Question about RCA P46924 46" Rear Projection Television
Neon in color
Just wonderin if anyone might know why evething that should be white in color has neon highlights around it...tv was workin fine up till now
  • jr50hockey Feb 21, 2008
    what do u mean by coolant in the tubes?
  • jr50hockey Feb 22, 2008
    would that cause rhe green to be blurry? if i move the slide adjuster on the green light the hase moves with it..all the whites are like neonish
    Sergeant:
    Champion:
  • 301 Answers
Sounds like you might need a good cleaning or your tv has contaminated coolant in the picture tubes. or you just might need to adjust the screen control for the picture tubes.
Posted on Feb 20, 2008
  • MATT BECKER Feb 22, 2008
    coolant is used in projection CRTs. it is usually a mixture of ethyl glycol and glycerin. it is used to cool the face of the CRT to prevent cracking and premature aging. sometimes the coolant can react with its metal surrounding or even the light being show through it there are many different ideas about the reason that coolant gets contaminated.
Hi does anyone know how to replace door gasket on white knight 44aw dryer
Look under the lip near the mounting area. There should be a spring, just gently pull it around till it is 180 degree or more . it will fall off.
Jul 26, 2014 | White Knight Press 44AW White Tumble Dryer
I have an 52 inch hdtv model number hd52w59 and my tv was workin fine and then it started to make this popping noise in the back and now sometimes my menu screen pops up the volume changes and it changes...
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 16, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have got Samsung Plano 29 inch tv. I see redgreen and white color lines at the top of the screen.this slides down till the middle of the screen. Please suggest
May 11, 2010 | Televison & Video
LG tv shows av inputs as black & white
you need to plug all three colors in not just yellow
red blue green need to be pluged in their respective colors
Nov 28, 2009 | LG 27LC2R 27 in. LCD TV
Black and White Channel
Check the fine tuning for that channel.Adjust + or - accordingly, see what happens?
Oct 02, 2009 | Apex Digital AT2708S 27" TV
Color vs. Black/White picture issues
If the trouble is black and white looseboard in CRYSTAL. Loose need to resolder.
Apr 16, 2008 | Toshiba CF36G40 36" TV
Screen losing color.. turning black and white
Your TV goes black & white, because your Wii could be NTSC or PAL which. If your Wii is PAL and your TV is NTSC then the TV will show a blac and white color. Since NTSC is for North America and PAL for Asia
Jan 13, 2008 | Nintendo Wii Console
One channel is suddently in B &W - All rest in color
is it on a cable box? try unplug tv and box, that usually resets everything
Nov 17, 2007 | RCA TruFlat 27F520T 27" TV
Samsung HC-P4752W No Color
Do not automatically think you need to go into the service menu. I bet you 100 to 1 that you pulled out a plug or a connector somewhere OR one is not seated into the plug all the way. If the set worked with color before you messed with it, there is not a problem in the service menu. The service menu is not the fix all thing. it is there to make fine alignments and adjustments, and as a matter of fact, messing with a service menu even with the service manual is very dangerous. I have seen peeps ruin TV sets by messing around with the service menu alignments. STAY out of these alignments. they are not going to fix a problem that all of a suddenly comes up. Repair the problem in the circuit first. Good Luck
Sep 18, 2007 | Samsung HC-P4752W 47" Rear Projection...
RCA P46924 46" Rear Projection Television Logo
140 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
