Question about Whirlpool AWG329 Front Load Washer/Dryer
When I set my whirlpool awg 329 on programme 4 it stops just before it reaches 5 and cuts out 5,6,7, and goes straight to 8
    Brigadier General:
  • 3,917 Answers
Check whether the balance load sensor is faulty or not or check the pump/filter for blockage .
or it could be the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Posted on Feb 04, 2010
What gauge speaker wire use for yamaha R-v905 Receiver
The usual gauges range from 18 to 16 with one limiting factor being the ability of the receiver and speaker terminals to handle larger gauge wire
Jan 28, 2013 | Yamaha R-V905 Receiver
Give the allowable number of wire for each conduit sized listed below. size wire 15mm(1/2) 20mm(3/4) 25mm(1 inch) No. 2.0mm(No.14 AWG) No. 3.5mm(No 12 AWG) No....
The fill would depend on the wire type because the type of insulation determines teh circular mills of the conductor here are some examples though of THHN,THWN,THWN-2 wire.
Based on NEC2008 Annex TableC.1
1/2" (16mm)conduit=12-#14THHN,9-#12THHN,5-#10THHN,3-#8THHN,2-#6THHN
3/4" (21mm) conduit=22-#14THHN,16-#12THHN,10-#10THHN,6-#8THHN,4-#6THHN
1" (27mm) conduit-=35-#14THHN,26-#12THHN,16-#10THHN,9-#8,7-#6THHN
Aug 18, 2010 | Gb Electrical 1 30 Amp Ground Fault...
Hi I have an AWG 329 washer drier. The water won't
the pump is either broken or there is a block in the drain line sadly with these ne high tech units they can break down within weeks ive seen 3000 dollar washers and fridges writen off as quality test are very weak
Apr 21, 2010 | Whirlpool AWG329 Front Load Washer/Dryer
Just installed new steam shower, it produces steam for about 5 minutes and then blows the fuse
Based from your comments, a new steam shower that blows the fuse in five minutes. You could have installed a new steam shower that is much bigger than what you previously have.
1. For a 5000 watts steam shower at 220 volts
power must have a fuse rating of 40 amps, supply
wires of at least No. 6 AWG Type THW ; and at
110 volts a fuse rating of 80Amps, supply wires
of at least No. 2 AWG type THW.
2. For a 4000 watts at 220 volts, Fuse: 30 amps,
Supply wire: No. 10 AWG type THW. At 110volts
60 amps, Supply wires : No. 4 AWG Type THW
3. For a 3000 watts at 220 volts, Fuse: 20 amps
Supply wire: No. 10 AWG type THW; At 110volts
Fuse: 40 amps, Supply wire: No. 6 AWG THW
4. For a 2000 watts at 220 volts, Fuse: 15 amps
Supply wire: No. 10 AWG THW and at 110 volts
Fuse: 30 amps, Supply wire: No, 8 AWG THW
Nov 27, 2009 | Hammering
10/3 or 12/3
Nozzle,
AWG Ampacity from table 450-5b of the National Electric code states the maximum ampacity;
12 AWG = 20 Amps
10 AWG = 30 Amps
8 AWG - 80 Amps
According to this, an electrician would pull 10/3 (or 8/3) for a dryer service because 12/3 is not allowed (by LAW) for this application.
Hope this helped,
SG
Apr 06, 2009 | Whirlpool ET8CHEXSQ Dryer
Philips Whirlpool 400 AWG 370 door is locked
take the kick panel off and reach up the right side where the door lock is. there is a release pull down that releases the door.
Jan 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWG 354: Water flowing can not stop
Thet happens because either the water level switch/membrane switch is faulty, or because the water inlet valve is defective and stuck on open. See also : It's overfilling
Dec 19, 2008 | Washing Machines
Error Aficio 550
reset the problem first if don't work then replace laser unit
1, press "clear mode" on up-right of panal.
2, enter 107
3,press and hold "clear/stop" for 3-5 second
4, turn power off and on
Dec 12, 2008 | Ricoh Aficio 450 Copier
AWM1404/4 whirlpool skips wash programmes
try some wd40 spray around timer shaft.but yot may have to replace the timer hope this helps.
Mar 19, 2008 | Washing Machines
Whirlpool AWG329 Front Load Washer/Dryer Logo
170 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
