Question about McCulloch Garden
Mccullough mac 4600 chainsaw gas line connections
Need help with connections between Bulb and carburetor and fuel tank and carburetor
  • Dean Bowker
    Dean Bowker Feb 04, 2010
    I have two fule line connections on carburetor. On is on top (which is metal). One is on side (opposite side of where the set screws are located) and is plastic . Which connection do i use to connect fuel line from gas tank . I am assuming its the top connection but my new bulb is not pulling gas through the side connection . Thanks. Dean
    President:
  • 2,220 Answers
This is an example of a typical fuel system with a few suggestions:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
Your basic model number is 600465. I only saw 11- prefixes used with 600465s, no promises I did not miss any. There are a few different suffixes with the 600465s. I think the suffix is on your saw immediately after the basic model number somewhere (On older Macs it is usually on the bottom along with the serial number. The dash of the serial is often the correct prefix). I must defer to you to find your exact IPL, here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.htm
I chose "11-600465-09" as an IPL example:
http://www.ordertree.com/modelinfo/MCC/11-600465-09-MAC-4600-10%2F94-to-Current-IPL-211594/139.11-600465-09-MAC-4600-10%2F94-to-Current-IPL-211594.1.59.1.html
I find these helpful when getting into an area of repair I am unfamiliar with. Also all components are displayed and part numbers listed.
If you find different size hose a small sample of each taken to a local saw outlet should provide something suitable. Please ask how long they feel any replacement should be (usually 12" ample). HTH
Lou
If you have additional questions you can reply below and I will assist you further.
Posted on Feb 04, 2010
  • dontbother10
    dontbother10 Feb 04, 2010
    I honestly do not know Dean. Logic says the highest connection should be the bleeder (primer - air rises) But logic got me in trouble in the military. Leave the hoses long and try it. If it does not perform as you had hoped swap them and retry. The only way for to provide an informed answer is for me to have been where you are. I have not. From your description I think you have them reversed. Metal top connection to primer.
    Lou
Diagram of fuel lines from tank to primer to carb and back to tank for a poulan 2050 chainsaw.
clip_image002.gifFuel components are onthe "Engine Assembly" & "Handle, Chassis, & BarAssembly" detail pages.
Replacement fuel lines can be found at yourlocal chainsaw seller/mechanic. They are different diameters.
Fuel Line Replacement
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Feb 21, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
I'm trying to replace the fuel lines on the primer button of a small McCullough chain saw. The old ones had dry-rotted and fell off, and I couldn't determine which line goes where. My first configuration...
The primer is just a small pump--it is supposed to draw fresh fuel through the carburetor and expel it back into the tank. There are also just two lines on the carburetor--the upper one should go straight to the fuel tank and filter, the other goes to the intake side of the pump. Just pick a port of the primer (remove the other line for the moment), and try to pump fuel into the bulb (make sure the bulb is not decayed as well)--it should fill with fuel if you have the correct connection--if not, just place the line from the carburetor on the other primer port and try to pump again. If still no fuel, something is plugged in the carburetor or the fuel filter. Hope this helps!
Nov 10, 2010 | McCulloch 16" Electric Chain Saw 35 HP
Routings of fuel line to Poulan 14 inch chainsaw Model 2025
No drawings or pix, but will try for description--the line from the tank that has the fuel filter is the main fuel source which goes to the upper connection on the carburetor. The lower carburetor connection goes to the intake side of the primer bulb, and the outlet side of the primer goes back into the tank, which has no filter inside the tank. The main problem is determining the correct primer port to connect back to the carburetor. When everything is connected, try priming the carburetor. If fuel fills the bulb, you have everything connected correctly. If nothing happens, try switching the two primer port connections and try to pump fuel again. If still nothing, hook the main supply line from the carburetor over to one of the primer ports and try for fuel again--if still nothing, switch the main supply line to the other primer port and pump again. If still nothing, check for a plugged fuel filter in the tank. If the filter was plugged, then go through the previous procedure again. Make sure to replace the fuel lines with original rubber lines, not plastic. Hope this helps!
Jul 13, 2010 | Poulan 14" Chainsaw
Need to know how to connect the gas lines from the primer bulb to the carburetor on a poulan woodshark model 1950 chainsaw
The lines should be connected to push fuel into the carburetor. The output (overflow) of the carb is routed back into the tank. So, two lines in the tank, one is an overflow (return) and the other is the suction. On the primer one line from the tank and the other to the carb. Connect so as to "push" fuel into the carb when the primer bulb is pushed.
Jun 16, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Poulan 2150 gas chain saw. How do I connect new primer bulb to carb and gas tank?
Make sure the tank is filled with fresh fuel mix.Try hooking the line that goes to the tank to one of the two primer ports and operate the bulb. If it does not pull fuel in, reverse the connection to the primer and try the bulb again. Once you get fuel into the bulb, move the tank line to the other port. Install a line from the open port on the primer to the open port on the carburetor. Try the primer bulb again, it should pull new fuel from the carburetor if the two connections at the carburetor have not been reversed. This is a kind of 'hit or miss' business when connecting fuel lines that involve the primer bulb. Nothing seems to be marked on the involved parts. Hope this helps
May 15, 2010 | Garden
Need to peplace fuel line in gas tank.whats the easy way to do i
Watch the video, bar far the best method I have found.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
• If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
Take lots of notes and a few digital photographs to help with reassembly.
May 10, 2010 | McCulloch Garden
Saw repair
HTH
Lou
Dec 07, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Need to remove & replace primer bulb on mcculloch mac 3516
There are 4 different IPLs for this saw. Fuel detail are on multiple illustrations.
http://www.ordertree.com/modelinfo/MCC/22-600035-18-Mac-3516-IPL-211318-01/139.22-600035-18-Mac-3516-IPL-211318-01.1.59.1.html
A helpful video, a few of my suggestions, and a schematic follow:
HTH
Lou
Nov 15, 2009 | McCulloch Garden
I have a poulan 2150 chainsaw. I replaced the
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb refills).
  • The pressure side of the primer returns any excess fuel to the tank as it is depressed.
HTH
Lou
Oct 25, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Config of gas lined Mc Callogh chiansaw 3200
What little fuel system detail there is can be found here:
IPL (Chinese Mac, exploded parts list)
https://www.dixiesales.com/ipl/327/Chainsaws_32cc-35cc.pdf
SmallEng.com
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb, bulb returns excess to fuel tank. HTH
Lou
Oct 07, 2009 | Garden
Garden Logo
1,041 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
