Question about ASUS Intel 5000P Chipset...
No sound from hd graphics card goeforce 2400 output, only picture
No sound from hd graphics card HDMI output, only picture. Card connected to spdif on asus p5 Ld2 se motherboard
    Problem Solver:
  • 11 Answers
Check your audio settings if its set to hdmi output.
Also if that board has a spdif out behind near the usb ports, See if its glowing or on....if not then you have a bad motherboard. Had the same problem before with another asus board
Posted on Feb 04, 2010
Sound output through hdmi
DVI is "Digital Video Interface". No Audio is transferred through this type of connection - even if one end of the cable is HDMI.
BEST solution would be to purchase a video card with HDMI output.
Alternate solution would be to run audio from rear audio jack to TV (assuming you have an input on the TV that will accept it)
Dec 29, 2012 | ASUS P5K64 WS Motherboard
I want to connect my pc to an Samsung LCD hdmi-hdmi
HDMI and DVI are both digital signals, therefore if you used DVI - DVI it would be the same as HDMI - HDMI.
If you really want to use HDMI - HDMI you could purchase a DVI - HDMI adaptor for your graphics card. Contact your favorite computer store.
Take care!
damnor01
Sep 08, 2011 | ATI RADEON HD 2400 PRO Graphic Card
When i plug in the HDMI from the computer, WIndows Vista system NVIDIA graphics card, I get no sound. When i plug in the BlueRay player, i get sound just fine. This computer outputs to my samsung TV just...
You are using different type of HDMI cables
OR
you should use different type of HDMI cables ,depending on the products you want to connect. There are 5 different types.
Maybe this link can help in defining which cable type you need exactly.
http://www.hdmi.org/consumer/how_to_connect.aspx
Sep 19, 2010 | Philips 26PF9966 26 in. LCD Television
I uninstalled my sound card to upgrade to windows 7,now i can't get sound.
Does your Device Manager (Sound) show any entries or drivers setup?
If Yes? reinstall/download update.
Nov 13, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Hdmi
Hi, =)
Basically what you need is to connect the S/PDIF out from the soundcard\motherboard I/O ports to the 8500 graphics card S/PDIF in and HDMI should now carry both video and audio.
So you have to check the video card. On the top part you'll see a white plastic with 2 pins inside of it. This is the connector SPDIF input from the video card. So what you have to do is look up in your motherboard for a connector with 3 pins that says SPDIF OUT. Even though it looks with 3 pins ONLY 2 of them are needed. You will basically need ONLY a cable like this:
http://www.tigerdirect.com/applications/Se...00&CatId=69
You can get it at a local pc technician shop for 2 bucks only.
Anyway what you do is connect one end of the cable to the two pins from the white connector from the video card and the other end of the cable to your motherboard on the first 2 pins of the SPIDF OUT connector. Now the way to know which ones are the first two, do it this way: The first two considering reading SPIDF OUT meaning that the first one is the one closest to the "S" letter of SPDIF OUT.
If it does not work trying connecting the cable differentely as you might be connecting in a reverse order (positive-negative). Don't worry about burning anything as it's only a sound cable, and it does not carry any power.
Once you do it, go to windows control panel and select SPDIF as your default sound playback.
And you're ready to enjoy sound and video thru HDMI now!
Aug 11, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
Problems with audio after installing radeon hd 2400
This happens because the video card has hdmi output. Since hdmi output can carry audio signals also, the audio driver gets disabled. Uninstall audio driver and video driver both, install the video driver, and then install audio driver. after installing the audio driver, in playback and recording devices choose choose the audio output device you purchased along with the computer. This should fix the issue.
Revert back for any clarifications.
Warm Regards,
Zulfir Sadat M
Apr 12, 2009 | Diamond Multimedia Stealth RADEON 9250,...
Audigy 2zs
u need a 2or 3 pin spdif cable from the spdif on ur gpu to the spdif on ur mobo/soundcard. check manuals of ur gpu and mobo/soundcard for correct pin diagrams. dvi wont carry audio even if using HDMI adaptor, u need to ling the gpu to soundcard/mobo depending on what u use for sound.good luck
google "nvidia spdif to soundcard cables"
Jul 14, 2008 | Creative Labs Audigy Gamer Sound Card
ASUS Intel 5000P Chipset... Logo
117 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
