Hi, I think you are telling about the adapter if you are trying to insert a micro sd card then insert the card in the adapter and then try to insert it in the slot if you are using a big sd card then directly insert it in the slot.
Peripheral Subsystem Integrated webcam, 0.3-megapixel resolution, featuring enhanced technology for low-light environments
5-in-1 card reader , supporting MMC, SD, xD, MS, and MS PRO cards Built-in microphone
Two USB 2.0 ports
External display (VGA) port
Headphone/speaker/line-out jack
Microphone-in jack
Ethernet (RJ-45) port
DC-in jack for AC adapte
No its not possible as no because with the use use of any software using can't change the working of a hardware.And how can a USB device will fit in memory card slot.
I am assuming you have plugged the screen into a known working power source. You have pressed the 'on' button to turn the screen on and you have hooked up the screen to the back of the computer. What I need to know is if when you power up the computer if you see any text at all from the post AND if you see any lights on the front of the screen itself. (most all screens have lights on the front of them to tell you they are turned on, and most of the time the light is green). If the screen is on but is getting an orange or amber light that means something. Also if you see text or something on the screen initially but not in windows then it could be a resolution or driver issue.
I have an emachines e627 and it has a webcam, because there are different models of the emachines e627. Most likely you have an emachines e627-5583, that model has a webcam. If you are trying to use your webcam there is a program that is built in called just go to "C:\Windows\Video Web Camera.exe". I hope this works for you ;)
