Question about Gateway FPD2275W LCD Monitor
22' Gateway FPD2275W LCD monitor menu locked
Hello.
I have a 22' Gateway FPD2275W LCD monitor, this is the problem
Everytime i press the menu button, a blue box pop up on my screen that says "MENU LOCKED". i have no idea how my monitor locked up on me. the buttons are touch interface(no physical buttons). i have the owners manual and i didnt see anything about the menu being lokced or unlocked NO WHERE in there, i spend hours reading that thing multiple times and i still havent found anything.
  • 1 more comment
  • husleman Feb 21, 2008
    thank you for the solution, but what is a OS???
  • Anonymous Mar 21, 2014
    i have caira tv lcd 22,when i turn on the monitor button and press power from remote control it is not working, what the cause???
  • Anonymous Mar 30, 2014
    i need the driver
Here is the solution, it worked for me!
http://support.gateway.com/s/MONITOR/7005483/7005719Rfaq104.shtml
Posted on Mar 07, 2008
  • morpho Mar 07, 2008
    THERE IS NO NEED AT ALL to re-install...just follow the instruction on the link above, or below
    http://support.gateway.com/s/MONITOR/700...
    Here is the instructions, below, but follow the link above, if you want to seethe images, that show you what they're tALKING OF:
    Q: How can I lock/unlock the OSD (menu screens) on the monitor?A: To Lock the OSD Buttons
    1. You must have an active video input connected to the display.
    2. Turn off the monitor.
    3. Turn on the monitor, and when the LEDs come on note the position of the top most button, just below the slider.
      View Picture
    4. After the active input message box goes away, press and hold the MENU button to activate the product tour.
      View Picture
      View Picture
    5. Press and hold the location where the uppermost button is just below the slider.
      View Picture
    6. The OSD buttons are now locked. Only the power key will function.
      View Picture
    To Unlock the OSD buttons
      View Picture
    4. After the active input message box goes away, touch the MENU button. An OSD Lock message appears.
      View Picture
      View Picture
      View Picture
    6. The OSD buttons are now unlocked.
      View Picture
    Scholar:
  • 198 Answers
This is not the problem of ur cd monitor.. this is some software problem.. just try to re-install the OS, your problem may get fixed.
Posted on Feb 20, 2008
The resolution may be too high to view movies on my older pc? how can i adjust it?
hello there:
you can reset the resolution by using the start menu click on start then go to control panel click on it then find the appearance and themes icon then locate the change screen resolution icon click on it then you should see a box pop up it will have a slide bar for the screen resolution try this and it might solve the problem hope this help you out thanks sincerely D.Jones
Jun 11, 2010 | Gateway FPD2275W LCD Monitor
GATEWAY FPD2275W 22" will show everything when unhooked from pc then reconnected but within seconds goes to a black screen. I have 2 and the other one works fine so it is definitely the monitor giving the...
Chances are that some capacitors in the power supply have failed. some monitors are known for this. The parts are readily available, but they do solder in.
Nov 13, 2009 | Gateway FPD2275W LCD Monitor
My Gateway FPD2275W LCD monitor has just failed.
Trying to find replacement parts for your model could be a task. LCDs are so inexpensive these days it would be cheaper to just replace it. Not sure if you have a Frys computer store nearby but I saw a 22" LCD for 129.00. Check your local electronics stores also. If you did find the part for your Gateway consider the cost and installation fees.
Eric
Oct 23, 2009 | Gateway FPD2275W LCD Monitor
Gateway 22 inch LCD monitor suddenly goes black...blue on light works but pic only stays on for 3 secs when computer is turned on.
Your inverter or backlight need to be replaced those are the main components that light up the display.
If you find this helpful please rate so.
Thanks
May 04, 2009 | Gateway FPD2275W LCD Monitor
Gateway 22" flatscreen monitor won't display after startup
Monitor has blown capacitors internally on the power board I can fix these let me know what you would like to do.
Mar 04, 2009 | Gateway FPD2275W LCD Monitor
22' FPD2275W gatewate monitor menu is locked
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 18, 2008 | Gateway FPD2275W LCD Monitor
AOC color Monitor 7G1R
Where are your buttons located on your monitor? If you press menu there should be a reset option.
Jan 06, 2008 | Gateway FPD2275W LCD Monitor
Osd lock problem
Hi
Try this.
PRESS AND HOLD THE SOURCE BUTTON FOR 20 SECONDS.
Should now be fine.
http://dc07.atspace.com/
Chris..
Dec 15, 2007 | Gateway FPD2275W LCD Monitor
Screen menu displays locked & unlocked
possible faulty VGA Controller board.
Dec 03, 2007 | Gateway FPD2275W LCD Monitor
Gateway FPD2275W LCD Monitor Logo
1,791 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
