Question about RTO Pit Bikes
Pit bike 125cc started but since i moved eclip on needle hight cause it was to rich it stars but dies now wont start got spark and getting fuel 5 hours old bike
    Problem Solver:
  • 3 Answers
Put the clip back to middle or where it was and adjust up idle screw at carby. The lei 2 strokes do not start from new you can pull and play with choke but until you idle it up by adjusting screw on carby about 1/4 to 1/2 turn it will fire and run.
Posted on Nov 03, 2011
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 20 Answers
Either it is not getting enough fuel or it is getting too much, the adjustment you have made is wrong, go back to the owners manual and recheck the setting.
Posted on Feb 03, 2010
I ran my 125cc Apollo pit bike for long distance and it died, won't start with kick start. We had to pull start it,but won't stay idling? How can I fix it?
TRY INCREASING THE IDLING FROM 1.5 TO 2.5 RPM DURING THE START . CHECK YOUR SPARK PLUG AS IT MIGHT CONTAIN CARBON RESIDUES .
Mar 17, 2016 | Pit Motorcycles
Theres no spark and bike wont start
you will have to check lead to spark plug then lead to coil
if your not getting spark at plug it could be a number of things ingintion
or just a loose wire best of luck hope you solve it
Mar 15, 2014 | Pit Bike 125cc 4 Stroke Dirt Bike
Hi i have a 4stroke 125cc pit bike it wont start tried bump start sorted turned over but when i reved it didnt respond then died any ideas
Tryd go to auto shop and check the carburator of your motor and clean your air filter adjust air setting in carburator and put a new fuel pump check fuel setting in carburator
Jan 18, 2014 | Motorcycles
Bike not starting
first try a new spark plug, if you get spark check gas filter, have spark ,have fuel, have timing it should start
Jan 05, 2014 | Pit Bike 125cc 4 Stroke Dirt Bike
DO I NEED A SPRING FOR THE FLOTERS IN A 125 4STROKE CARBIERATOR?? I HAVE PLENTY OF SPARK NEW OIL NEW PETROL STILL WONT START
If youre talking about the spring in the carbs. throttle bodythe answer is yes.
Inside the main chamber is a cylinder with a long pin ,this pin or needle goes to the main jet which governs the gas flow.
if the spring is missing the needle will be in the wrong position .
as far as the floats are concerned they teater on a set pin and are designed to float on top of the fuel in the float chamber.make sure they move freely and that there not rubbing on anything or bent.you might want to try some starting fluid to get things started then make your adjustments,after starting aduust the idle screw first.
a good formula for idle screw is turn the screw all the way in .
Then turn it out 3 and one half turns out,
good luck,Gary
Sep 08, 2013 | Pit Bike 125cc 4 Stroke Dirt Bike
Roketa 125cc wont start! spark plug is not giving off spark?
Check the lead and connections between the coil and the plugs, the battery and the coil. If all else fails check the battery charge.
May 08, 2013 | Motorcycles
Why my pitbike wont start or cuts out
Yep, clogged fuel filter, dirty carb. ????
Mar 24, 2013 | Pit Bike 125cc 4 Stroke Dirt Bike
My pit bike 125cc wont fire up
Try unpluging the cutouts.they are usally on 2-3 places on these bikes ,brakes,also check the fuse that is on the red wire comming off the battery it will be blown or end of fuse holder will be pushed in and not touching the fuse.
Apr 13, 2010 | RTO Pit Bikes
I have a pit bike 125 its not starting wot so ever got good spark but still not start
If you have spark them it must be gas. eather no gas or to much gas. Put it on chock, be sure the shut off valve is in on position.Now crank it over a few times , if it wont fire. Check the plug , is it wet or dry .If its wet then it may be flooded and needs to dry out and air out the cylinder.Try starting when dry. If its dry try putting a 1/2 oz of gas into the spark plug hole. replace the plug and turn it over . This will get them to fire up. Good luck DFD
Apr 22, 2009 | RTO Pit Bikes
RTO Pit Bikes Logo
338 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
