Question about Canon PIXMA MP830 All-In-One InkJet Printer
Will not power up. it is plugged into electrical outlet. power cord is fine and usb cable is not plugged into computer. is there a fuse or breaker or some other fault detection device in the power supply?
    President:
  • 2,306 Answers
No fuse or breaker on this model, Most times this problem is caused by a bad printhead. When they go bad it doesn't allow the printer to power up. If the printhead is not locked in the corner, you remove the inks and printhead and try powering again. It will give the no printhead error if that's the problem. If you put that printhead back in you can ruin the main logic board. You just buy a new printhead.
Posted on Feb 03, 2010
Yes there is a glass pigtail fuse on the printed circuit board of the power supply. The problem is getting into the power supply housing. It's not meant to be accessed but can be done. I removed mine from the board and it tested bad. The other problem is finding the same type and rated fuse. Good luck with that. It wasn't meant to be. Good news is that you can buy a new power supply from Canon for about thirty bucks and it's a breaze to replace. It's located where the power cord plugs into the unit and has only one screw securing it. Five minutes or less to replace.
Posted on Apr 07, 2010
No power to microwave
Hello
Check the Power Cord
Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
Switch the Outlet on
Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
Reset the Oven
Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
Check the Fuses and Breakers
See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
Oct 04, 2011 | Microwave Ovens
No power. Will not turn on
Not intended to offend;
1. If using A/C (house electrical power), please check if electrical wall outlet is active. Attempt to plug-in another electrical device such as a lamp, clock, radio, etc.. If the electrical wall outlet has top and bottom plugs, try the top and then the bottom plug to see which one works. Sometimes, the top outlet will not work, yet the bottom outlet does work. The wall outlet should be replaced by qualified technician.
2. If both outlets do NOT work, and the outlet is GFCI breaker protected, maybe pressing the RESET switch on the outlet will power-up the outlet.
3. If the outlet is NOT GFCI breaker protected, check your electrical fuse box for a tripped fuse. Sometimes, a tripped fuse is NOT visible. May have to trip the specific fuse or all fuses to off, then back on. Recheck the wall outlet.
4. Once your know the outlet is live, check the power cord (a/c adapter for laptops) to make sure they are securely plugged-in to both the wall outlet AND the PC or Laptop.
Will need more information once the above steps are taken:
Is it a Desktop or Laptop?
Make and Model (if known)?
Any lights (glowing) on the desktop or laptop?
Any lights on the A/C adapter if its a laptop?
Mar 30, 2011 | Computers & Internet
Tv will not come no timer lite blinks
Things You'll Need:
  • Electrical outlet
  • Fuses
  1. Check that the power cord is securely plugged into the power outlet.
  2. Make sure that the power outlet is receiving electricity by plugging a different device into the plug and turning the power on. If the other device does not work you likely have a blown fuse or tripped circuit breaker.
  3. Replace the blown fuse or reset the circuit breaker as needed. If it happens again, an electrician should assess the problem.
  4. Contact akai Support if Steps 1 to 3 do not solve your problem. Only a trained service technician should attempt to fix the power problem with your television
Jan 22, 2011 | Akai PT46DL10 46" HDTV-Ready Television
Air cond & electrical outlet in 1999 sprinter by keystone 33 ft
One of your breakers in your main panel should be for either one of those. Simply test receptacle for power as you try flipping each breaker off and on, until you find the right one. Quite often a high amperage draw item like electric frying pan, or hotplate plugged into the one by the kitchen area is the culprit. If they smell, or appear burnt or scorched, they should be changed, as well as the entire circuit tested for proper size wiring, as well as rated receptacle to handle big power( amperage draw). Extension cords will also cause same problem. Make sure if you have to use an extension cord, that is a heavier gauge wire, approved for that use, and is as short as possible. I'm assuming your AC is plugged in to a receptacle, and not on roof?
Apr 23, 2010 | Heating & Cooling
No power to fridge. power to house ok, circuit breaker to fridge not tripped. what to do?
plug something else into outlet and see if it works your outlet/ wiring maybe bad if it works your power cord for fridge maybe bad have a short in it if outlet or cord is bad call eletrictian
Jul 07, 2009 | Sub-Zero Refrigerators
Everytime I plug in the power cord, it trips the breaker.
Refrigerators are not designed to run on a GFCI. Try a heavy duty extension cord to the fridge from a outlet that is not GFCI protected. If it still trips you probably have a short circuit in the compressor.
May 13, 2009 | GE GTS22KBP Top Freezer Refrigerator
Photosmart 8750 carriage jammed error and skewed printing
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Jan 09, 2009 | HP Photosmart 8750 InkJet Printer
GE Harmony Profile
Did you check the terminal block where the cord plugs up and ohm the wires in the main cord? If thats not the problem then you might have a bad computer and or inverter.
Jun 30, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Spacemaker XL1400 - lights underneith don't work.
Check power outlet and breaker , recock breaker .
Open oven fuse test both end , test power cord both, if those testing point okey , try plug power and test it .
Jan 17, 2008 | Samsung MW1030WA Microwave Oven
Canon PIXMA MP830 All-In-One InkJet Printer Logo
768 people viewed this question
old marine
old marine
