Question about HP LaserJet P3005 Printer
Prints an extra page that says @PJL SET RET=OFF
3 Suggested Answers
frcs68
  • 1605 Answers
SOURCE: LaerJet 5p Extra page prints with code
check all your application.(word, Excel) by going into print preview, you might have a single black page at the begining. ( this happens when you save the templete with a blank page.)
if that is not, let me know. got to go one step at atime.
Posted on Oct 28, 2008
  • 9 Answers
SOURCE: LaserJet 5p extra page prints first with code
When you get that kind of information those are instructions to the printer. It has been my experience that the drivers loaded for the printer are not the correct ones. Check to make sure that you have the drivers for a HP 5P printer and verify that is what kind a printer you have.
Posted on Mar 17, 2009
Sharp mx 3100n
Sounds like PJL = Printer Job Language Set source Color Convert. whatever that means !!!!
Sounds basic but have you checked the Manual ? http://www.manualsprinter.com/sharp-mx-3100n
Go through sending test prints and go from there.
Aug 25, 2014 | Office Equipment & Supplies
Canon printer prints an extra page with a message ""@PJL INFO STATUS""
More information is required like are you using windows 7 or windows 8. Suspect you may have wrong PCL driver. PCL.
Press additional functions on printer keypad. Press report settings on LCD screen. Press Printer on lcd screen then press configuration and press yes to printing configuration page.
Look at the configuration printout to see if you can find the language the printer is using is it PCL3 ,PCL6, PCL5E, PS3 ..
This has to match the driver you are using !
All these drivers are available to download from Cannon but finding the matching driver can be done via trial and error but the configuration page is easier and less painful.
A mismatched driver to printer is possibly the cause of the extra page print.
Nov 09, 2013 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Extra Line when printing from a dos-based program
your printer paper size shorter than your PC dos-program print size setting, example: if use a letter size paper to print a A4 size file which should occur two paper go out..
so you need check your PC print setting or take a presetting paper size, make a size match between PC program and paper in printer .
hope you fix it, please take a rating let me know how much helped you thanks!
May 21, 2009 | Dell 5100cn Laser Printer
Hp Laserjet 4 Plus printing very light - second post
Your description indicates that the problem is with the printer driver settings.
Go to Start, Control Panel, Printers and check the setings for Economode and ReT. The should both be off or Economode=off and ReT set to Med or Dark.
This should fix the problem. Let me know if this works or not and we can try something else.
May 03, 2009 | HP LaserJet 4m plus Printer
The printer is printing an addition page each time a page is sent
Are you using a custom written language application or are you using an application such as Word?
It appears that you are using a PJL wrapper around the print job. Please create a print to file (off of the driver screen) and send it to me at janddgasrepair@verizon.net. I'll be able to look at the job and see what ie happening.
Right now I suspect that you are not clearing out the PJL properly.
Don
Apr 04, 2009 | Lexmark T520 Laser Printer
HP LaserJet 3330 prints a configuration page after each print job
If you scroll through the menu functions to service, you can restore factory defaults. If you use the fax function you'll need to run the AiO assistant again. It may take care of it. I didn't see anything on the config page or the menu structure page that would indicate an option to require a print report after each document.
Mar 23, 2009 | HP LaserJet 3330 All-In-One Printer
Oct 28, 2008 | HP LaserJet 5p Printer
PJL
1- set tray 1 either to paper size letter or any
then paper type to ANY
2- set tray 2 to Letter and Plain
3- go to file - print - right click on printer- properties- device settings make sure you have the properties correct. ( letter size, any options must be listed here, duplex, stapler etc.. and set to on
Apr 22, 2008 | Lexmark T642 Laser Printer
HP LaserJet P3005 Printer Logo
707 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
