While attempting to change the ink cartridge on my HP Officejet J4680 printer Ihad problems putting in the new cartridge. It appears there is a pressure type spring that is a squared "U" with hooks on both ends that let go on one side and is hanging down in the way. Is this something I can easily reposition myself....are there any diagrams that describe the proper positioning for the spring?
  • 2 more comments
  • libbys2 Feb 03, 2010
    I may not have been completely clear on my question. When I removed the cartridge a piece of wire in the square shaped "U" that I described detached from somewhere in the cartridge holder. It is now hanging from one end and blocking the new cartridge from being inserted. I do not know the original positioning of this wire...which I believe provides tension on the cartridge to keep it in place
    I downloaded the manual and looked through it....but do not see the spring anywhere.
  • libbys2 Feb 05, 2010
    I don't know where I am not being clear enough....but I do not have a problem following the directions for replacing the cartridge....It is just impossible to put the new cartridge in...as directed, because somehow the spring I described came unhooked and prevents the cartridge from being installed. I am not looking for the directions for putting a new cartridge in the printer....I am looking for assistance in properly fixing the spring....so I can follow the installation instructions.
    I have had several people answer this question by sending me detailed information on the replacement of cartridges....although that was my original intent, I have tried to stress that it is not possible to do because of the u shaped spring that became detached and will now not allow the new cartridge to be installed. I do not need to know how to change the cartridge I need to know what the proper placement of the spring is and how to reconnect that....so I can install the cartridges....which I know how to do
    President:
  • 3,278 Answers
Hello, Libby.
From what I can determine, sounds like you are referring to a cartridge latch. Unfortunately, I've been unable to find any further information.
But, if you take a flashlight, look inside and see where the other side hooks, you may be able to fix it.
Hope this helps.
Posted on Feb 06, 2010
  • 341 Answers
Step one: Remove the old cartridge
  1. Press the Power button ( While attempting to change the - c01983533.gif ) to turn on the HP product.
  2. Open the front access door. The carriage moves to the far right side of the HP product. CAUTION: If the HP product is off when the front access door is opened, the HP product will not release the cartridges. Figure 1: Open the front access doorc01429211.gif
  3. Wait until the carriage is idle and silent, and then lightly press down on a cartridge to release it.
    • To replace the tri-color cartridge, remove the cartridge from the slot on the left.
    • To replace the black cartridge, remove the cartridge from the slot on the right. Figure 2: Remove the black cartridge
  4. Pull the cartridge toward you and out of its slot.
Step two: Prepare the new cartridgeUse the following steps to prepare the new cartridge for use in the HP product.
  1. If you need a list of cartridges compatible with your HP product, follow these steps to use the HP SureSupply page:
    1. Right-click this link, HP SureSupply , and then click Open in New Window to find a complete list of compatible cartridges.
    2. Click the language selection link next to the globe icon. FiWhile attempting to change the - c01895539.jpgage selection linkc01895539.jpg
    3. From the drop-down lists, select the appropriate Language and Location , and then click Save .
    4. Enter your product number, and then press Enter . A list of compatible cartridges displays.
  2. Remove the new cartridge from its packaging. Be careful to touch only the black plastic.
  3. Use the pink pull tab toWhile attempting to change the - c01367670.jpglastic tape gently. Figure 4: Remove the tapec01367670.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or the ink nozzles. Touching these parts can result in clogs, inkWhile attempting to change the - c00442147.gif bad electrical connections. Figure 5: Do not touch the contacts or ink nozzlesc00442147.gif
Step three: Replace the old cartridgeUse the following steps to replace the old cartridge.
  1. Hold the new cartridge with the HP logo on top, and then slide the cartridge at a slight upward angle into the empty cartridge slot. Push the cartridge in firmly until it snaps into place.
    • To install a tri-color cartridge, insert it into the left slWhile attempting to change the - c01429213.gif class="h_mi">To install a black cartridge, insert it into the right slot. Figure 6: Insert the black cartridgec01429213.gif
  2. Close the front access door.
  3. An alignment page prints. You do not need to do anything with this page yet. Continue to the next step.
Step four: Place the unused cartridge in a cartridge protector If you are temporarily removing a working cartridge (for instance, removing a black cartridge in order to install a photo cartridge), put the cartridge that you are not using in a cartridge protector.
NOTE: Cartridge protectors come only with photo cartridges. If a cartridge protector is unavailable, store the unused cartridge in a rigid, airtight container (not a plastic bag). If unprotected, the cartridge can dry out and become unsuitable for use. Step five: Align the new cartridgeThe HP product prints a cartridge alignment sheet when you install new cartridges.
  1. When prompted, load unused, plain white, U.S. letter or A4 sized paper into the input tray, and then press OK on the HP product control panel.
