR Button to place the system in DVR Mode
  2. Press:
    • Freeze
    • View
    • Return
Samsung Security Reset Procedure #6 Courtesy Sergio Ayala
  1. Reboot the DVR
  2. Once the DVR has rebooted, enter the following sequence on the remote:
  3. UP, RIGHT, 5, 3, 3
  4. You will be prompted to do a factory reset. Confirm
Sep 18, 2017 | Samsung Home Security
My Samsung dvr model SDR75300n can't not reset my passwood.
you need to do on the dvr .remolt settings you cant do needs to be done by the dvr
Jun 15, 2017 | Samsung Cameras
How to reset my pass word on my Samsung Security Video System SDH-B74041
    Wait 2 minutes
    • POWER,
    • HOME
    • VOLUME UP
    • Freeze
    • Alarm
    • Freeze
    • Alarm
    • Freeze
    • Menu
    • Enter
  2. Press:
    • Freeze
    • View
    • Return
These reset procedures cover many Samsung Security DVRs, but not all. I will add reset procedures to this article as they become available to me. By design, Security DVRs are made to be secure, and not all of them can be reset by the consumer. If you have an urgent need related to your Samsung Security DVR, you should contact Samsung directly at their support page Samsung Support, or by calling: 877-349-3149. For less urgent matters, you can email them directly at Email Samsung Support. Support is available 7 days a week, 9:00 am - 9:00 pm EST.
Jan 08, 2017 | Samsung Home Security
2005 camry need to know
Have you tried locking all the doors windows up then using the door key not the key fob if you have one. Put the key in And manually unlocking the door this usually resets and disarms the security system in most modern vehicles. The alarm and security system will continue to function properly but this a a manual override to shut down the security systems sensors and make the audible alarm system to reset and stop sounding the ala
Apr 10, 2014 | Vehicle Parts & Accessories
Can you please reset this phone because I put a number password on it and forgot it
Dear friend,
You have not provided us your mobile model no.
Reply me with your mobile brand and its model no. And your country.
Regards,
Priyank Abhineet.
Oct 31, 2012 | Sony Ericsson Audio Players & Recorders
I bought a 1997 Nissan Infiniti from someone and set off the security system, how can I turn it off
put the key in the driver door and turn it left then right then left again, alarm with go off
Jan 26, 2012 | 1997 Infiniti.5 J30
I have an old Westinghouse Security Systems that keeps alarming every 15 minutes Model XL4600SM Key pad and its driving us crazy.. don't know how to shut it off can someone pls. help us (numeros days...
Check all ur windows and doors sensoring connections,might need to be changes.Weather is too hot or too cold,will trigger the alarm.When u arming tries by passed and any error codes for doors or windows connections codes.This should stop the fault alarm by the expanding and contracting sensors by the weathers.
Dec 15, 2010 | GE Security Simon 3 Wireless Home Security...
Forgot password
This is one of those annoying but easy things. If you can't remember the password and logon then your only option is to reset to factory settings (hold down reset for 15 seconds on this model i think). That wipes out all the settings and you then need to set it up again as it will be have just like the day you bought it. Depending on your setup that might mean you just have to set the time, turn on dhcp, setup your wifi identifier and security and put in a new password and logon.
I don't know what your situation is at home/work where ever the router is being used ie if you have roommates or people you don't want to have access to this. If thats not the case what I suggest to most people is to write down the information on a piece of masking tape and stick it on the bottom of the router. If you have a problem you can lookup the password or a setting quickly. If its at home for example and your conecerned about security if someone can look at the bottom of the router you really do have other bigger problems than network access ;-]
Sep 19, 2010 | NetGear WGR614 Wireless Router
GE Simon - Reset Installer Code & Remove Sensors
I am sure you already guessed this but it appears someone has changed the default installer code. Using the default installer, dealer, or master codes defeat the purpose of a security system as most criminals know the default codes. The only way I know of to regain control of this panel is to reset it to factory defaults. This does mean that you will have to completely re-progam the system. I would document as much stuff as you can from the display before resetting it. If you don't have a copy of the installation manual I am providing a link below. Hope this helps.
http://www.home-technology-store.com/assets/PDF/GE/Simon-Install.pdf
Mar 19, 2010 | GE Security Simon 3 Wireless Home Security...
Kitchen Appliances - Others Logo
1,419 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
