Question about Compaq Presario M2000 Notebook
BATTERY IS BAD. CHARGE CORD HEATS UP. REPLACED CORD AND CHARGER LAST YEAR
  • 25 Answers
Compaq chargers get heated up a lot when charging. This is a common problem.
Based on the issues you mentioned, unfortunately you would need to get the battery changed.
Regarding the charge cord getting heated up, try keeping it on a concrete/cold surface to lessen the heat. Unfortunately nothing more can be done about it, and as i said compaq chargers do get heated up quickly.
Thanks.
Posted on Feb 03, 2010
MH-25 is not charging the battery
Check the cords and make sure to disconnect and then reconnect the cords. Try the charger if nothing then try replacing the battery. If the battery is bad the charger will not work. If the battery is replaced and will not charge then replace the charger.
Mar 26, 2013 | Nikon MH-25 Charger NIKON
My laptop is not charging. i plug the power in but still doenst charge. im not sure if its on the power cords or on the laptop please help asap i need my laptop for school :(
Does the laptop work on AC ? Is the battery or cord/charged a replacement? First, try another cord/charger of the EXACT same specs as original. Second, Is the battery good? How old? Over 4 years? Have it tested. Beware of inexpensive aftermarket batteries and cord/chargers. I assume the laptop works on AC? If you unplug the AC , with battery in, the laptop shuts down immediately?
Nov 26, 2012 | Lenovo IdeaPad Y450 Notebook
The chair will not charge.
Greg,
You could have one or more of the following problems.
The batteries could be bad or too old to take a charge. The U-1 batteries for this chair can last between 1 and 2 years at most.
You have a bad charger cord which is making bad contact or is disconnected at the chair or the wall outlet. You can swap out this AC cord with a known good one.
The fuse at the charger is blown. The fuse is either at the back electronics console or in-line in a black boot fuse holder under the rear cover at the DC output of the charger harness. Check this fuse by holding it up to a light and checking to see if the filament is burned open. The fuse is a 7.5 amp ATO fuse usually.
The on-board charger is burnt out. This is harder to check since it is in the bottom of the electronics compartment for on-board chargers. Essentially, if the AC cord, fuse, and meter are good you should get up to 28 volts output at the batteries when they are connected to the charger output. You can pull the battery tray out or remove the base cover depending on model and put a digital voltmeter at the battery connector to test. Check the battery connections and plugs to make sure they are tight and connected.
If you have an off-board charger you can test the output and function of this charger the same way. With the off-board charger make sure it is plugged in and the switch is on before you make a voltage check at the battery connector (with the batteries plugged in).
Your most likely problem is the batteries. If the voltage is below around 18 volts, the on-board or off-board chargers will not turn on. If you can bring the voltage of the batteries up with a short term deep cycle charger clamped on the terminals you may be able to test the charger. You also need to have someone load test the batteries. If they are not holding a charge or load test weak or more than 2 years old replace them with new ones. A good technician can make all these checks in under 1 hour. The labor to replace any of these parts is also less than 1 hour. Hope this helps.
Dec 20, 2010 | Jet 3 Ultra Power Chair
I need to know how to charge a power wheelchair plse
You will need to connect the charger that was issued with the power chair to a working electrical outlet (do not use an extension cord or power bar/strip), turn it on and connect the other end to the power chairs' charging receptacle. Keep it connected for 8-12 hours or until the light on the charger indicates the batteries are charged.
If the charger indicates the batteries are charged but the charge does not last more than 1-2 hours, they batteries may have gone bad, are worn out and need to be replaced.
Aug 09, 2010 | Health & Beauty
Jazzy 1103 will not charge. Power cord and electrical outlet verified good. Plug in chair for charge, the ammeter indicator bar remains at 0, even after several minutes. If chair is powered on (while...
The battery charger is only made to last 1 year if you
re lucky. They are all made in China very cheaply and some only last a matter of months. If you are on Medicare they will replace the charger if necessary after a year. Good luck, hope this helps
May 15, 2010 | Pride Jazzy 1103 Ultra Standard Power...
One of my Ryobi 18v battery packs (1400672) won't charge, the chargers red and yellow lights stay on. How can I trick it into charging?
Use
AC / DC Power Adapter Replaces Ryobi One+ Batteryhttp://lcdpayless.com/ryobi_one_power_adapter.php
Oct 22, 2009 | Ryobi Drills
Does leaving handset in charger shorten battery life
I used to repair pagers for Motorola and back then the biggest problem we had was from bad batteries. Firemen would go on vacation and leave there pagers in the chargers while gone. They would return in a week or two and find that there pagers would not work. The chargers heat the battery while charging and this continued heating after charging would ruin the batteries. New chargers aren't as bad but it is best to cycle your battery. Run it until it needs charging, charge until charged then use until it again needs to be charged. Refrain from unnecessary charging. If you properly cycle a battery it can last for 2 or 3 years before replacing
Oct 07, 2009 | Avanti Microwave Refrigerator
Laptop will not charge but charger light is on
Sounds like a bad battery or the charger isn't putting out enough power even though the light is on.But most likely its the battery.
Jul 25, 2009 | Acer Aspire 5500 5570-2609 Laptop
I plug in my ds light to charge and the orange
If your DS is 2.5 to 3 years old, the battery may be bad. Lithium Ion batteries expire 3 years after their date of factory production, so they need to be replaced occasionally.
Also, if there is a kink or break in the electrical cord, it could cause problems. The only real solution, aside from tearing the cord apart and resoldering or taping the severed ends, is to purchase a new charging cord.
If the battery is already 100% charged, it may not display a charging light.
Jun 23, 2009 | Nintendo DS Lite Console
Charge
You need a separate battery charger for this camera. It does not have a battery charger built into the camera itself and can not be recharged thru any cords connected directly to the camera. The USB cords only transfer the files to the computer, they don't recharge the camera.
Dec 30, 2008 | Sony Cyber-Shot DSC-P50 Digital Camera
Compaq Presario M2000 Notebook Logo
96 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
