Question about Manfrotto 475B Pro Tripod
3 black pieces and the spring piece fell out while cranking it way up...how do they go back in- they obviously help smooth out the vertical raising and lowering...they re not broken.
  • 685 Answers
Try www.BogenTripodParts.com for that part. There is listed the widest selection of Bogen parts and support more models than any other web site I’ve seen. There are losts of pictures to help find just the right part.
Posted on Jun 22, 2010
Le Crueset 1.8-Qt. Enamel on steel whistling teakettle u-shaped metal piece fell out
There are two parts to the whistle - the hinged whistle bit and the black base that is attached to the spout. They are joined by a pin that passes through the base and through a bracket that is fixed above the spout, and through the bottom of the arm on the hinged whistle. Remove the pin - it is a push fit - so you need a rod of the same diameter. It will then all come to pieces. The U shaped metal spring sits in the bracket on the spout - the open end and the slope on the spring to the top. Then put the bits back together and replace the pin! This is tricky but do-able as all the holes have to line up. You need to have plenty of light to see what is going on. Once aligned the pin goes back in okay but don't try to force it. If it doesn't go in your alignment isn't right.
Mar 22, 2013 | Le Creuset 1.8-qt. Enamel on Steel...
Clean a KX-P7100 printer
The paper jam in theKX-P7100 is usually due to the paper tray.
If you pull the paper tray out you'll notice a black piece of plastic (located at the most front) with a cork like material in the middle. Try pushing down on this piece of plastic a few times. If it does not pop up immediately the grease that Panasonic used has become "sticky". The piece of plastic is removed by turning the tray upside down and pushing on the small plastic tabs that hold the black piece of plastic in. Be careful to not loose the spring that is located under the black piece of plastic or break the plastic tabs that hold it in place. Once you get the black piece of plastic out, clean it with que tips and clean the area it slides up and down in. Make sure to remove all the "sticky" grease. Once you get it clean, don't forget to stretch the spring to one more inch. the spring quality is awful at tensile strength. Then place the spring back in its place and push the black piece of plastic back in its place. You can add some light oil to the black plastic to make it slide better. After it is reassembled try pushing down on the black piece of plastic a few times. It should spring up almost immediately. This should take care of the jams that you are experiencing.
In addition, you may have to stretch the 2 big springs under the metal plate in the paper tray to one more inch. To access them, you'll have to unscrew the 3 philips screws under the tray (take a picture before :-)), take away the 2 blue pieces and take out the metal plate.
Now I'm able to print from the media tray without any problem :-).
Hope this helps!
Dec 09, 2012 | Panasonic KX-P7100 Laser Printer
Window cranks for 1986 Nova
Try your toyata dealership as they are the ones that built the car.
Oct 23, 2009 | 1986 Chevrolet Nova
Oster Power Pro Cordless Clippers I took the blade off, sm. long black plastic piece fell off. Wanted to change blade to ceramic. Can't get it back together don't know where black piece goes. Don't know...
The plastic piece is a blade guide and has a slot down the length of it which the spring locates into. Simply slide the replacement ceramic cutter under the spring
Sep 29, 2009 | Oster 76076-010 Hair Trimmer
The pin on the starting switch broke. Black and Decker CMM120
Same problem with ours. We used a bolt (cut to fit with dremmel tool) to replace the pin and the spring slipped over the bolt. I don't remember exactly where the two arms of the spring met the switch and handle, but it was obvious once the spring was on the bolt.
Aug 31, 2009 | Black & Decker 19" Electric Lawnhog...
Canon PC770 - paper tray wouldn't slide in all the way
Thats right that spring help to counter balance the top,the pease of plastic is to keep the spring in place.There are 2 spings that support the top.That plastic is not so expensive but to install the new plastic and spring is a very big job and it can be expensive.It normally takes me 3 hours to replace.The mashine can work normally it is only a hassel when you want to replase the toner .
Jun 16, 2009 | Canon PC-920 Black and White Copier
Mouse wheel a parts fell out of logitech 110 cordless mouse
Hm. I cannot find any repair or service manuals for it. I think they're supposed to be disposible ...
The closest pictures I could find were the installation guide which has very basic pictures.
I am sorry.
Try this, though, it might show something that looks familiar.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/fattach_get.php?p_sid=KMk6DnAj&p_li=&p_accessibility=0&p_redirect=&p_tbl=9&p_id=8363&p_created=1210269007&p_olh=0
Jun 15, 2009 | Logitech EX 110 Keyboard, Mouse
Missing piece, camera will not turn tape
the pinch roller goes here:
you are missing the snap spring too, which is used to lock the pinch roller.
May 21, 2009 | Sony Handycam DCR-TRV240 Digital Camcorder
Viking sewing machine
Wow, that is good detail on the tube that fell out. If it is a brass colored tube that is open on both ends then you need a new crank slide. You may also notice that the take up lever can be moved up and down about a quarter to half of an inch. That sleeve can't be put back so that it will stay, and installing a new crank slide is probably something that you will want someone to show you how to do, not read from a manual.
Is the small white wheel near the drive belt? If so, it is to hold tension on the belt. Let me know and I will look in one and can tell you where to hook it.
Sep 13, 2008 | Husqvarna Viking 1
The little spring fell off the water door, how to get it back in?
if you can't get the spring back it, put a piece of clear packaging tape folded over on itself on the opening edge of the door, that way you can grab it to open it and it's not obvious.
Nov 09, 2007 | Bemis Whole House Digital Humidifier ED11...
Manfrotto 475B Pro Tripod Logo
143 people viewed this question
Top Manfrotto Photography Experts
Mitch Davis
Mitch Davis
ray gallant
Are you a Manfrotto Photography Expert? Answer questions, earn points and help others
