Question about Westinghouse 19" Widescreen Flat Panel LCD Monitor
Monitor will not come on...light flashes orange and beeps
  • 540 Answers
The beeps sound is coming out from the pc then rams are loose or defective please remove the rams clean the copper contact of the ram with a soft cloth and then reseat them if the problem persist then replace the ram.
Posted on Feb 03, 2010
Dell desktop 4 short beeps on startup
Ram Read/Write failure. Check memory modules.
Jun 15, 2014 | Dell Computers & Internet
My monitor won't show the display even though it is turned on
There may be problem in Monitor or VGA Card. When you Turn on PC the Monitor light is green after 10 second if It will be orange . It means your monitor is alright . but problem in you VGA Card. When the PC turn on there is any beep. If no beep then your RAM is alright. Problem in VGA Card.
Mar 21, 2010 | Sony SDM-HS75P/S 17" LCD Monitor
My monitor receives power, but doesn't receive signal from my computer. The green light blinks like there is something wrong and there is a faint beeping noise.
1st you separate you monitor from you Computer.
  • Now On your Monitor and check there is Faint beeping noise.
  • If there is no noise and after sometime the monitor light will change in orange colour.
  • It means there is no fault in monitor.
  • And also check Data cable of monitor is it right.
  • It means there is problem with you computer .
  • You Check the VGA Card.
  • I think there is problem with your VGA Card.
Mar 10, 2010 | Acer AL1916W 19" LCD Monitor
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    BJC-8200 beeps 10 times and wont go online.
  • Hi
  • All The Best: Pineworks
  • Oct 06, 2009 | Canon BJC 8200 Photo InkJet Printer
    Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
    freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
    Sep 13, 2009 | Freezers
    BJC55 Printer not printing
    There are some possibilities due to the above phenomena. Let's discuss about it:
    1) If the POWER light is flashing green, then your printer is now warming up or performing maintenance procedure (replacing cartridge/tank) or cleaning print head, just wait a few seconds till the light stop flash. Also if the last page of a print job not done, this POWER light flashing green.
    2) If the CHARGE/ERROR light is flashing orange with beep 3 times, it mean your cartridge need to be install (especially the 1st time turn on printer) or cartridge being replaced, just install the cartridge and press RESUME to continue.
    3) If both POWER light is flashing green and CHARGE/ERROR light is flashing orange with beep 3 times, then your printer may facing a very serious error and maybe need a replacement.
    Hope these help.
    YBC (/\)
    Nov 01, 2008 | Canon BJC 55 InkJet Printer
    Power problems with monitor?
    Hi...there,
    It's seems you got backlight inverter problems... not your 12v AC adapter. You need to replaced a new backlight inverter. Have a nice day!
    Oct 13, 2008 | Computers & Internet
    Monitor screen blank and LED orange light flashing
    For some reason, it seems as if your monitor has either lost the video signal or the capability to interpret the siganl. If you have the ability, put a second monitor (or tv) to your computer. See if you get a video siganl. If you do, then your monitor has an internal issue with the signal and needs to be addressed "hands on" by a technician. If you do not see a video, then your problem lies within your video card. Good luck.
    Aug 18, 2007 | AOC LM 720 17" Flat Panel LCD Monitor
    Westinghouse 19" Widescreen Flat Panel LCD Monitor Logo
    163 people viewed this question
    Top Westinghouse Computers & Internet Experts
    Matthew Spark
    Matthew Spark
    Paul Bade
    Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
