Question about Adcom Audio Players & Recorders
GCD -600 powers up, won't open carousel tray or play
2 Suggested Answers
SOURCE: adcom gcd-600 won't play
If I understand your issue, you press play and the player does not recognize the disc, the optical pickup may be defective. I suggest you contact an Authorized Adcom Service Center. For further questions, contact Adcom directly.
Posted on Jan 08, 2008
Can I advance my slide tray manually?
A Kodak Carousel 600 has no Forward/Reverse buttons for tray movement. The only way to advance the tray with the slide change mechanism is by LIGHTLY depressing the SELECT bar. To manually advance the tray, push and hold the SELECT bar down fully.While holding the SELECT bar, you should be able to rotate the tray by hand. Good Luck!! Jim
Aug 08, 2013 | Kodak Carousel 600 Slide Projector
Kodak 850 Carousel Projector tray won't advance
The Carousel 850 is 40-45 years old. The symptoms you describe indicate the timing is off. Timing is an "adjust & test"..... try a SMALL adjustment and then test it.... adjust again & test again. Repeat until you get smooth tray action. See the attached illustration:
May 16, 2013 | Kodak CAROUSEL 850 KODAK
Kodak Carousel 600 Slide Projector manual
The KODAK Carousel 600 Projector has NO forward or reverse controls. To cycle the tray forward, LIGHTLY depress the SELECT bar. Reverse is accomplished by holding the SELECT bar down completely and rotating the tray by hand. Jim
Apr 03, 2013 | Kodak Carousel 600 Slide Projector
Kodak 600 projector has not advance button
You're correct!! The Kodak Carousel 600 does not have an ADVANCE button. To advance the tray you LIGHTLY depress the SELECT bar on the edge of the projector. There is no reverse capability, other than holding the SELECT bar down fully and rotating the tray by hand. Enjoy your projector!! Jim
Mar 09, 2013 | Kodak Carousel 600 Slide Projector
My Kodak Carousel 650H has a stuck slide and the tray won't move. The stuck slide is lined up with the "gate index." I tried releasing the tray but only one side of the tray releases. The...
Two steps.
1) Look down into the center of the carousel. There should be a round, flat silver knob with an elongated notch in it. Take a coin (US 5-cent piece or similar) and use it to turn the knob. This releases the catch on the metal plate under the projector. You should then be able to lift the carousel off. Be careful: some slides will fall out as the slot is not aligned with the carousel body properly once you do this.
2) Make sure the locking ring on top of the carousel is in place (or else take out all your slides. Turn the carousel over and gently rotate the metal plate covering the bottom of the carousel into position. You will hear/feel a "click" when it's in place.
The projector may have jammed because there are two slides stuck in the viewing slot--check for this before you put the carousel back on the projector. If it jams a lot the metal plate under the carousel may be bent.
Jul 17, 2011 | Kodak Carousel 4600 Slide Projector
Jammed tray
Hi there, had a similar problem.
This unit is easy to open. the four screws on the sides and two i think on the back. When it is open you will have access to the discs in the machine. the last disc will probably be jammed between the facia and the caddy and will be impeding the carousel mechanism, once removed you should check the functions starting with eject, and again to cycle, load disc position 1 insert disc and check. this player i think rotated the disc on loading to a set position, would have to open one to check. hopefully the carousel is not out of sync and all is well.
May 01, 2009 | Sony CDP-C265 CD Player
Onkyo 6 disc cd changer DX-380 has CD stuck under carousel
This has just happened to us. Often when the changer tries to select a CD on random play, it somehow knocks one CD off the carousel, usually on top of the other 5 CDs and then you can retrieve it easily. This time it knocked it down behind the carousel so the drawer could not close. We left the drawer open, carefully took the player out and tipped it upside down and then tipped it forward. We then closed the drawer while it was still upside down and then turned the player back up the right way. The loose CD fell onto the carousel and we could then open it and retrieve the CD. No damage to either CD or changer and we are now listening to music again!
Jan 04, 2009 | Onkyo DX-C380 6-Disc CD Changer
Adcom gcd-600 won't play
Dec 02, 2007 | Adcom GCD-700 5-Disc CD Changer
Pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
When i put a cd into the tray the door will close. It will say its loading but then the cd tray will reopen again not allowing the cd to play.
Nov 26, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Top Adcom Audio Players & Recorders Experts
 Grubhead
Grubhead
Computer Links
Greg Cann
Greg Cann
Are you an Adcom Audio Player and Recorder Expert? Answer questions, earn points and help others
