Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Working on a dell dimension 5150. it posts then states hardrive error, then states an alert about some thermal error(only stated this on post the first time i turned ti on) then shortly after it turns off. i can get into bios but as i look for temp readings it shuts off, doesnt give em much time to look around. I think maybe an overheating issue is involved but any insight would be nice. thnx
    President:
  • 1,768 Answers
You are probably right on here.
the 5150 has a temp sensor that is saying that the hard drive is too hot.
In the new PC this sensor is to protect the internal components from damage. If a hard drive is what we call "throttling" then it will generate to much heat and the sensor then kicks in and shut down the voltage to that component and then shuts down the PC.
This issue is usually due to dust deposits around the component or the CPU.
1. Open the case and use compressed air to clean
2. Call Dell tech support and report this issue it also may be a malfunctioning sensor on the Mother board.
3.Dell case are sometimes well engineered for air flow but because of the new processors that are installed which emit a lot of heat due to rapid processing cause the sensors to kick in also and air flow in the cases is vital and dust accumulation is mostly the culprit.
Posted on Feb 03, 2010
  • 644 Answers
Yes, it probably is the processor over heating, the bios then shuts the system down to save the processor from damage.
The only way to cure this is by taking the heat sink and fan off the processor, wiping all the old coolent solution of the processor and fan then reapply new coolent, this should solve the shuting down issue.
Dell dimension 5150 wont boot past post. I've tried afew things but nothing works. can you help? thanks
If it won't go past POST then there is a hardware error. Try removing the hard drive and RAM. The mother board should complain at power on giving messages. If it does, try fitting the RAM module by module, then the hard drive.
Apr 17, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I have a dell dimension 5150 and when i switch on i have a white screen and can go no further?
Do you get any beeps? Search POST - power on self tests. In my experience I fear you might have a motherboard failure.
Apr 15, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My Dell Dimension 5150 PC is not starting up straight away, instead the green light on the power button flashes about every second for several minutes then stops, pressing the power button then boots the...
It sounds like your system is hibernating or asleep instead of powering up. Consult the power management section of your manual here. You can also use the troubleshooting section of the Dell online support site to help find a solution to this problem. It could be the button is sticking in the bezel, or there could be some other fault with the switch or the power supply.
See a link to the support page for your system here. and follow the prompts for more details about this error.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 10, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Pc sht down stating thermal error. suppose processr fan not working. can this be the cause of the eror?
Most of the time you'll never hear the CPU fan. If you don't hear the normal fan sounds coming from your computer, it is most likely the power supply cooling fan. Hold you hand at the back of the computer where the power chord plugs in, while the computer is running, and test if you feel air blowing on your hand. If you don't, then replace your power supply. Make sure, when checking for a new PS that you get the correct pin count. Best to order from Dell since proprietary systems usually use proprietary parts and a generic PS won't fit in the opening at the back of the computer (alignment of the plug and the fan with the opening, etc.)
May 25, 2009 | Dell Dimension 4600 PC Desktop
Dell Dimension 5150 no sound - please help
You should be able to download the original driver files from Dell Support Drivers & Downloads.
However, this may be worth a try:
Go to Start --> Run, and type in services.msc.
A window will pop up with a list of services. Scroll down to Windows Audio. Right-click
and click on Properties.
Make sure that "Startup type" is set to automatic. Also, make sure, under "Service
status," start is selected.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 08, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 will not boot. Flashes amber light
I had the same issue with my Dell Dimension 5150 and I replaced the front I/O USB Audio Panel and it booted right up.
Feb 10, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150c
The flashing orange light is an error code. Dell tech support can tell you exactly what the code means. Hope this helps.
Jan 25, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I recently formated my hard drive on my dimension 5150 now i can't connect to the internet to update the puter because i can find the ethernet driver
Find a computer with internet access and type http://ftp.us.dell.com/network/R105478.EXE into the browser. It will prompt a download for your network card. Burn it to a CD or copy to USB drive. Then take to your computer and run the file and your ethernet card will be working. This is for the ethernet card on your motherboard. If you have an aftermarket one as well this will get you on your way.
Jan 06, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
128 people viewed this question
Alun Cox
