Question about Life Fitness 9000 Next Generation Treadmill
The motor was smoking ,how to fix it - Life Fitness 9000 Next Generation Treadmill
  • 79 Answers
You must replace the motor or send it to repair, they must re-winding back
Posted on Feb 05, 2010
Testimonial: "very reasonable solution thank you"
How do i fix a smoking Kohler 535cc engine?
if it is a mower motor then I suspect that the air filter is leaking dirty air into the cylinder and has dusted the motor
(worn rings from abrasion)
check that the oil level is not over full
it may require a ring job
Jul 09, 2015 | Garden
1998 astra car is smoking on accelaration
It's time for an engine rebuild. Or you could get a reconditioned engine installed. All depends, if the car is in good condition and worth fixing. But it is a 15 year old car. Might be time to upgrade.
May 15, 2014 | Cars & Trucks
Burning smell smoke
Same problem here. Have you found a fix?
Jan 22, 2014 | Triumph 7.3T Treadmill Drive Motor
Excess smoke
The general rule: white-ish smoke indicates coolant in the exhaust, meaning a blown head gasket, whereas darker smoke indicates motor oil in the exhaust, which means that one (or more) cylinders have a broken ring, and the engine needs a ring job.
Fix for white smoke: replace head gasket.
Fix for black smoke: ring job.
Oct 05, 2011 | 2003 Lexus ES 300
Motor started smoking
If motor has been smoking, the electrical insulation has been compromised, not much fixing to that, I suggest using the unit till it quits, then replace
Aug 14, 2010 | Flotec Corrosion Resistant Shallow Well...
Motor runs good, starts good, but smokes. do i need a gas treatment? thanks.
if its running with the choke stuck on it will smoke it will be black smoke if the piston oil ring has worn out you get blue smoke,,and you can smell oil in the smoke there is no treatment that fixes worn out piston rings,,,only fitting new rings will fix that
Jun 21, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
I have Hoover Widepath Bagless 12 Amp Windtunnel vacuum. Yesterday I was vacuuming and smelled smoke and it shut itself off. Today I cleaned out the filters (they weren't bad) made sure nothing was...
Hi There,
When a vacuum cleaner smokes, it is usually only one of two possible problems.
It could either be that your motor burned up, or that your belts burned. The belts on this particular model are notorious for breaking, but the fact that your machine doesn't come on at all after this happened, sounds like it may be the motor.
Both of these issues have a unique smelling smoke. If the smoke smelled like an electrical burning smell, this indicates it's your motor. If the smoke smelled more like burning rubber, then it's probably your belts.
If the smoke smelled like burning rubber, here's a video that we've recorded showing step by step how to inspect, trouble shoot, and replace the belts on your vacuum cleaner. If you open it up and the belts are still in tact, then this probably is a more serious problem of the motor burning out.
. I'd be more then happy to walk you through more advanced diagnosing if this doesn't fix your problem, please just use the comment box here on the Fixya repair page.
If this was helpful to you, please be so kind and rate my repair helpful, or leave some feedback for me. This is really appreciated by the Fixya community if the repair solution was able to fix your problem.
Thanks again,
Chris Jones
GoVacuum.com
Jun 14, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Smoking from motor near passenger side windshield
UNFORTUNATELY ITS VERY POSSIBLE.BUT GET A FEW ESTIMATES.THAT SOUNDS STEEP.
Nov 20, 2008 | 2001 Ford Taurus
SMOKE
it may just be a wire rubbing the tub and the insulation is gone. smoke means something is not right. the drive motor will smoke if the windings overheat neccesitating a new motor. - the start or run capacitor for the motor may be bad.
Dec 27, 2007 | Washing Machines
Life Fitness 9000 Next Generation Treadmill  Logo
275 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
sajeel1978 .
Level 1 Expert
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
