Question about Gateway 310 Series (158920) PC Desktop
I did a system restore on my computer and restored it as far back as it would allow. When it restarted it displays the screen saver but there is nothing else... no start menu or anything. If I log onto the guest account, everything appears but nothing can be changed because the guest is not the administrator. What can I do?
  • daboin_ke861 Feb 06, 2010
    I did as you suggested and I get a pop up window that says "Windows Explorer has encountered a problem" Send error report or Don't send
  • 644 Answers
When in the administrators screen is up with just the back ground press the ctrl(control) and hold down then the shift key and press escape, the task manager should apear, goto the applications tab, once there on the bottem right hand side click on new task, in the text box type: EXPLORER.EXE then click on ok, if the screen reapears with all the icons post back and i will run you through the perminant fix. cheers
Posted on Feb 03, 2010
  • jimnuggats Feb 06, 2010
    Click on send, if it a web page pops up with a fault diagnosise, have a read and get back to me, if not in a couple of days you will receive an update and your computer should be back to normal. post back and let me know, thanks.
Hard disk stop
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 11, 2013 | Toshiba Satellite 2805-S301 Notebook
My computer want start and every times I starts it it say error and please restart
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
Feb 04, 2013 | Computers & Internet
May 25th my CISnet computer would not start Windows, a file was missing. I did not have my Windows CD so I let the CISnet do the Restore. Can I undo the change after my CISnet computer restore to original...
Try the following;
1. Press "Start" on your Cisnet computer's desktop screen. Scroll up to "Accessories," then hover over "System Tools." Click on "System Restore."
2. Click the option that allows you to select a different restore point, rather than using the default restore point. The program will display a calendar.
3. Select a specific point to restore your Cisnet computer to by choosing a date from the calendar display. Click the "Next" button to confirm, then click "Finish" to close out system restore. Your Cisnet computer will restart and open with the selected settings.
Be sure that you do not unplug your Cisnet computer while running system restore because it will need sufficient battery life to complete the program.
Jun 02, 2011 | Computers & Internet
How to reset my computer to an earlier date
If you are talking about in the Windows operating system all you have to do is move you cursor down to your task bar and all the way to the left. Right click on the time, and select "adjust date and time". Then type in or select your desired date and time and press okay. You can only change your time if you want, after that you are done.
Mar 01, 2011 | Toshiba Computers & Internet
My computer was turned off improperly and now the screen saver is extra large with a very large cursor.
Hi jjbender3,
What Operating System (Windows XP, Vista, 7) are you using? You can try to do a System Restore to go back to a previous date prior to the problem.
To do System Restore in XP:
1.) Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
2.) On the Welcome to System Restore page, click to select the Restore my computer to an earlier time option, and then click Next.
3.) On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
4.) On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
5.) Log in to the computer. Then click OK on the System Restore Restoration Complete page.
To do System Restore in Vista and 7:
1.) Type restore into the Start menu search box, and you'll immediately see System Restore at the top of the start menu. Click it.
2.) Click one of the restore point, and you will have to confirm and then restart your computer to roll the system back.
Hope this helps.
Feb 23, 2011 | Computers & Internet
I am unable to access the internet from sleep mode Can only get on internet from shut down mode
Three possible causes of sleep mode. first, an extensive screensaver with password lock prevents display. A condition that is observable as a blankscreen also known as sleep mode. Second, a computer power saver settings that shutsdown during idleness. Third, An improper shut down of the computer would have caused a sleep mode to save the system data files.
Restoring the computer to regular functionalioty
First solving predictable sleep mode settings
1. A movement of mouse pointer across the screen should reestablish unprotected password modes
a. password protected sleep mode would display an promp message requiring key code soon after the mouse pointer has changed direction
sloving unpredictable sleep mode settings
1.A computer power saver, screen saver, or splash screen displays prevnting programs acess would require manually powering off the computer system.
a. A manual power back on of the system should restore to program functionality mode
important notes
1. contact expert technical assistance
Dec 20, 2010 | HP KQ495AA Pavilion A6500F Desktop PC
My xp pro on Dell gx150 not saving settings
Try to use the System Restore, this process will fix all system errors in your computer.
In your desktop screen, go to:
  1. Start Menu
  2. All Programs
  3. Accessories
  4. System Tools
  5. System Restore
  6. In the System Restore Window, choose Restore my computer to an earlier time.
For example: Today is March 22, try to locate the date were your computer is in perfect condition.
7. Click Next
8. Then you'll see some marked dates
which means those are the dates to use
the system restore
9. Choose a date, then click Next
button
10. Your computer will automatically
restart then wait for the process to
finish
11. A message will appear that states
your computer is successfully restored
12. Then observed the changes in
your computer system
Mar 22, 2010 | Dell OptiPlex GX150 PC Desktop
Toshiba power saver fatal error code 0x57
try to reinstall your operating system..or restore the system..go to control panel and click the back up or restore files so that all the errors in your computer will fixed..even a fatal error..hopefully this will help your problem..
Aug 28, 2008 | Toshiba Satellite A135-S4527 Notebook
Gateway 310 Series (158920) PC Desktop Logo
48 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
