Question about Epson Stylus CX5400 All-In-One InkJet Printer
Epson cx5400 prints blank pages - Epson Stylus CX5400 All-In-One InkJet Printer
  • 4,041 Answers
Hi
Only things it could be is your software driver needs to be reinstalled or you got the wrong driver for the windows you are using on your PC or the heads on your printer is blocked this happens if your printer been standing long time,
There is a place in your driver when you go to print a docs there are some tabs there which will have Tools Tab you can clean heads from there, if heads not clean then try some tricks I used
Here.
Ok it got to be the heads blockage
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 04, 2010
My epson cx5500 does not print (test print ) I've been through a nozzle check and have fresh cartridges.... just end up with a blank page
If the inkjet printer has not been used for some time, and the ink cartridges are full then the print head nozzles may be blocked. If running the maintenance nozzle cleaning does not clear the print head nozzles then the print head will need to be replaced.
NOTE - inkjet print heads are not cheap, it may be better to purchase a new inkjet printer.
Jan 17, 2011 | Epson Stylus CX5400 All-In-One InkJet...
CX5400 Replaced all ink after months in storage
uninstall the printer then reinstall it according to the setup manual.Make sure you are installing the cartridges correctly.Then print a test page form the properties menu
Oct 07, 2009 | Epson Stylus CX5400 All-In-One InkJet...
I have an Epson stylus CX5400 all in one printer. It does not print, when I send a document to print the pages are blank, I have put in new cartridges
Do a nozzle check sounds like your nozzles need to be cleaned!! Here is a link to Epson http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=25301&prodoid=36478881&category=Products
Aug 27, 2009 | Office Equipment & Supplies
Epson CX5400 - use as scanner only?
imy cx5400 prints only part of the page.it also prints so light i can barley read it.When Iprint pictures there are lines all down the picture.
Aug 30, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Printer only prints blank pages epson sylus cx5400
Sorry to say, but you may want to read this thread......
http://www.fixyourownprinter.com/forums/inkjet/29681
Jul 12, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson cx5400
This sounds like a common problem that affects many CX models. You can find a countermeasure for this issue HERE. This should get you up and running again.
The fix requires some dis-assembly of the printer.
(http://www.tradebit.com/filedetail.php/1594393-Documents-eBooks-Technical)
Mar 07, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson cx5400 problems
Sound like print head is you problem, are you using epson gen inks? ussally heads clog due to dodgy inks running  threw machine, If it isn't under warranty replace with new
Oct 18, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus CX5400 prints blank pages
I've had this happen twice with the CX5400. I've fixed it both times by following the instructions on this page: http://inkjetprinterhelp.us/duraink.html (This involves dissassembling your printer so it's not for the faint of heart!)
Oct 11, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Printer problem
The Jets have dried out Which is seroius on an Epson because they are part of the machine. There is a tool you can make thats will help to clear the problem- but it will be long job. Contact also www.fixyourownprinter.com
Sep 24, 2007 | Epson Stylus CX5400 All-In-One InkJet...
My Epson 680 Printer only gives me blank pages
First of all, there is the seller's liability here. If it's from eBay, there's some protection feature for you to use. The "prints blank pages" problem is believed to be caused by a clogged purge tube. Here is a guide I found that exlpains the problem, and how to solve it: Recently, after changing out the blank ink tank on my finacee's Epson CX5400 multifunction inkjet printer, the printer began printing nothing but blank pages. Even after doing multiple head cleanings and test prints, pages would emerge from the printer completely blank. After some research, a number of fellow CX5400 owners have reported having the same problems, to the extent that the term "design flaw" became a common theme. I've owned several Epson printers and have had, generally, good luck with them. I was always somewhat suspicious of Epson's philosophy of making the print heads a permanent part of the printer and having the only replaceable part be the ink tanks, but it produced good-looking prints so it didn't bother me. Now I know, unfortunately, that this system is both a blessing and a curse. Before we delve into how to fix your blank-page-printing problem, a quick explanation on how Epson's ink delivery system works (or, rather, how it appears Epson's ink delivery system works, because Epson isn't exactly willing to divulge its trade secrets) is in order. There are a few components to the delivery system. First, you have the ink tanks. Early Epson tanks were just that; plastic boxes with a sponge inside saturated with ink. Newer tanks have a small PCB with a flash chip on it, so the printer can tell if a tank is new or used, or if it's an Epson brand cartridge or a generic replacement. In either case, the basic functionality is that it's a holder for the ink. Next in the chain are the ink tubes and primer. I've heard conflicting reports on how Epson printers get the ink out of the tanks; some believe that the tanks are positively pressurized when first installed, so that ink shoots out of the tank when the printer needs it. Other reports say that the printer puts negative pressure on the cartridge to draw ink out of it. Once the printer has the ink out of the cartridge, there are two places it can go, to either the print heads or to the purge tube. The print heads are what makes the ink spray onto the paper; the purge tube is where the ink goes when the printer primes new cartridges and cleans dirty print heads. Many cases of the "prints blank pages" problem occur right after installing new ink tanks. People have literally removed empty tanks from printers that work perfectly, and installed new tanks to find that the printer delivers blank pages (this happened to me). Since it's highly unlikely that the print heads have become clogged during the 5 minutes it takes to swap out the cartridges, the problem has to be elsewhere in the ink delivery system. So here's what happens when you install a new ink tank: 1. The new tank is installed, the printer recognizes that it's a new tank, and begins the priming sequence. 2. The printer starts to prime the tank. Ink comes out of each tank and is directed to the purge tube. 3. The ink flows through the purge tube into the internal absorbent pad. 4. After a couple seconds, the printer stops the priming sequence and probably does a quick print head cleaning. Now, a few people have done some in-depth troubleshooting and found that the "prints blank pages" problem is actually caused by a clogged purge tube. While this may not immediately make sense (you may be thinking, "so what if the tube is clogged, the ink will just spill inside the printer elsewhere"), here's what my research suggests happens when the problem occurs: 1. The new tank is installed, the printer recognizes that it's a new tank, and begins the priming sequence. 2. The printer starts to prime the tank. Ink comes out of each tank and is directed to the purge tube. 3. The tube is blocked, so the ink has nowhere to go. 4. After a couple seconds, the printer stops the priming sequence. Epson's ink delivery system appears to be a sealed system, so when the ink has nowhere to go in step 3, little ink has actually escaped the new ink tanks. This means they're not primed correctly, and won't deliver ink as they need to when the printer goes to print. So unless the purge tube gets cleaned out, you can swap tanks and perform head cleanings until the cows come home and it won't do any good. Now that there's a basic understanding of what's going on, here's how to try to fix the problem. This guide is meant to be model-agnostic; I did this procedure to a Stylus CX5400 multifunction, but it should be similar for most Epson inkjets made in the past few years. It's unknown if new Epsons still have this problem, as it usually takes a year or more to surface. The first thing you need to do is prepare your work surface. You'll need a big table, preferably one you don't care too much about. If all you have is your good kitchen table, then it's a good idea to slice open a tall kitchen garbage bag to make one large sheet, and tape it to the table to protect it. Next, you'll need the following tools and supplies: (View attached picture)
Jun 21, 2006 | Epson Stylus 680 InkJet Color Printer
Epson Stylus CX5400 All-In-One InkJet Printer Logo
74 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
