Question about HP Compaq Presario V3000T Notebook
When i turn it on a black screen comes up w/DOS-type writing on it saying "we apologize for the invonvenience but windows did not start successfully. A recent hardware or software change might have caused this" and it gives me choices: safe mode, safe mode w/networking, last known configuration, or to start windows normailly... but it freezes up and doesn't let me choose...
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 83 Answers
Dear Customer,
Do the following Steps:
1.)Run the Hard Drive Self Test from BIOS.Turn On the Notebook and kepp on tapping F10 key and go to the Diagnostics and Select the Primary Hard Drive Self Test and Press Enter and Run the Test.If Passed then and Do the system recovery or IF HDD test Failed needs to purchase the New HDD with Recovery Disc from HP Tech Support by calling 1-800-474-6836
hope this will fix your issue.
Posted on Feb 03, 2010
Configuring updates screen
Try booting up in Safe Mode and see what happens.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. If it boots up ok, then do a restart into your normal windows mode.
Try running the check disk utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Jun 08, 2012 | Computers & Internet
OXOOOOOOA5 (OXOOO1OOOA OXOOOOOOOO,OXOOOOOOOO,OXOOOOOOOO)
This looks like the codes from a Blue Screen Of Death (BSOD). If so you will need a system disk to boot from and get to a dos command prompt (black screen with white writing) and type the following command:
chkdsk /r
Check Disk Repair will run for well over an hour and you will see the percentage of completion going from high to low but that is normal. Let it run to completion and then reboot.
In Windows XP to get to the dos command prompt boot from the system disk and when the options come up select Repair. Select 1 for the Windows Operating System and when it asks for the Administrator Password just press enter.
In Windows Vista to get to the dos command prompt boot from the system disk and when the options screen open you could try a startup repair. If it fails look the dos command at the bottom of the Recovery Console.
Mar 23, 2012 | eMachines ET1641-02w (PT.NA60X.001) PC...
Windows XP does not advance past Window load screen, it does not get to the use rid screen. When I turn off, The black screen with some options ( ex. Safe mode, Safe Mode with networking, strait with last...
Use the command screen with the c prompt and when the DOS window operating system comes up type in cd/windows The type in chkdsk /f /r
It will ask you to answer Y or N
Answer Y and then reboot to start chkdsk and it may repair itself
Jul 15, 2010 | Dell Dimension 4600 PC Desktop
A pop window occurred as page load error 502
Hello
Thank you for using
FixYa for your problem
go to start / then go to RUN and there copy the following( all together 1 space Between words)
regsvr32 softpub.dll initpki.dll wintrust.dll
Then Click OK to all 3 pop-up small windows-
if any fail write me apart.
if all 3 succeed then go back to RUN and type CMD a black DOS screen will pop up, type there as follow
netsh winsock reset log.tx.
then hit enter and read what its says and do as he tells you
good luck!
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 02, 2009 | Microsoft Computers & Internet
It wont start up kind of
Try start, run, then type MSCONFIG go to start tab and UNcheck everything, then go to services and at the lower left of the window it says hide microsoft services and check the box then disable all then restart and see if that helps.
Sep 02, 2009 | ASUS Eee PC 1000H Laptop
Black screen white writing...
Restart and keep pressing f8. Select safe mode and see if you can login to safe mode. If that is not possible then keep pressing F10 key to start recovery tools. Just follow instructions on the screen in recovery tool to recover your Notebook back to factory settings.
If there is any important data on the notebook, then use data backup tool in REcovery utility.
Please leave your feedback if issue was recolved
May 27, 2009 | Compaq Presario 900 /1500 Series EVO...
Limited or no connectivity. No assign network Add. to comp.
Have you checked the cable?
Try this with a new cable installed:
Go to Start menu > Run > type "cmd" (without the quotes) and hit Enter or click OK.
In the black DOS-window type "ipconfig/release" (without the quotes) and press Enter.
Type "ipconfig/renew" (without the quotes)
and press Enter.
When the DOS windows displays an IP-number (e.g 192.168.1.2), close the DOS-window and try to connect.
Alternatively right click the network-connection icon down on the far right beside the clock and choose "Repair"
Apr 25, 2009 | Computers & Internet
Computer problem
that is your DOS prompt
Try typing at the black cursor (chkdsk /r <ENTER> <Y> <ENTER> REstart the PC)
If that does not work
Shut down PC
F8 on boot get back to Advanced boot option
SAFE MODE WITH NETWORKING
Sign in as ADMIN or Owner
say yes to get to Desktop
Once you get to the Desktop
(Windows XP)
Start>RUN>CMD (This will be the command prompt window}
(chkdsk /r <ENTER> <Y> <ENTER> Restart the PC)
(Vista)
Start>Start Search>cmd>(above) Right click on CMD>Left click(RUN ADMIN) (This will be the command prompt window)(chkdsk /r <ENTER> <Y> <ENTER> REstart the PC)
Jan 23, 2009 | Intel D845GVSR Motherboard
HELP!! (dell precision 340) im getting 4 screens when i turn on m
Reboot into Safe Mode by repeatingly tapping on F8 while in process of rebooting and then select "last known good configuration". If that fails reboot again to safe mode and select safe mode with command prompt and in the command prompt type "chkdsk /f /r " <enter>
If that doesnt work do place your Windows CD into the Cd-Rom, reboot and select option "Repair"
Jan 02, 2009 | Dell Precision 360n PC Desktop
HP TOWER
go to:
  • start
  • select run
  • type cmd
  • when dos box opens type
  • sfc/scannow
  • have o/s cd ready if it needs it
  • any damaged files will be replaced
good luck
Terry
Mar 19, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
HP Compaq Presario V3000T Notebook Logo
112 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
