Question about D-Link DIR-625 (790069292637) Wireless Router
DIR-625 will not connect to a satellite modem
The DIR 625 will not connect to satellite modem, wireless or direct. Using default settings it will connect to a cable modem and when I move it over to the satellite modem will not work.. I have an older Netgear router that connects both ways to the satellite modem.
dll
Unplug it and **** urself =] it will work than
Posted on Jun 03, 2008
I don't know how to reset password for d-link DIR-625
Section 1 - Product OverviewHardware OverviewConnectionsUSB Connect a USB 1.1 or 2.0 flash drive to configure the wireless settings using WCN.Reset Pressing the Reset button restores the router to its original factory default settings.LAN Ports (1-4) Connect Ethernet devices such as computers, switches, and hubs.Internet Port The auto MDI/MDIX Internet port is the connection for the Ethernet cable to the cable or DSL modem.Power Receptor Receptor for the supplied power adapter.D-Link DIR-65 User Manual
If you don't know it you can check our list of default router and modem password list here.
If you have changed it and don't remember it you may have to reset your device to factory default using the reset button on most routers.
Sep 23, 2011 | D-Link DIR-625 (790069292637) Wireless...
My router suddenly stopped working yesterday and I've tried everything I can think of to fix it. I have one computer wired directly in to it and a few laptops that use wireless connections. The...
Please try to access the router's configuration page by accessing 192.168.0.1 using a computer that is wired on the router.
Default admin user name:Admin
Default admin password:
Please update firmware:
Note:Please do not upgrade the firmware over wireless connection. Anyway you wont be able to do that now but for future reference. Please use the link on the bottom.
DIR-625:
http://www.dlink.com/products/?tab=3&pid=DIR-625&rev=DIR-625
DIR-625 rev C:
http://www.dlink.com/products/?tab=3&pid=DIR-625&rev=DIR-625_revC
Jul 10, 2011 | D-Link DIR-625 (790069292637) Wireless...
I don't know how to set a password on my d-link router because my internet is insecure. How do i do this? I have the default username and password, but i don't know what to do from there.
1.Open your Internet browser and type in the default IP address for your DIR-625 wireless router: 192.168.0.1. A window will appear asking for your DIR-625 wireless router network name and password. If you do not know your existing network name, enter the default network name, "Admin." Leave the password blank. If you have already set up a network name and password, enter it now. Select "Log In."
2.Select "Wireless Settings" from the left-hand navigation bar. Put a check mark in the box marked "Enable Wireless."
3.Type your new wireless network name for your DIR-625 in the box labeled "Wireless Network Name."
4.Type your new password for your DIR-635 in the box labeled "Pre-Shared Key."
5.Select "Save Settings" from the top of the screen to save your new password.
Feb 07, 2011 | D-Link DIR-625 (790069292637) Wireless...
Hi, i m not able to connect my wii on internet.
You need to set up the IP address, Gateway and DNS fields from your route's main menu.
Actually dir-625 have a default IP Address: 192.168.0.1
Default admin username: Admin
Default admin password: (blank)
Also check it in your Local area connection, your Gateway Address: 192.168.x.x
Jan 08, 2011 | D-Link DIR-625 (790069292637) Wireless...
I need help setting up my D-Link DIR-625 Wireless Router
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Feb 18, 2010 | D-Link DIR-625 (790069292637) Wireless...
Port forwarding with DIR-625 (wireless environment)
Does your modem has a NAT too? if not then upgrade the firmware of the router that usually fix the problem, if not then ask your ISP and see if they are blocking the ports. have you tried connection without the router to see if that will work?
Sep 09, 2009 | D-Link DIR-625 (790069292637) Wireless...
Using a HN9000 modem and D-Link dir 615 together
change your routers IP address to IP address. 192.168.1.1.
Jun 06, 2009 | D-Link DIR-625 (790069292637) Wireless...
Can not connect to Internet wireless or through router to Ethern.
call service provider (isp) to insure they have routers mac address. I cannot stress this enough
Mar 01, 2009 | D-Link DIR-625 (790069292637) Wireless...
No connection with Inter with dir-625 - connection Poep
If a single computer is connected directly to the speedstream modem(a model number would be an added help), do you need to sign on with your userID and password that was provided to you by Bell Sympatico? if the answer is a yes you may need to setup PPPoE on your router but if your answer is no, then you may need to check the IP address your computer is getting from the modem if it's a private IP(192.168.x.x or 10.10.x.x) that means your speedstream modem is set to PPPoE, check if your router has the similar IP address as your modem, compare the default gateway address your computer is getting when connected directly to the modem and when connected to the router if they have the same segment like 192.168.1.x or 10.0.0.x your required to change the IP address on one of the device, my suggestion is to change it on the router then make sure you connection type is set to obtain IP address automatically(DHCP) or something like that and check if your router will get an IP from the speedstream modem.
Jan 21, 2008 | D-Link DIR-625 (790069292637) Wireless...
D-Link DIR-625 (790069292637) Wireless Router Logo
182 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