  2. Lift the scanner lid.
  3. Place the alignment sheet on the scanner glass so that the top of the sheet is on the right side with the textWhile attempting to change the - c01366108.gif Make sure that the sheet is aligned with the right front corner of the scanner glass. Figure 7: Place the alignment sheet on the scanner glassc01366108.gif
  4. Close the scanner lid, and then press OK on the HP product control panel. The HP product aligns the cartridges.
Posted on Feb 04, 2010
  • 4,889 Answers
Easiily understandable instructions along with pictures are given on page 110-112 in the manual on the link below. You need to keep your printer on while installing the cartridge so that you can run the alignment procedure after its done. Aligning instructions are given on page 113.
Right click here and click save target as to download the manual
Hope this helps,
Sai.
Posted on Feb 05, 2010
  • 542 Answers
Download the user guide from the below mentioned web site:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=3692888&lc=en&cc=us&dlc=en&lang=en&cc=us
Revert back for more assistance.
Posted on Feb 03, 2010
I get my ink put in by Costco. I am getting an error message saying that the black ink cartridge is incompatible. But I have used this black printer cartridge before. I do not have the money to buy a new...
Are the cartridges used, genuine HP cartridges? I know that on HP and Canon printers that the brand name cartridges seem to work better than the aftermarket ones.
Dec 08, 2010 | HP Officejet J4680 InkJet Printer
New black cartridge wont print
Hi
check expire date on cartridge
perhaps you need to replace it
or clean it from maintenence menu
of your printer
In case I had help you pls vote me
Nov 06, 2010 | HP J4680 Office Jet All-In-One Printer
Print Cartridge Problem: (Tri-Color) See
Top three solutions to this query at HP support are close to your described problem: (not exact) Try the closest match to your error.
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Officejet+J4680+All-in-One+Printer&qry=print+cartridge+problem+tri-color&submit.x=0&submit.y=0&ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=3692887&productBigSeriesOid=3645080&spid=3692888&opname=HP+Officejet+J4680+All-in-One+Printer&pname_desc=HP+Officejet+J4680+All-in-One+Print%2FFax%2FScan%2FCopy&ptype=consumer&stype=pn&contextual_lname=&spname=HP+Officejet+J4680+All-in-One+Printer&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-007%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&product_line_code=DU&search=0
Nov 28, 2009 | HP Officejet J4680 InkJet Printer
Print cartridge prob [tri-color] refer to ... doc to troubleshoot
HP Officejt J4680 - All in one Printer from HP, whcih will have Printing, Fax, Scanner and Copier facilities.
Normal catridges recommened by HP are given below :
01. HP 901 - Black which will print 200 Pages.
02. HP 901 - Tri Colour which will print 200 Pages.
03. HP 901 XL Black which is a bigger one that will print 900 pages regulary.
This printer is most rugged one used by Home as well as in offices.
The follwoing message regarding this Printer taken from HP Website which gives information about the printer quality.
Enjoy the convenience of wireless connectivity with our Officejet J4680 All-in-One. You'll be able to print, copy, scan, and fax all from one device, plus print at speeds as fast as 28 pages per minute in black and 22 in color. And with our Officejet inks, you'll get high-quality printing at a lower cost per page than with a laser printer. Reliable and versatile
  • Print, copy, scan and fax with a single machine
  • Print fast, at up to 28 pages/minute black, 22 color##
  • Fax at speeds up to 33.6kpbs
  • Streamline big tasks with the 20-page automatic document feeder and 100-sheet paper tray
  • Preserve important documents for decades without fading1
Solution:
Please use the originai catridges for this printer and there will not be any issues.
In spite of this, the problem continues, please call the local HP Authorized Printer vendor to solve this problem.
If the Printer is under warranty, you will get a replacement printer with same or the higher configuration which is available in the market.
Jul 21, 2009 | HP Officejet J4680 InkJet Printer
Hp officejet j4680, incompatible cartridge
It is not necessary to buy another cartridge my friend, you can repair it. let me show you how... just take a towel paper, pour some water on and slide the cartridge slowly on, repeat this action 3 times and then slide the cartridge on another towel paper without water slowly and get the cartridge back in the printer.
good luck
Jul 02, 2009 | HP Officejet J4680 InkJet Printer
Problem of incompatible cartridge occure in my new J 4580
i had the same problem with the hp 4580. i needed to replace the black ink which i did. then the error message appeared "incompatible print cartridge tri color"...chatted with hp customer support, wasted a hour. claimed its a hardware problem need to have it fixed. i asked would i be charge he said yes but the printer was under warranty. he asked other questions...bottom line i left the chat box....bought another hp 4580, used same cartridges, same message...THEN finally i replaced the color cartridge...and BAM! it worked on both printers. solution...replace the color cartridge...cons..if this happens again its a waste of money to keep buying the colored ink...
Feb 03, 2009 | HP J4680 Office Jet All-In-One Printer
50 people viewed this question
k24674
