Making noisewhen touching anythingon keyboard
  • indic May 11, 2010
    What kind of noise is it? A beep ?
    Scholar:
  • 77 Answers
Could use some more information, like make, model, operating system (XP, Vista, Windows 7) but try this:
Go into Control Panel-look for Sounds and Audio Devices; open the applet, disable the microphone or any type of audio boost.
Posted on Feb 03, 2010
Yamaha motif xs6 after touch problem
needs first aid by cleaning it first,,if it doesnt work faulty board that serves the keys. (mks)
Aug 26, 2014 | Yamaha MOTIF XS6 Keyboard
Yamaha P-70 digital piano. A few keys are making a loud knocking noise. The note still sounds, but the knocking noise on the few keys can be heard at the other end of the house
There's an extremely comprehensive pair of videos about repairing this problem on YouTube thanks to David Allyn. I have embedded them below, or you can search "P70 Noisy Keyboard Repair".
Jan 03, 2014 | Yamaha NP 30 76 Key Lightweight Digital...
Hi , I,m Itali , sorry for my English , but I'have a problem with KC-350 ( similar KC-550) The general Gain it's not responding. The output signal is very very low and very noisy. Thank for...
Sounds like you have a poor or open ground if the loud noise is 50 or 60 Hertz. If you have the loud noise when the keyboard not connected then the open ground is in the amp. Often times it is only a cold or bad solder connection which you can touch up with a solder iron and some rosin core solder. If the noise disappears when the keyboard is not connected then I would look at the patch cord first and the connectors second. If you have a second amp you can test to cord and keyboard to verify the problem is the keyboard. If you have to touch up the solder connections, unplug and open up the unit. Make sure all connectors or seated and none of them are loose. Use a grounded three prong solder iron and 60/40 rosin core solder. Heat up connections on the connector and add a small bit of solder to each connection. Next heat up the solder connections on the circuit board and quickly add some solder. Caution, do not apply to much heat on the circuit board or the copper trace will lift off the board so you need to use as little heat as possible just to start the solder to flow then let it cool.
Aug 19, 2011 | Roland KC550 Amp Keyboard
When I type on my keyboard, the pointer skips around. I can be typing on one line and all of a sudden, the typing is in another place.
hello, This happens because you are landing some part your hand (palm) in the touch-pad when you typing. which activates the touch-pad and makes sudden movements in the pointer.
This problems for lot of laptop users, unless you can get use to prevent the hand from touching the touch-pad, the only option is getting a USB keyboard where you can plug in without any drivers and type without any trouble.
Mar 30, 2011 | Dell Inspiron 6000 Laptop Keyboard 0H5639
Some keys not working. Some keys need excessive pressure to make them register. Most of the keys are very light touch rubbery keys and so a light touch on the faulty keys mean they do not register
It's time to replace the keyboard -- it's much cheaper than taking the keyboard to a qualified technician, to try to get it repaired.
Jun 01, 2010 | Compaq Keyboard
New lenovo N500 laptop keyboard not working just noise
The N500 has a row of touch sensitive buttons above the keyboard, toward the right side of the computer. If you have accidentally press one of those buttons you may have disabled the keyboard, try pressing one of those buttons to activate the keyboard again.
Good luck.
Jul 01, 2009 | Lenovo ThinkPad T500
Toshiba qosmio E-10 noises keyboard and start up
Sound like you have a stuck key and the bip noise is the keyboard buffer pverloading.
If you can't unstick this key, you need a new keyboard.
Apr 13, 2009 | Toshiba QOSMIO E15-AV101 Notebook
HP Pavilion zd8000 keyboard skips characters
The most common reason that your cursor skips around is that you are touching the touch pad when typing. Some are more sensitive than others. On my Toshiba I had that problem, but it has a Fn key that allows me to turn off the touchpad. Problem went away when I went to a mouse instead.
Had a client with a Dell with the same problem. I had to actually physically disconnect the touchpad and her problem went away.
Now as for the first problem, (the HP), I'd say you have a stuck key on the keyboard. It would make that noise.
Feb 14, 2009 | HP Pavilion zd8000 Notebook
Keyboard
Thers a conflick methinks between mouse and keyboard if not BIOS update you may need
Sep 13, 2007 | IBM ThinkPad R50e Notebook
35 people viewed this question
k24674
