Question about Garmin 010-00358-00 GPS Receiver
Garmin Nuvi 750 will not access sat. signal. Would external antenna fix problem? Everything else seems ok. Thanks Ben
  • 21 Answers
You have the solution here:
http://www.sharc.net/gps_antenna_repair.htm
Posted on Mar 19, 2010
Garmin nuvi will not acqire satellites
Please indicate what Nuvi model you have. Some Nuvi models have an external antenna port while others do not.
Feb 12, 2015 | Garmin GPS
GPS Garmin 1450 poor satelittle signal- can't find satelittloes
If the Garmin nuvi 1450 could find satellites at the same location and time before there's something wrong with the built-in receiver / antenna. Because it's not accessible from the outside it needs to be opened to check the antenna connections. Best is to check battery at the same time and replace it - once the problem is fixed.
At some locations there can be poor GPS sat reception - due to line of sight obstructions, such as trees, buildings. For a 2D fix it needs to "see" at least 3 satellites signals.
Jul 05, 2011 | Garmin nuvi 1450 GPS Receiver
How can I get a sattelite signal on my garmin nuvi 750? . It has worked great up until I lost the signal a few days ago. if you go to your location it is stuck on the last location before I lost the...
Power the GPS down for a spell, maybe an hour or two, overnight if possible. This will clear the memory and then power it up again, let it reboot. Make sure the GPS has a clear view of the sky or use an external antenna so the GPS can gather satellite data. Also do not press the buttons many times as this can confuse the GPS and make it "lock" up.
Feb 09, 2010 | Garmin nuvi 750 GPS Receiver
My Garmin 350 locks up and has problems locking onto Sat. It also has a problem if I move more than 100 miles in the off mode and when I restore power it takes hours to days to lock onto to its new...
Try external antenna. It worked for me. a short (12") piece of fine wire conected to the center of the external antenna socket or but an external GPS antenna. Worked for me anyway
Oct 09, 2009 | Garmin nuvi 350 GPS Receiver
No car radio / stereo for use with Garmin nuvi 750 GPS
Every Garmin Nuvi unit I've seen has a (loud) built-in speaker. The only demand our 250s and 265 make of the vehicle is a 12V power supply (and they'll even work without that for a while, until the battery goes flat).
A.
Dec 17, 2008 | Garmin nuvi 750 GPS Receiver
My Garmin Nuvi 300 often struggles to aquire, have to switch it on and off, sometimes takes quite a while to start. It then seems to work fine. Sometimes it is trying to update software, doesn't seem to...
Please read the solution that resolved this problem for may others. Most likely, you have already tried this. However, the antenna of your Nuvi 300 is the same as the entire 3xx & 6xx Nuvi series. I know this because I have worked on them.
http://www.fixya.com/support/t1115882-garmin_nuvi_360
If the above procedure does not work for you, the entire antenna assembly will need to be replaced.
The other option is to purchase an external antenna for your Nuvi and plug it into the external antenna port (gold connector) on the Nuvi antenna assembly.
Best wishes,
- Jim
Oct 21, 2008 | Garmin Nuvi 370
Garmin Nuvi 760 loses satelite reception. Tried to reset to factory settings and still having problem.
You may need to buy an additional external GPS receiving antenna. I did for my 750.
Because we love our electronics so tiny, they use an internal antenna. The gold input on the back of it, is for an external antenna available for under $20 from ebay. I used it when I lost reception in NYC, and also in rural areas. The external one has q magnet on it, and you can put it on the roof and have the cord come in your window to the unit (better than arm out window!)
check here - where i bought mine
http://cgi.ebay.com/AMPLIFIED-GPS-ANTENNA-FOR-GARMIN-NUVI-760-750-770-780_W0QQitemZ220265873242QQihZ012QQcategoryZ73348QQtcZphotoQQcmdZViewItemQQ_trksidZp1713.m153.l1262
Enjoy, NGK
Sep 03, 2008 | Garmin GPS
Garmin Nuvi 360 - Acquiring Satellites
Did you check to make sure that it is not in demo mode?
I've seen complaints that the unit is not working, and it was in demo mode.
If everything is set up properly and it still does not work, you will most likely have to send it to Garmin in the US.
Jerry G.
May 28, 2008 | Garmin nuvi 350 GPS Receiver
Sat nav
NUVI 660 ,
Well sir, did you flip up your antenna parallel to earth surface as mentionned into the manual.
Without the antenna you will not be able to get any signal.
Dec 17, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin 010-00358-00 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
