Question about Dell Dimension 3000 PC Desktop
I just recently got dsl through At&t, my dsl modem is connected just fine and works with my laptop but my desktop won't work with it. It shows I'm online but my browser(firefox) isn't working with the modem. I can't update my other programs either. I had this problem with the laptop but it resolved itself when I removed IE from my laptop. I tried to do the same with my desktop but no luck. The ping test comes back fine, so I'm stumped.
  • s_chewy_b Feb 04, 2010
    Both are wireless connections, My desktop wasn't reading the same as the laptop. However, once I made the changes to mirror what the laptop has, I have "limited or no connectivity". Speed and signal strength are great though.
  • 25 Answers
Based on the information you gave, looks like
(1) Either there is a proxy server set in your browser settings on the desktop. If yes then uncheck it.
(2) Another solution is to copy the same settings as on your laptop to the desktop. Assuming you have Windows installed, go to control panel, network connections. right click on the ethernet adapter --> properties. Select TCP/IP in connection type.Click on properties. Now here whatever entries you find (which work with AT&T) you need to copy those to desktop too.
You internet should work after this.
Thanks.
Posted on Feb 03, 2010
Testimonial: "Thank you so much!"
  • indic Feb 04, 2010
    Ok,
    Could you try changing the ip settings to DHCP? That is, you would need to go back to the desktop settings which you changed and select "obtain ip address automatically". There would be two such select buttons. Does the "Limited connectivity" disappear after this?
I'm trying to connect dsl directly to my laptop - but when I connect the eithernet cable from the dsl modem to my laptop it says there is no internet connection??? The dsl cable works fine with my...
Maybe the laptop is configured by default to look for a wireless signal through its wifi drivers, or a different previously installed modem. Go to your Computer/Control Panel/Network Sharing Center and set up a new connection there so your computer knows what to do.
Nov 02, 2010 | Dell (0E828) for Latitude C610 Modem
Can't access modem from desktop
If your DSL works on PPPOE then you need to setup PPPOE on the 2wire router with the Complete Username and the PAssword for the PPPOW connection, if your DSL works on a Local IP address like 192.168.1.254 or 192.168.1.1 then first check the gateway address of the 2wire Router, if it's in the same IP address range like the DSL Modem like 192.168.1.x the you need to change the Local IP address of the router from 192.168.1.x to 192.168.2.x that should get you up and running with the DSL Modem.
Mar 25, 2010 | 2wire 2700HG-B Router (2700HGB)
Wireless connection works fine from the d-link router but the desktop linked from the phoneline keeps going offline. Why?
You've omitted some information about your hardware & configuration & connections.
You should have:
1. cable-modem connected to cable socket (or DSL-modem connected to telephone wall-jack);
2. router connected via Ethernet cable to the cable-modem (or DSL-modem)
3. desktop computer connected via Ethernet cable to the desktop computer
4. wireless device (iPod or netbook or notebook) connected over the "ether" to the router -- this connection will stay "up" almost "forever" (as long as there is AC-power to the router and power to the wireless device).
Which parts & connections do you have?
Dec 26, 2009 | D-Link Computers & Internet
Att dsl internet on deskop and want wireless for my laptop
Yes you can buy a different DSL modem and that should not be a problem , then once you have the new DSL you just contact ATT and they will set up the settings on it...
Oct 09, 2009 | 2wire 2700HG-B Router (2700HGB)
Desktop wont connect to internet but laptop will!
repair the conection and also try a diffrent ethernet wire sometimes it could be bad
Jun 05, 2009 | Actiontec GT701C DSL Modem
Problem getting to internet through 2wire 2701hg-b router
how can I connect a 2wire 2701HG-B router to a motorola SB5101modem?
Apr 22, 2009 | 2wire Computers & Internet
Compaq evo d500 doesnot connect to internet through DSL
is the desktop connecting wirelesslly like the laptop? What kind of router are u uaing, if you are ccnnecting via a wired connection, you need to rt click on my network, "on the desktop"go to properties, add a new connection, and let the wizard walk you through the setup, it just isn't set up right for the network, you can also use the one that says connect to a home network.
Mar 17, 2009 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
Link Sys wireless G router, connects with laptop, not desktop
first unhook router and hook up pc directly yo modem and type in 191.168.1.254 and goto config tab and see is modem is ppoe or bridge to ethernet needs to be ppoe second go back into setup on router and do a manually config and tell you have a dynamic dns and finish setup process i had the same problem with att internet and att had me setting it up wrong
THESE ARE DSL INSTRUCTIONS
Feb 16, 2009 | Linksys Wireless-G WRT54GS Router...
Dell Dimension 3000 PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
