Question about Vacuums
The power goes off and on when using my vacuum. When I push my vacuum forward, intermittently it loses power.
    President:
  • 389 Answers
Almost certainly there's a broken wire within the electric flex. This usually happens where there's most bending and pulling - that is, where the flex enters the machine or where it enters the plug. You'll need to get someone to either shorten the flex or fit a new one.
Beware that messing with electrics is potentially dangerous, so don't do it yourself unless you are confident you know what you're doing! Good luck!
Posted on Feb 05, 2010
When I push the handle forward it comes back and when I pull it back it pops a wheelie and goes forward please help
I've had that exact issue with a Kirby Diamond Edition. What has happened is that the bracket inside the machine that activates the forward and back motion of the tech drive has come out of its slot. The only way to fix this is to disassemble the machine and put it back into place.
Dec 22, 2015 | Kirby G6 Bagged Upright Vacuum
My kirby g4 motor runs backwards and so the power drive when pushed forward wants to go backwards. I need the wiring diagram so I can get it wired correctly.
The wires to the switch, coming from the carbon brushes, have been reversed. The carbon brush closest to the switch goes on the lower switch terminal.
Dec 24, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Bissell Power Steamer Pro Deluxe will not move forward
tip unit back to lift brushes off floor and roll forward until over carpet edge. tip back unit to sit flush on carpet and unlock handle so it swings freely. now pull backwards ith finger on spray trigger. that's how it works, not by pushing forwad.
May 16, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
My eureka central vac power brush turns off when pushing forward than back on when pushing back. Ever seen this before?
Yes I repair them all the time. What that means is that the connection of the hose handle to the power brush upper wand is loose. This can happen over time with use. The connection just loosens up. Do you have the exact model of the power brush?
Nov 22, 2009 | Eureka 1810 Central System Vacuum
Power nozzle works intermittently
The pin connection from the lower handle tube to the power nozzle are not making good contact. It is new, so i would have warranty service performed.
Nov 19, 2009 | Vacuums
Miele s571 vacuum cleaner power surges up and down in strength every few seconds from startup.
I just repaired the same problem. It is not the motor. There is a defective capacitor in the regulator. Large grey capacitor should have a value of 0.22uF/275V. It was in my case just 85uF. Changed capaitor and it was OK.
Jun 24, 2009 | Miele S318 Bagged Canister Vacuum
Power head for my central vacuum powers on and need to be pushed
what brand system is it? by not moves do you mean it doesn't pull itself forward? chances are its a cheap rubber belt that is stretched out and needs to be a replaced.
May 19, 2009 | Electrolux Central Vacuum
Brush won't rotate when pushed forward
I had the same problem . The reason it acts like that is due to the cable that runs from the vacuum motor to the brush assembly has an intermittent open. My fix was to find the small cable that was causing my troubles and splice it. Making sure that I recovered the insulation. Of course my local repair station wanted to replace it for $75 labor plus parts and keep it for 3 days. I took it home and did it in 30 minutes .
Dec 12, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Power cord broken inside s251i miele How do i open the s251i ????
HOW TO OPEN MIELE 251 VACCUUM: 1-Unplug from wall and disconnect power cord 2-Remove black switch panel at back of top panel: A-Use Phillips screwdriver, remove two silver screws visible between back of hinged top door and front of black switch panel
B-Push back of the panel down while pushing it forward (towards front of machine). There are two plastic notches and clips which are tightly fit together that you need to separate.
Once it releases, push it a bit more towards the front of the machine and lift off panel. It has wires connecting it to the main body so it will not remove completely.
C-Be careful not to lose the springs that simply sit inside of two plastic channels, one under each of the two switches. These are required for your witches to operate properly.
3-Locate screw at bottom of deep rectangular hole now revealed (under former location of black switch panels). Unscrew using Phillips screwdriver. 4-Open hinged top panel. Locate two silver screws, one on each side of main housing. Unscrew using Phillips screwdriver. 5-This will let you lift off the whole top assembly, door and main housing, revealing the plastic chassis and the motor unit within.
You now have access to the motor, wiring connector harnesses, circuit board and the cord reel.
Dec 07, 2008 | Miele S251i Plus Bagged Canister Vacuum
I have a self propelled Royal Dirt Devil vacuum model number 087900 and it goes backward fine but forward has to be pushed so hard it's impossible. Is this a switch? Do you know about how much the part...
You might try a new belt and/or brush roll. The brush roll is what helps pull a vacuum forward, the power drive helps, but if the brush isn't turning like it should, then it will hinder forward motion. The belt may look ok, but they stretch to the point that under load they won't drive the brush roll.
Feb 28, 2008 | Vacuums
Vacuums Logo
51 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
